billyO
551 -
Everything posted by billyO
Hey John. Do you get yours at Clay Arts or is there a place in Oly to get them? Hope to see you at Swaptoberfest (I should have some stabilized spalted maple burl for sale there....)
Nice looking knife, but I really like the 1/2 elk skull on the sheath. I need to get away from my go to sheath style and start learning how to carve leather. You may have just motivated me.
Sweet! Welcome to the pattern welded addiction....
Smithing after rotator cuff surgery?
billyO replied to bigb's topic in Blacksmithing, General Discussion
As a physical therapist for the past 22+ years, I'd say talk to your PT about not only your pain issues, but also what you want to get back to doing. If, after you say blacksmithing, your PT rolls their eyes and says you won't be able to, get another PT. If there aren't any tears in the muscles/tendons (what the rotator cuff actually is) then you may only have to modify how you stand at the anvil or swing your hammer. The problem with relying on general practitioner MDs is that typically, they only have 1 hour of musculoskeletal anatomy in school and no coursework in biomechanics. The problem with many orthopedic surgeons is that all they consider is surgery. I'm sure you've heard the saying, "If all you have is a hammer, everything looks like a nail." A good PT will have a thorough understanding of biomechanics, and movement and how to adapt and change your movement patterns to reduce inflammation, which is usually the cause of pain. You may have to modify your hammering, and it's possible your days as a striker may be limited. I'd try 3-4 different PTs before even considering shoulder replacement. Those have a horrible success rate, and I've known surgeons who consider a 50% recovery a successful replacement surgery. After re-reading the above, I'm not sure how much stock I'd put in this doctor. It would most certainly would matter if there was a tear. If there's a complete tear, you've lost one of the 4 muscles that holds the head of the humerus in the glenoid, and that would matter. I'd also suggest start icing the shoulder for 30 min a few times a day. Advil is an anti-inflammatory and ice is a great anti-inflammatory. Also, Advil is only one of a few different NSAIDs (Non-Steroidal Anti-Inflammatorie Drugs), and not all of them work for everyone (Cortisone is a steroid, a much more powerful anti-inflammatory). Advil is ibuprofen and that doesn't work for me. What works for me is Aleve, which is naproxen sodium, a different chemical. Another NSAID option is Aspirin, which works for some folks. -
I realize I'm late to the game on this thread, but folks who do pattern welded blades have been using instant coffee to stain the carbon steel after etching for years, especially with kitchen knives. It is NOT a durable finish, however and will rub off in time if care isn't taken. The nice thing is that you can just soak the knife again when you want a greater contrast. It's my understanding, however that the cheaper the coffee the better. I suppose this is possible, but the suggested tempering method for a 1080 steel for a kitchen knife is 400-450deg for two 2 hour tempering cycles. And after putting all that work into forging, grinding and heat-treating a blade, why would you want to risk a faulty tempering?
Looks great. Don't limit yourself too much. You can also do a twist pattern, and there are many variations on the ladder pattern. I've ground x's, checkered patterns, ladder grooves that only go up half the width of the blade, and you can combine the patterns. In fact, you may have just inspired me to do a widely spaced ladder pattern with raindrop holes drilled between the grooves....hmmmm...
I think most of us here would agree 100%. Keep up the good work.
Looks great! Welcome to the never-ending path of pattern welding. PCB etchant from Radio Shack is ferric chloride. I am currently using a 3:1 water to acid ratio. It's my understanding that most folks (myself included) will do a ferric chloride etch to get some topography to the blade before soaking it in the coffee. I've heard that the coffee "etch" is mainly a resinous buildup on the surface caused by the coffee. It rubs off fairly easily, especially if there is no topography on the blade. When you etch to get some topography, the coffee coats the carbon steel (the depressions made by the ferric chloride) and the nickle steel is higher in topography so that protects the coffee from rubbing off as easily.
Very nice! I'm liking the stand tool. I may have to start doing something like that for my damascus. I'm also liking that box elder. Almost as nice as my maple. as always peace and love billyO
Make a plan to head down to Longview for one of their Mentoring Center demos on the 4th Sat of the month (but you probably already know about them). At least plan on going down to Swaptoberfest. Stay cool! as always peace and love billyO
Show me your Bottle Openers!
billyO replied to Arbalist's topic in Blacksmithing, General Discussion
Are you talking about the texture or the contrast? If the physical texture is what you're referring to, then you merely need to etch it longer. The longer it's in the acid, the deeper the etch. If you're talking about the contrast, there are a couple different ways of helping this. First, etching longer (and deeper) helps prevent the oxides wearing/rubbing off. A chemical process called parkerizing is used a lot and is probably the most durable. A lot of smiths (myself included) use cheap instant coffee to improve the contrast. I etch my blades long enough so that I can feel the pattern with a finger nail (neutralizing the etch by dunking in boiling baking soda/water, then let it sit overnight before cleaning). Then I wet sand lightly with 5000 grit paper and a hard backer to clean off the nickle steel that has resisted the etch. Finally, I dunk the whole blade in a STRONG batch of instant coffee (the cheapest you can find). I used 1/2 a can to 1/2 gallon water, stored in the fridge and have been using it for about a year now. IMO, there's a "sweet spot" eventually you'll learn, of how long to keep your blades in where all you have to do is rinse off the blade well and have the contrast. Not long enough, you don't get enough dark. Too long and the worst that will happen is the 15N20 gets too dark and you have to scrub harder and usually will have to re-dunk in the coffee. The 2 best things about using coffee is that you really can't do any damage by keeping it dunked too long, and with my stabilized blocks, you can re-darken with the handle on and dunk the whole knife, handle and all. If you like the pattern, I'd re-etch in the acid, then try the coffee. Also, before use, you're sealing the steel with something, wax, oil, clearcoat, no? Have fun. as always peace and love billyO -
Some of my recent work - comment/critiques wanted (pic heavy)
billyO replied to billyO's topic in Knife Making
Nope, I made those myself. Pretty easy to do. Yep, A couple/few years ago I cut down a maple on my property, mainly for firewood and saw all the spalting. I did choose that tree because of the root burl. I've got another one a bit further back on my property with a 3' dia burl that I'm thinking about being my firewood tree this year. I just need to find an easier way than manual labor to get the wood up to the house. Thanks for the compliments all. as always peace and love billyO -
Thanks Dave! BTW - are you a member of the NWBA? If so, have we met at any of the conferences? -
billyO replied to Mark Ling's topic in Blacksmithing, General Discussion
I'm honestly not sure how it ended up fatiguing. Have I really been that rough with it over the last 18 years? I thought I had noticed it getting loose over the past few weeks and so the other day, took off the rubber collar and noticed the tube starting to tear (which was making the shifter loose), so I re-fit the piece and then used a pipe clamp to hold it on, but that only lasted 1/2 day before fatiguing completely and breaking. And yes, paying attention to how heavy this would be on your vehicle is a good idea. -
Hello all. Thursday afternoon, my stick shift broke while shifting into reverse (fortunately, I was at a friend's where we found a piece of pipe to get me home). Part of me wants to be ticked off that Dodge used a sheet metal sleeve to slide over a steel piece bolted to the lever into the transmission and looks like this finally wore out and tore (the right handed bend should be straight). The conflicting part recognizes that it it a 25 y/o diesel with 417K miles. So I decided yesterday that now was a time to do a project that's been on my mind for the past 5-6 years. Done out of 1" square. I'm a bit upset that I had to rush it to get it finished so I could drive last night, so it doesn't look as good as I'd like, but I may re-do it someday... Have a good summer. as always peace and love billyO -
Andy's pretty much back in filling orders, so I'd start trying and contact him.again.
Yes, the mentoring center is a great resource. I was the coordinator until health issues made me step back. I hope to get back there soon.
In answer to your initial question, no it is not necessary. Burning the tang in is the way it has been done, probably since the start of knife making. I know of some professional makers in the US that burn in the tang (and it's my understanding that many of the masters in Japan still do it that way). The benefits of epoxy is extra insurance and it can help seal the slot so water can't seep in. I've had the same problem in the past, and instead of buying large amounts of epoxies like West Systems g-flex, get some 30-60 min epoxy at your local hardware store that come in the tubes with the plungers, they last a while when stored properly and aren't as expensive, so if it does you're only out $3-4. as always peace and love billyO
And Jack, I hope to see you at one of the NWBA events in soon. as always peace and love billyO
To answer your initial question, a simple one turn twist of a piece of 1/2" square takes me about 30 seconds to do the twist, 20-30 minutes to heat the forge, a couple minutes to cut the stock to length, depending on which tool and if it's set up, a couple/few minutes to heat the stock, and about 10 minutes to locate the twisting wrench. To do a combination twist like you did takes significantly longer to make the twists even. Doing those 2 in 2 1/2 hours is a decent time, especially for someone who calls themself a newbie. A well known US author wrote that it takes 10,000 hours to become a master of most things. If you actually timed yourself, do a couple more of the same and you'll be surprised at how quickly the time drops. As stated above, doing one-offs takes significantly longer because even though you may have an idea on what you want it to look like, you are coming up with the method and order of doing things (this is more important than most newbies realize) on the fly, and I'd estimate that for 99% of the smiths out there, even though they have a clear idea on what they're shooting for, they don't get it right on the first heat and have to tweak things and often re-tweak them and that's always a "fun" challenge, depending on how much a perfectionist you are. There are many things that can cause this need, for example, as the piece retains more heat, the less you have to schwak/coax it (this is especially true with twists). And the more experience you have, the less you have to adjust what you're doing because you can anticipate the necessary changes you need to make to your manipulation of the steel. Pay attention to what you do and what happens with each heat and your time will start to decrease, but remember, there is only so fast one can go and even the experts have a lower limit. as always peace and love billyO PS - can you tell I'm part Italian?
Or if you belong to a black smithing group who has a fundraising auction, you could submit a bag for a smith who wants to look like they've been working to sprinkle around their anvil.... as always peace and love billyO
SLAG - not sure what you're interested in, but if it's a beginner's set, I packed up 7 sets today ready to ship. You can order through either his website or on line called 36Grit. If it's a specific pair of tongs or set, let me know and I'll see when we have those ready and let you know. Thomas - If it hurts, don't do it. There's only a couple of conditions where no pain no gain actually means something. Usually when someone doesn't do their rehab after surgery and let the soft tissue shrink, and wee need to stretch it out, because the patient didn't. As related to the shoulder, there's a condition called "Frozen shoulder" where the soft tissue in the joint shrinks/tightens and the PT's job is to stretch it out again. But even then, if there's no improvement after 6 or so weeks, then we stop and let it run it's course, usually resolving with as normal use as tolerated over a year or 2.
What weird animals have been in your shop
billyO replied to Glenn's topic in Blacksmithing, General Discussion
That one was 1 1/4" square stock. In my experience, animal heads up to 1 1/2" square aren't too tough. I'm almost finished with a husky out of 2" square, and not sure I'll do that again. It took 2 days of hammering just to get the pre-shape formed. But I guess I'm getting some good definition in my hammer forearm muscles.... Yes. Please do, I'd love to see it as well. -
Thanks for the compliments. I'm not sure I can explain in words how to do this, but I'll try. There's actually a couple of ways to do this, depending on the approach you take to the head. One way is to take a hot cut to peel a chunk of material off the parent stock from the back, then draw out the ear with a cross peen (you can see the hammer marks). Another way to get the mass needed is when you forge the pre-shape of the head, using a spring-fuller or guillotine tool to isolate the head from the parent stock, then use a fullering tool in a "scooping" motion with your blows to pull out the material, then use the cross-peen as above. The first way is much easier. For a better explanation, I'd suggest trying to get a hold of one of Darryl Nelson's animal Head DVDs. Either the bear's head or lynx head would show the basics for this. as always peace and love billyO -
Wow, I'm surprised I haven't added this one earlier "Ask 10 blacksmiths how to do something and you'll get 12 different answers." ~unknown as always peace and love billyO
