dawson f Posted May 17, 2019 Posted May 17, 2019 so i,m having a hard time deciding between a belt sander or a air hammer to flatten out the steel. some opinions on which one i should get would be very helpful Quote
Daswulf Posted May 17, 2019 Posted May 17, 2019 Whatcha making? Those are two totally different tools for different uses. Quote
dawson f Posted May 17, 2019 Author Posted May 17, 2019 well i'm planning on being a blacksmith and i'm trying to decide whether i'd rather do all the shaping by hand, or do all the grinding with a rotary tool. both tools would save me a lot of time but i'm on a pretty tight budget. Quote
Steve Sells Posted May 17, 2019 Posted May 17, 2019 shape what, and grind what with what rotary tool? Quote
pnut Posted May 17, 2019 Posted May 17, 2019 Blacksmithing usually is considered hammering hot steel. You use a grinder for finishing. Pnut (Mike) Quote
dawson f Posted May 17, 2019 Author Posted May 17, 2019 shape out the metal to get it the size and dimensions i need. grind out ruff areas and make the edge. the rotary tool is a dremel 3000. sorry if i'm not very specific. Quote
Steve Sells Posted May 17, 2019 Posted May 17, 2019 "the metal" is not telling us anything, and a dremel isnt doing anything for working on a cannon, but will be nice for cleaning up Chess pieces so to answer your detailed question: Get the thing to make the metal look like you want Quote
pnut Posted May 17, 2019 Posted May 17, 2019 You need to do both. Hammer and grind. I thought you were asking about a belt grinder or air hammer. On a tight budget either might be out of reach. How much experience do you have with belt grinders or air hammers? I'm not sure where Hart Co is but If you get up to Grant Co I'd be more than happy to help you out any way I can. Pnut (Mike) Quote
dawson f Posted May 17, 2019 Author Posted May 17, 2019 thanks, pnut i have a small amount of experience with belt grinders but have no experience using air hammers Quote
pnut Posted May 17, 2019 Posted May 17, 2019 If you don't know what you're doing an air hammer can be dangerous. If you're just starting to get into smithing just focus on learning proper hand hammering technique. That's difficult enough without making it more complicated than need be. I looked up Hart Co. I have a sister in Hardin Co by Ft. Knox. If I visit her anytime soon I'll let you know. Pnut (Mike) Quote
Daswulf Posted May 17, 2019 Posted May 17, 2019 Do you have Hand forging experience with hammer and anvil? Because a power hammer is just an extension of that for working larger stock or working stock faster. If you have no hand forging experience then there is a lot to learn and mistakes will happen faster and worse with a power hammer. Quote
dawson f Posted May 17, 2019 Author Posted May 17, 2019 thank you i guess i should work on my hammering technique ill get the belt grinder and it would be very educational to talk with someone with more experience well daswulf i have a little bit of hand forging experience but not much Quote
pnut Posted May 17, 2019 Posted May 17, 2019 Look for a blacksmithing group or classes near you. You'll learn more and learn faster than trying to figure out on your own or by watching YouTube videos that might not be good info to begin with. Nothing beats in person face to face learning. Pnut (Mike) Quote
dawson f Posted May 17, 2019 Author Posted May 17, 2019 i'll do that thanks everyone for the info Quote
Eventlessbox Posted May 17, 2019 Posted May 17, 2019 Dawson, Blacksmithing shapes steel into everything from tools, to chandeliers, to gates, to statues, to swords and knifes, to small delicate jewelry. And the tools required vary just as greatly.. If you were making gates and large pieces an air hammer would be helpful, knifes a grinder, statues a good welding rig. Ect. It's not possable to be specific in an answer for you without knowing which facet of the craft you are going to focus on. Quote
dawson f Posted May 17, 2019 Author Posted May 17, 2019 i'm making knives preferably but i may end up doing other things later down the road. Quote
Latticino Posted May 17, 2019 Posted May 17, 2019 IMHO the most helpful tool for knifemaking is a belt grinder, ideally a 2 x 72, so you are likely on the right path there. Be prepared though, abrasives are expensive and to work efficiently you will need a lot. Quote
Cedar Crest Forge Posted May 18, 2019 Posted May 18, 2019 5 hours ago, Latticino said: abrasives are expensive Usually. I have some tricks to avoid the worst of that. He sounds like he should just find a teacher ( learn in someone else's shop), until he figures out what he needs or wants. It is easy to spend 1000$ in a belt sander setup, and those box store belt sanders just don't cut it. Actually, as a first electric tool, how about an angle grinder? Cheap, effective, versatile. Cuts, flattens. I've even used it to bevel the cutting edges of two handed Halberds. Fun times. Quote
ThomasPowers Posted May 20, 2019 Posted May 20, 2019 At this stage I would say: Neither; work on learning to forge and how to draw file blades. Keep saving money and perhaps when you are at the stage to profit from them you can buy both! Quote
Buzzkill Posted May 21, 2019 Posted May 21, 2019 If you want to start making knives right now then go with the grinder and make knives solely by stock removal at first. Buy known stock close to size and just grind away everything that isn't a knife. That will help you learn some of the skill sets needed to make a good knife. In the meantime you can spend some time at the forge learning how hot steel moves under the hammer and how to get the shapes you want. If you try to learn forging, grinding, heat treating, and finishing knives simultaneously you will probably experience a fair amount of failures which can be discouraging. If you are willing to take your time and perhaps not produce a good finished blade for a few months or more then I would agree with Thomas as well. Quote
swedefiddle Posted May 22, 2019 Posted May 22, 2019 Good Morning, Dawson Start by learning how to Forge by hand Hammer. If you start with a Power Hammer, you are going to have a huge pile of RUBBISH. A Power hammer does'nt teach you how to control what you are doing. To get the benefit from a Power Hammer, you need to know how/what Hand Control is first. To start, you need to get to 1st base first!!! Blades come later, after learning how to Forge, first. Neil Quote
Cedar Crest Forge Posted May 22, 2019 Posted May 22, 2019 If you really want to flatten the steel with precision, as a professional knifemaker, use a surface grinder. You can buy an old industrial one, to save money. To take it to the next level, you can replace the grinding wheel with a 2x 72 belt design, so you can mix and match belts to your 2 x 72 belt sander. As a hobbiest, you don't need any of that to get started. Quote
ThomasPowers Posted May 22, 2019 Posted May 22, 2019 Of course having a proper stop block on a powerhammer can help a lot too; or getting good at adjusting your rolling mill. Quote
jason0012 Posted October 12, 2019 Posted October 12, 2019 Look up kentucky forge council. They meet in bowling green- not too far from you. If you are on a tight budget, try a grizzly grinder (2x72). It is one of the best deals on grinders ( not the best grinder , but a good start). A power hammer is a pretty big leap from hand forging, and no small investment in space, time and money. Get comfortable forging by hand, then add power tools. You will get a better idea what you need that way On 5/17/2019 at 8:22 PM, Cedar Crest Forge said: Usually. I have some tricks to avoid the worst of that. He sounds like he should just find a teacher ( learn in someone else's shop), until he figures out what he needs or wants. It is easy to spend 1000$ in a belt sander setup, and those box store belt sanders just don't cut it. Actually, as a first electric tool, how about an angle grinder? Cheap, effective, versatile. Cuts, flattens. I've even used it to bevel the cutting edges of two handed Halberds. Fun times. I would agree. It is pretty easy to spend $1000+ on belts. Quote
