Steve Sells
Administrators
    9,156
Everything posted by Steve Sells
  1. I collected it from various places when researching my second book.
  2. Being dyslexic can be annoying when trying to read fast, I just saw Monday Morning Update .... since he kicked off late last week Not getting info wrong is a challenge for me, glad I missread
  3. Chrome Vanadium, refers to the type of steel used to make the tool not the coating
  4. we all get that at times, dont worry about it until its happening all the time
  5. if it helps any, my first modem was 300 baud
  6. I was a programmer active at the start of AI with languages like Prolog. Things have moved a long way since then. Searching an established database went to programs building their own databases to make choices from, but its not the same as really thinking
  7. try adding a few small pieces of charcoal inside the foil to use up O2
  8. I would avoid the tap-cons, they dont do as well where wriggling is involved.
  9. Suggested heat treat for what thickness, most of those charts are for 1 inch or more thickness, which is why we have a separate area for blade HT, btw I relocated your post here because of that. Also be aware that some discount steel places, don't always ship out what your ordered, they substitute often for "close enough"
  10. leave the shank to blade part rounded, a sharp inner corner like that is a stress riser
  11. NO different processes just use clean charcoal
  12. Just a little for the future maintenance. Place a breaker number at each switch/outlet, this is in addition to the panel schedule, You wont remember after a very short time and it really makes it faster when you need to find it
  13. FYI in case of a 120/240v delta connection we use orange for the high (240v) leg, and some Installations like General Motors plants have their own color codes
  14. Just to humor Frosty: 120v colors red, black, blue for phases; white neutral, green ground, HI-volt colors brown, orange, yellow for phases; grey neutral, green for ground and pink and purple colors are used for travelers on switches
  15. That's what I was thinking Mike, but he says its running on 3 legs
  16. Are you sure it will work properly on single phase?
  17. So does a Desert Eagle unless you have forearms like JPH lol
  18. Having researched current prices and ballistics and availability of .40 .45 and 9mm, I have to go with the 9mm for my next. I am thinking of Sig p365XL, for ccw and definitely getting another Holosun for it, Love the one I have on another gun, and unlike the remeo zero series, I dont have to take it off the weapon to change a battery
  19. what is a p220? I have seen Sig 229 and 320 not a 220 tho
