Everything posted by Jon Smith
A new dirk
Well yes that would be the obvious answer. The less obvious one would be that the parent wood was reclaimed, which would give the piece a lot of character and make it more of a conversation piece.
A new dirk
You do good work. I'm curious. What were you doing with a piece of 200 year old walnut?
- Anyone had forged Meteoric iron?
One Proud Bladesmith
Thanks for the advice gentlemen. And you're right, there's already several things I would do differently since then
Persian style subhilt fighter
*Drooling* Quick! Send it too me so I can hide it for before someone steals it!
Back in the Saddle
Name does ring a few bells... Or that could just be the echo from my anvil still bouncing around. Either way, good luck
Back in the Saddle
Whoa whoa whoa lets put the brakes on this wagon train for a second. Who's the new smiths in Eunice? I wasn't aware there were any metal bashers in town
First knife. Don't laugh.
I was thinking swages too, or make a knife out of normal rebar and just weld in a bit and make it San Mai
2 small integrals
Now I know I have engineering on the brain--I saw "integrals" and immediately started thinking of calculus.... Needless to say, I definitely like these integrals better. Wouldn't mind having one for a hunting knife
Knife Making
Do a search on here for the original etcher post, as its not my idea, but here's how it works. Take an old laptop charger and cut off the end that goes to the computer. Strip back the wires then separate the positive and negative. On mine, the negative was wrapped around the positive. Attach the positive wire (I attached alligator clips) to the blade and the negative to a cotton ball or q-tip dipped in salt water. To form the design, I coat the area I want to etch in nail polish then scratch the image into the dried polish with an xacto knife. Then, plug in the charger and apply the salty cotton to the design. It should start to fix and produce an acrid smell. About 30 seconds should do it. Reversing the wires will produce a darker mark. Then remove the polish and shine normally
Knife Making
The laptop charger etching system is the way to go. I use a bottle of my girlfriends old fingernail polish as a resist, but wax would work too.
chandelier
Nice job. Is that a church or a house?
blacksmith knife
Might still be a bit much...but if it looks like it'll hold the edge then you should be good. I normally go with a deep yellow/ light brown temper for an hour in the oven for 5160. Either way, welcome to the addiction that is bladesmithing
blacksmith knife
Love that crazy blade profile! What steel? Depending what you used, a blue temper (being somewhere around 475-550*) may be a bit much for an edge
Quenching in Oil vs Water?
5160 spring steel cracks badly in a water quench....trust me on that one. Lost a few good blades that way
pipe hawk
You're smoking tobacco...it's unhealthy to begin with. But then again, working a forge all day, especially a coal one, is bad for you too. Pick your poison I suppose. So long as there's no heavy metals involved to burn off, it should be relatively safe. Though I have heard that a metal pipe doesn't smoke the same as, say, a good briar. Not being a smoker, I couldn't say for certain.
- Blade from a ``fresh`` smith.
- What kind of file for knifemaking?
Guitar Strings
The smaller ones are perfect for colonial cheese cutters or something similar
The Bleeding Edge
Again, I may be wrong as I've never seen/worked with one in person, but a vertical forge would be set up similar to a normal gas forge (anyone ever try coal?) except that the chamber is oriented vertical with burners through the side. I would assume the reason being that long pieces of hot iron tend to bend under their own weight as you remove them from the fire in the normal horizontal orientation?
- Shreveport Louisiana looking for coal
- The Bleeding Edge
Oak burl
No there's no problem with it, and I have read through the ref materials. I was just wondering if anyone had come up with other methods/ materials that weren't listed. The whole vacuum/pressure thing kind of throws me for a true, deep stabilization.
Oak burl
I went ahead with the bag method and have it in a compressed two gallon ziplock in a dark corner of the shop. With it finally turning colder (below 75*) down south, it shouldn't get too hot. Which leads to the next step. Anyone have a good home process to stabilize this bad boy? I keep seeing the minwax wood hardener, but anything else that has good results?
