Kanca 50(110lb)
I grabbed a Kanca 50 anvil on sale as I've heard good about their vices before purchase i tested rebound with a 3/8 bearing ball and its good 80-95% at $800 i thought it wouldn't be a bad grab as I've seen no old anvils locally.
brought it home and tested it with a small ballpeen starting about 4 inches and light blows there are visible marks in the face (images left large to see) and a 800G hammer was flattening the edges while taking small nicks to the face I'm trying to decide if i should return it and wait for something better or use this it is definitely forged top, 2 pieces and welded together. Base may be cast
M.J.Lampert
IMG_0486.thumb.JPG.24a22c38686ef9bd69f1e802d3d18937.JPG IMG_0493.thumb.JPG.ef40c60657472552fe250ca0ac78c590.JPG IMG_0496.thumb.JPG.47ea28badfccea9568d9a92772c11781.JPG
Edited by M.J.Lampert
photo sizing
If the rebound with a ball bearing was good I would trust that over a hammer. To me the marks on the face appear to be more like scratches than dents. They're nothing I would worry about anyway. I wouldn't be surprised if only the face is induction hardened and the horns are still soft.
That being said I have read here that the hardness of the face of Kanca anvils can vary substantially from one to another. The million dollar question is is it better than what you have now? And perhaps, do you still like it? You're the one who will be using it after all.
Do you have a good magnifying glass? The marks on the face may just be the finish machining marks being flattened on the high spots. This would be pretty normal even for hardened steel if it was ground after heat treatment.
The little chips in the edge is why you try not to strike the edges with the hammer, let along "light" taps with a 800gm hammer! I realize you're young but please try to get the, "if a little is good a LOT is better," out of your game bag! an 80gm ball pein would've told you all you needed to know without damaging anything.  The same thinking has people actually RECOMMENDING a 1" bearing ball for a rebound test and guys are dropping them from 3' I've read about a couple few who climbed ladders so they could drop them from 10'.
It's small wonder Centaur refuses to honor the warranty on an anvil tested with a bearing.
Wood stump? Forge some staples, bend over some large nails, RR spikes, some fancy strap contraption, etc., etc.. EZPZ.
Frosty, what are your thoughts on a cannon that fires 1" ball bearings? With a well positioned chronograph we could determine it's velocity before it hits the anvil and again on its return journey!  It occurs to me that it might be best to fire our cannon remotely. The rebound off the old noggin is probably pretty low and not worth measuring.... Though, I have been told I can be hard headed...
(Note for MJ, I'm not poking fun at you. My imagination is simply running away with me)
thanks i will take a magnifying glass out and look
oops I'm slightly more brawns than brains:ph34r: (at times)
I've learned that from you in a separate thread and now my edc includes a 3/8 bearing ball and I'll drop from 10in beside a tape measure
Frazer, I've been told similar (bull headed) and at times i can be rather thick skinned
PS I don't see how that was poking fun at me
MJ, what I have used on my Peter Wright (which has steps on the feet under the horn and heel) are two pieces of angle iron with holes drilled in them over the steps and 4 lag bolts through the holes into the stump.  It has worked well for over 30 years.  They are easily removable if necessary, unlike staples pounded into the stump.
M.J.  my Kanca had a thick layer of clear coat on the face. It was very hard to remove with a cup brush. Have you removed the clear if it came with any?  You will get better rebound afterwards
My Kanca seems very hard to me. It has %95+ rebound in the sweet spot and has barely any marks after three years of weekends
I have heard of soft ones however, maybe I got lucky.  I have been happy with mine -
P.S.  thats a good price. About what I paid, with shipping, 3 years ago
i will see if there is any coating on it
i found similar rebound across the face varying at most 15% IMHO
M.J.Lampert
looking at stand designs on the dedicated thread sadly the first 2 hands of pages are short on images Show me your anvil stands - Page 35 - Stands for Anvils, Swage Blocks, etc - I Forge Iron
looking at this one https://www.iforgeiron.com/topic/51596-show-me-your-anvil-stands/?do=findComment&comment=519256
also like this design https://www.iforgeiron.com/topic/51596-show-me-your-anvil-stands/?do=findComment&comment=469929
 both would work well as my anvil has no good point to tie into many others to sort through before i decide
finally i see a lot of anvils have extra chain wrapped around I've hear that this reduces the ring, is this true?
M.J.Lampert
Not enough 2 week bruises or shed blood. Mostly I stopped moving fast around the anvil's horn unless I'm working on it. About the third time I nailed myself to an anvil horn they became positively fascinating. I always seem to be aware of the things. That was before Iforgeiron and I still remember it like yesterday. Bruised clear to the bone. <shudder>
A sharpish bic is a good thing.
