Caballo bueno Posted December 25, 2021 Author Share Posted December 25, 2021 How wide and long could it be? Quote Link to comment Share on other sites More sharing options...
Glenn Posted December 25, 2021 Share Posted December 25, 2021 The fire, fuel, and use will determine the size of the crater. Use only as much gentle air as is needed to get the heat that you need for the metal you are working. You can only work 4-6 inches of hot metal before it cools off and needs reheated. Quote Link to comment Share on other sites More sharing options...
Caballo bueno Posted December 25, 2021 Author Share Posted December 25, 2021 I can put a pipe in the 40 mm shaft, but I don't know what measurements to give the crater to heat pieces like 4 mm thick bars, etc. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted December 26, 2021 Share Posted December 26, 2021 So use a JABOD and experiment with the crater size till you get one that works just right for *you* and your setup! Once you find a good design you can work on reproducing it in a bit more durable fashion. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 26, 2021 Share Posted December 26, 2021 Caballo, mi amigo. You keep asking us for specific sizes for a forge that is intended to be easily changed to suit the work. As Thomas just said, build a JABOD and experiment until you discover what works for YOU. I have ZERO idea what YOU need to work 4mm stock, I could have my way with it using a fire about the size of a tea cup. I think of 4mm. almost being wire. One of the beauties of a side blast forge is how easy they are to change. You REALLY need to stop asking questions we can't really answer, build one even if it's wrong and start using it. You'll learn what works from using it. There really isn't any other way. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted December 26, 2021 Share Posted December 26, 2021 Sorry I’m not up to date on my conversions but isn’t 4mm close to 1/8”? you could probably forge that size stock in just about any size fire, even just a small camp fire with a good bed of coals outta get you up an running in minutes! I saw a picture of a member on here forging or repairing log tongs if I recall correctly? He was out in the forest Using a log for an anvil and a camp fire to heat the steel and it was a lot bigger than 4mm! anyways my point is that I agree with everyone else, all ya gotta do is start a fire, stick some metal in it, and then you will know very quickly what works best for you! Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 26, 2021 Share Posted December 26, 2021 That was me, I used a mattress inflater, piece of pipe and a piece of log for the anvil. It took maybe 2-3 minutes to bring the log tong to orange. I didn't have a trench or fire back, just a fire and air blast. It wasn't a proper forge but it did the job. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted December 26, 2021 Share Posted December 26, 2021 Shhh Jerry! I know it was you, I was leaving it a mystery on purpose, that way everyone would start wondering who actually did that! an go looking around the forum for the picture and story Lol, anyways my point was that if you could forge log tongs in just a camp fire, then it probably doesn’t really matter what size fire he starts out with to forge 4mm stock, just start a fire an get forging! Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 26, 2021 Share Posted December 26, 2021 I didn't "forge" them I just re-shaped one hook I'd straightened out. I've used that example and pic so often I'm getting tired of posting it. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted December 26, 2021 Share Posted December 26, 2021 (edited) On 12/26/2021 at 10:36 AM, Frosty said: That was me, I used a mattress inflater, piece of pipe and a piece of log for the anvil. Is your matress inflater to noisy? I used today ine I had troublr rven with headphones on and hed to unplug it every now and then and they can suck air fire too if you switch it counter clockwise mine is this pump Edited December 28, 2021 by Mod30 Trim quote. Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 26, 2021 Share Posted December 26, 2021 It's louder than a bellows and has an annoying whine to it. I'm not bothered by loud machinery as much as most folks though, I've been running loud machinery my whole life. My single outlet T burner forge is so loud, sometimes people step out of the shop to be understood while shouting at each other. People who burn coal or charcoal tend to hate how loud propane forges are. That's one reason I was so delighted when I got NARB to work, it's very quiet. Quiet is nice. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted December 26, 2021 Share Posted December 26, 2021 what is narb frosty? Quote Link to comment Share on other sites More sharing options...
JHCC Posted December 26, 2021 Share Posted December 26, 2021 Naturally Aspirated Ribbon Burner. See this post: Quote Link to comment Share on other sites More sharing options...
Frosty Posted December 27, 2021 Share Posted December 27, 2021 Naturally Aspirated Ribbon Burner, is a propane forge burner. I tinkered around and copied some existing devices adapted to use a T burner and darned if it didn't work WAY better than I expected. You can read the whole story of what I did and just how silly happy I was with how it turned out. I still have trouble believing it works so well. In the thread, "Naturally Aspirated Ribbon Burner Photo Heavy" I think it's been pinned in the gas burner section. Below is pic of the NARB forge at it's first public appearance at a local club meeting. You can see the propane flames, lots of little flames. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
natkova Posted December 27, 2021 Share Posted December 27, 2021 I just saw great thread. About topic 4 mm is realy thin i can heat it in my stove You shoul look something about 10mm or 15 mm so you can heat max 20 mm it will be around 1 inch. Quote Link to comment Share on other sites More sharing options...
Caballo bueno Posted December 27, 2021 Author Share Posted December 27, 2021 They are not 4, they are 40 mm of the diameter of the tube through which the air comes out to the stove Quote Link to comment Share on other sites More sharing options...
Caballo bueno Posted December 27, 2021 Author Share Posted December 27, 2021 what is a jabod? Quote Link to comment Share on other sites More sharing options...
LeeJustice Posted December 27, 2021 Share Posted December 27, 2021 Just A Box Of Dirt. Many posts on here regarding that. https://www.iforgeiron.com/forum/267-jabod-just-a-box-of-dirt/ Quote Link to comment Share on other sites More sharing options...
Caballo bueno Posted July 29, 2022 Author Share Posted July 29, 2022 Hello? Quote Link to comment Share on other sites More sharing options...
George N. M. Posted July 29, 2022 Share Posted July 29, 2022 Hello, yourself. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 29, 2022 Share Posted July 29, 2022 We're still here. Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 30, 2022 Share Posted July 30, 2022 If you have ore questions ask, we haven't gone anywhere. If you'd just like to talk with the gang speak up, we're a pretty friendly bunch. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted July 30, 2022 Share Posted July 30, 2022 Most of us don’t bite. Those that do, the moderators insure they are vaccinated! Quote Link to comment Share on other sites More sharing options...
Frosty Posted July 30, 2022 Share Posted July 30, 2022 Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 31, 2022 Share Posted July 31, 2022 Some of us are even boosted! (Others are going on toothless.) Quote Link to comment Share on other sites More sharing options...
