Everything posted by Will W.
Forging meteorite
Older thread, surely, but im curious, Steve. What if you attempted to add carbon via carburization? As in, the same way shear steel and blister steel are made. One assumes that if the meteorite is of high enough iron content, the carbon will migrate into it, yes? I wonder if the high nickel content usually found in meteorites would inhibit carbon uptake? It would likely be better to refine the meteorite first, in order to get it as purely metallic as possible, before carburizing, similarly to how wrought iron would be refined before it was carburized. This is just my speculation.
Billy Thats. So. Cool. What an awesome idea. Never occured to me to make a shifter. Another idea added to the list. I think it came out looking good for being "rushed."
Favorite handle materials?
Ax and hammer handles: ash is my go-to. Tough, light, and takes a stain well. Favorite knife handle material? Well jeez, thats a huge question in its own right. Cocobolo, Bocote, Ebony and Desert Ironwood are among my favorites for exotics, and black walnut is my favorite for domestics.
Feng shui in a blacksmith shop
Hmm... bending a piece back and forth quickly will produce quite a bit of heat... im sure if i open my car door at 60 mph and scrub my workpiece on the asphalt, i could produce some heat... angle grinder?
photos needed
I see. Well, i wish i had the skill to produce patterns such as that, i would be glad to help, Steve.
photos needed
Im sure you could google those terms and find a plethora of results under images.
I rearrange the tools in my shop quite often. I usually put them right in the last spot i would think of when i next need them. Now, please excuse me. Where did i put the 10mm socket...?!
- Heat Treating a Frizzen
Hey all. I realize theres a gunsmithing section of this forum, but thats a very low traffic section near the bottom, as such i thought i could receive more information by placing this thread in General HT. Traditionally, the frizzen of a flintlock was case hardened, to provide a sufficient surface for the flint to create sparks from. My question; could you simply through harden a piece of, say, 1095 and do a low temper at 350-400° F? While i am no expert, i imagine frizzens were typically case hardened because it was simply easier, given the materials of the time. When demand for rifles was high, using high carbon blister steel would likely be too time consuming and expensive, and also a waste of good quality steel that could be used elsewhere, such as in the springs or barrels. Nowadays, we have easy access to high carbon steel, so it would seem logical to through harden a piece of that instead of going through the process of case hardening. But could one expect similar results? Thanks.
- Arm & Hammer Anvil
What does a grandfather do when a grandson wants to make a knife
Really has an effect on the self esteem when a 9 year old makes a better first knife than I did . Seriously though, that is soooo cool. Kids need to learn the value of working with their hands. Good on you for letting him and helping him. Like Frosty said, hes going to be telling HIS grandkids about that knife.
curves ahead
Steelmaking Before Bessemer is actually on my "need to buy" list, Thomas. Seems like a good set. I believe it was your recommendation (among *many* others) that brought it to my attention, so thank you, i suppose. Crucible steel is very interesting, Steve. I look forward to reading about it.
ABL Stainless
AEB-L creates a very nice edge due to its chemistry being designed for a lack of large carbide formation, assuming a correct heat treat of course. Its a great stainless to work with, IMO. Lots of bladesmiths recommend it for razors.
curves ahead
Well, I would enjoy reading about the intricacies of iron smelting and steel making. Not just ore to bloom, but crucible steel, tamahagane/orishagane, blister steel, weight ratios for charges, identification and differences between ores, e.g. magnetite, hematite, geothite, maghemite, etc, different types of furnaces e.g. bloomery, tatara, catalan, etc. But i guess thats sort of an entire book on its own, isnt it?
curves ahead
Interesting. Thank you.
curves ahead
Cool! I like the pattern. Do you know what the chemistry of the meteorite is? Just curious is all.
Student with Project Dilemma
I, for one, love when Thomas references archaeometallurgical books. It makes my "need to buy" list a little longer each time. Though i am still wondering how im going to justify the price tag on a copy of "The Knight and the Blast Furnace."
Don't ask how we know these things
Dont arc weld with your sleeves up. Dont use demo saw wheels on an angle grinder (so ive, uh, been told *nervous cough*) Dont use a wire wheel on a grinder with an unbuttoned flannel. Dont do *anything* in the shop without safety glasses. Dont "play" with nunchucks.
First straight razor
Nice! I like the cube twist handle.
Next step in damscus
Everyone skins the cat differently i suppose. Not really. You just up your amps a little, make a puddle, and walk that puddle across each piece (or layer, in this case.) Bring your arc gap out a little bit more than usual too. Some guys use a circular motion, i always do more of a back and forth zigzag. Youre basically just melting a small section of the pieces together in a controlled way. With regular steel and stainless, its easy peesy, but aluminum tends not to like to cooperate with this technique. Usually each piece will create its own puddle and you have to "bridge" it with filler with aluminum. Is super easy with lap joints and butt joints, a little trickier with T joints. I would imagine fusing the corners on billets would work well too.
Grappeling Hook
Trailer house steel
I agree with Steve. Seems unlikely they would use such a high carbon steel in a trailer frame. They usually build trailers to minimum specs with cost and turnaround being #1 priority (in their minds.) Anyway, the mystery steel game is afoot. Same rules apply that always apply. If you got a piece to harden up pretty well then you have at least decent steel to work with.
Grappeling Hook
Jlp, what exactly is this training called? I ask because i have simply never heard of it before.
