Double Y Posted June 9, 2015 Share Posted June 9, 2015 I saw a Craigslist add for a roller last week. It was powered and seemed like a nice smaller roller. As soon as I inquired about the roller, it was pulled down. However, the guy sent me a message he had another roller. He said it was an older manual one.I couldn't make it over until yesterday and found this gem.This Barth says its capacity is 16 gauge and is built like a tank.The piece I rolled is 10 gauge and was just a test piece. This will be a dang handy addition to the shop. Quote Link to comment Share on other sites More sharing options...
Double Y Posted June 9, 2015 Share Posted June 9, 2015 something funny is happening with this thread... Quote Link to comment Share on other sites More sharing options...
Gergely Posted June 12, 2015 Share Posted June 12, 2015 Just trying to do what Iron Dwarf did last time. Quote Link to comment Share on other sites More sharing options...
Gergely Posted June 12, 2015 Share Posted June 12, 2015 Yepp, it was jammed again. Last post was on page 169 but somehow it looked like it would be on p. 170. And that page didn't exist.Anyways, todays score was a couple big leaf springs, nothing special...BestsGergely Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 14, 2015 Share Posted June 14, 2015 I went to pick up some coal from a guy who is moving couldn't take it all with him and these two items along with some steel that isn't pictured followed me home. He is holding the hood and chimney for me because it wouldn't fit in the van with the coal and everything else! Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 14, 2015 Share Posted June 14, 2015 Good score!Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
ausfire Posted June 14, 2015 Share Posted June 14, 2015 Some nice ideas in his shop too. I like the leather (?) holders for the hammers etc. I'm guessing the heavy chain round the anvil waist is to stop the ring? What are the things in the white block? Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted June 14, 2015 Share Posted June 14, 2015 That is a heavy duty wire brush. They have flat bristles instead of the usual round ones. Quote Link to comment Share on other sites More sharing options...
Quarry Dog Posted June 15, 2015 Share Posted June 15, 2015 And they tear the scale off almost as well as a hot rasping session. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 15, 2015 Share Posted June 15, 2015 You can buy them for less than official "blacksmith tool" prices at a butcher supply. Butcher block brushes.Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 15, 2015 Share Posted June 15, 2015 Good score!Frosty The Lucky.Thanks! Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 15, 2015 Share Posted June 15, 2015 Some nice ideas in his shop too. I like the leather (?) holders for the hammers etc. I'm guessing the heavy chain round the anvil waist is to stop the ring? What are the things in the white block? Thanks! Yes, they are leather straps that I cut from a piece of belly. The heavy chain around this particular anvil does help minimize the ring. It's an 82 lb Hay Budden. Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 15, 2015 Share Posted June 15, 2015 And they tear the scale off almost as well as a hot rasping session.I got it to remove scale off of stock that I'm forging but should I also use it on the anvil? Those bristles are VERY stiff and I'm not sure that I want to be scraping my anvil faces with it. Should I scrape the scale off the anvil with it between heats, or continue to use the wire brush that I've been using? Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 15, 2015 Share Posted June 15, 2015 Naw, no need to use the brush on the anvil, you can just sweep the scale off with a GLOVED hand and don't worry, that brush doesn't stand the chance of a fly in a bonfire of damaging a Hay Budden.Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 15, 2015 Share Posted June 15, 2015 Thanks for the reply and I understand why the GLOVED hand. Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 15, 2015 Share Posted June 15, 2015 Thanks for the reply and I understand why the GLOVED hand.Discovered that early on too? I only had to brush fresh scale off the anvil once to learn that one. Pain is a one lesson teacher. A wire brush is just fine it isn't going to hurt the anvil, not a bit. I keep a stainless wire brush on the table with the butcher block brush to get into the little nooks and crannies so I grab it to brush the anvil off if I don't have a glove on.Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Quarry Dog Posted June 15, 2015 Share Posted June 15, 2015 I've never noticed that the wire brush does harm to the anvil, but I do know that it chews the scale off of the work without shaving it down. Hot rasping works pretty well in a vice too, and the rasp side will really shave things down fast. An added side effect of hot rasping that I've noticed is that if you keep going around your work with the right amount of pressure for the thickness you can get very straight and true. Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 15, 2015 Share Posted June 15, 2015 Discovered that early on too? I only had to brush fresh scale off the anvil once to learn that one. Pain is a one lesson teacher. A wire brush is just fine it isn't going to hurt the anvil, not a bit. I keep a stainless wire brush on the table with the butcher block brush to get into the little nooks and crannies so I grab it to brush the anvil off if I don't have a glove on.Frosty The Lucky.Well, something like that. A piece of still black coal popped out of my forge and being that the thought of wasting coal causes me to cringe I foolishly picked up the BLACK coal and learned very quickly to always remember what I'm working with! Quote Link to comment Share on other sites More sharing options...
SpankySmith Posted June 15, 2015 Share Posted June 15, 2015 I have that EXACT same brush but I seldom use it, it leaves scratches on my material. Does a fantastic job with scale but I can't live with the scratches. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 15, 2015 Share Posted June 15, 2015 Well when I went up to visit my wife, repair the house and drool in my shop; I found that I didn't have the right material to hand for the repairs and so had to go visit the scrapyard---BWAhahahahahahahahahahahahahahahahahahahaha. Unfortunately I was at low ebb on my allowance. I had 57 pounds of stuff; both required and "spec" and so came in right below my cash on hand limit of US$12 (20 cents a pound) and then I saw a largish cast iron ball with a hook on it. Being in the SCA for the last 37 years or so I know that armourers have a veritable lust for such things so I asked if it was for sale...their reply that not only was it for sale they had been holding it for me. (Perhaps because I had bout 6 of them at one time previously...) Luckily I had brought my change bottle and was able to count out $18.40 in change to go with the $3 I had left from buying the "needed" stuff.So besides the 3'x8' piece of galvanized sheet, I picked up a nice 4" "adjustable" C clamp, (always take the time to dig in the "garage clean out" stuff as for some reason folks will junk perfectly good tools!!!). About 20" of old rock drill---good for blades especially as the old stuff tends to be a straight high carbon steel. Some strapping in convenient sizes for an upcoming fork class at an SCA event. Some utility pole hardware---my new rental has a carport built from 6 utility poles and so having some hardware to fit in the already present holes makes a handy place to hang stuff---like a hammock. Some misc steel that looked like it might be handy and a 107 pound cast iron ball with a steel hook protruding from it. (Possibly a dock weight---but here in the desert???) Also a lovely if hot morning at the scrapyard and the "warm" feeling that they are thinking about me---even if it's a "Push that to the side, that feller with the disreputable red hat is sure to buy it next time he comes in, the idjit!" Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 17, 2015 Share Posted June 17, 2015 I went to buy the Box Jaw Tongs in the middle and the other 10 items followed me home! All 11 items, whose condition ranges from great to excellent (except for maybe the two slitting chisels, they are in good condition) for $140. Quote Link to comment Share on other sites More sharing options...
stan Posted June 17, 2015 Share Posted June 17, 2015 Great looking quality tools at a great price , I wish. Quote Link to comment Share on other sites More sharing options...
Anthony San Miguel Posted June 17, 2015 Share Posted June 17, 2015 I met the guy who sold them to me when I first took an interest in smithing, about 8 months ago. He is no longer interested in blacksmithing so he sold them to me at a good price. I am really excited about this score! They are all Pieh Tools, Blacksmith's Depot, or Centaur Forge tools. Some still have the stickers on them! Quote Link to comment Share on other sites More sharing options...
Wayne Posted June 17, 2015 Share Posted June 17, 2015 This little load followed my back the other day, one vice is missing the spring and fixings and the beam drill is missing its handles but that can be fixed Quote Link to comment Share on other sites More sharing options...
divermike Posted June 20, 2015 Share Posted June 20, 2015 (edited) Had the chance to go to a local flywheelers swap meet last saturday, picked up these two beauties, prolly will sell em as I have one already. Both need springs, offers by PM if you are interested, or my pm Edited June 20, 2015 by Glenn Quote Link to comment Share on other sites More sharing options...
