March 14, 200917 yr Sask Mark, I ordered the book a few days ago and I am waiting for it to come. I'm kind of excited because they let me have the author inscribe it to me personally. Thomas, that makes a lot of sense. Thank you for that bit of insight. I will give that a whirl, or rather a bounce.
March 15, 200917 yr Jeff, If you want to check out my Hay Budden give me a call 753-4037. I'm not worried about posting my number as it is a public record.
March 15, 200917 yr HI My hay-b has big 111 on side & as it is mounted with silicone seal I can not see lowest inch of base. Hayseed
March 15, 200917 yr Can anyone help with the date of manufacture of my 100# anvil. The best I can tell the numers on the base are 8006 with possibly a fifth number. There is a number 0 under the horn. Thanks.
March 16, 200917 yr Hey Matt, sure, I would love to come by and check it out and see your set-up. I'll PM you with more.
March 16, 200917 yr Author Can anyone help with the date of manufacture of my 100# anvil. The best I can tell the numers on the base are 8006 with possibly a fifth number. There is a number 0 under the horn. Thanks. Could be as early as 1893 (if it's only the 3 numbers) with a 5th number it could be from 1902.
May 4, 200917 yr If anyone has time, trying to find out if my 138lb. HB #56672 was made 1899 or 1900? Also, a 74lb. ACME either #136302 or A136302 stamped in the same spot? Thanks, Dave
May 5, 200917 yr I have a HB 110lb, the number is A15942. I picked it up in a junk shop in SW Pennsylvania. Where is everyone finding the year of manufacture? Could someone date this for me?
May 8, 200917 yr I have 2 Hay Buddens. First is shop anvil ( 147 # ) and 2nd is trailer anvil ( 116 # ). Serials written down somewhere. You may find that Hay Budden was called the Rolls Royce of American wrought anvils. Kieth has a nice 175 lb in the Threshers shop.
June 4, 200917 yr Hello! Harv 'Coastie' Larabell here............just bought a 105# Hay-Budden off eBay for $250.00, located within 80 miles of my house....item number 190307236590 if you want to take a peek. Looks like S/N 31204 if anyone has an Anvils of America book would be neat to know the year. I've been using a piece of RR tie up till now although I also am really just a beginner. I have been 'collecting' for quite some time in anticipation of retirement which may be this October. I have a small coal forge with a Buffalo hand crank blower, a propane forge from 'Poorboy', A/C stick welder, small wire feed welder, oxy/ace set, a few hammers, chop saw, grinders and now a Hay-Budden Anvil........ and lots of Oak stumps to set em on! I was fortunate to have a neighbor for quite a few years that was an excellent Smith and he taught me the basics. On weekends I would watch out my back window for 'coal' smoke coming out of his barn then I'd grab a few cold ones and run over. He had an awesome power hammer that ran off an overhead belt, bout all I remember about it. Very glad I found this site and thank everyone for the wealth of information posted. I want to do a Rose next and I also have (60) RR spikes to do something with! Thanks all! Coastie
June 6, 200917 yr Looks like S/N 31204 if anyone has an Anvils of America book would be neat to know the year. The serial number 31204 would make it manufactured in 1897. Nice anvil.
September 7, 200916 yr It has the serial # 157227 on the left side of the front. One side of the anvil has VVM Hora 1914. It does not say Hay Budden but I was told they manufactured under different names/logos. Thanks!
September 8, 200916 yr Unless I missed it mine does not have a S/N. It is marked 135 the bathroom scale showed it at 134. It looks like it was an outside anvil so the S/N may just be hidden.
September 8, 200916 yr 148# made in 1918, the top half is tool steel, the base is wrought, welded together.
September 8, 200916 yr I have two Hay Buddens. The one I use the most is a 120 lb, serial # 12320, The other 57 lb, serial # 17192. 312320
September 9, 200916 yr The serial number would be on the front of the foot underneath the horn and they often suffer from rusting there.
September 10, 200916 yr 200 lbs. A20457 just paid $ 2.25 a lb. for it in L.A. Okay, I'm confused...Once they changed to the "A" designation, they didn't return to the none "A", did they? So how is the aformentioned 31204 date from 1897 if my A20457 is from 1895?
September 10, 200916 yr They switched to the A designation later on. I can't remember the exact date. I'm pretty sure your anvil wasn't made in 1895. I can look up the correct date in Anvils in America when I get home tonight if someone doesn't beat me to it.
