yesteryearforge
Everything posted by yesteryearforge
  1. Most band saws have blade welders on them Can you visit a local machine shop and have them weld it for you
  2. There is all kinds of oil industry in the area ( not sure if its in your area or not as you didn't say where your area is )
  3. I GOT ONE THAT LOOKS LIKE THAT ITS 560 LB BROOKS
  4. I have 3 five inch and one 8 inch post vises all mounted on square steel tubing 4 feet in the ground in concrete. Getting ready to mount another 7 inch one in the ground so only about 27 inches high to use as a striking vise. Willtake a cut wheel and cut a V in each jaw to form a square to hold hardy tools etc
  5. Actually the melting point of mild steel is higher than the melting point of cast iron
  6. Just buy a punch handle from lowes or home depot
  7. A pressure washer with the high pressure tip will clean a lot of rust and crud off of old tools saves a lot of wire wheeling and sanding ( not to mention the dust and mess involved )
  8. I have never attached an anvil to its base I have used various way to capture the base to keep the anvil from moving around or falling off its base wheter a stump ,boards or a metal stand. My vote is for a metal stand
  9. Although im a member I wont be able to make it to the conference
  10. You would be suprized what a pressure will clean up. Just be sure to blow it dry and re -oil / grease
  11. I have one that size but it has a full length leg ( long and slender ) Weighs in at 16lbs
  12. Nice job they Do look nice
  13. About 12 inmches tall with brass highlights .-
  14. Wonder what program they used in the middle ages ?
  15. Welcome to IFI Nice work space
  16. its main function was for de- burring parts like in a machine shop Not really very heavy duty unless you compare it to some of the junk sold at the big box stores now days.
  17. Nice dish The only thing that I can see it needs is MORE candy
  18. very nice
