July 27, 20178 yr Well it looks great.. Really nice work and great attention to detail.. Have a chance to use it yet?
July 27, 20178 yr Not yet. I figured I'd work on my other Anvil while my shop is a mess from the latest project before getting going on a metal project. Ive also been picking up tongs & hammers so I'd have some starter tools.
July 27, 20178 yr You just like to BE in your shop? Right there with you Brother though you're is awfully clean though a little blacksmithing will fix that right proper. Frosty The Lucky.
July 28, 20178 yr The stand I use for demonstration, 109lb HB, bolt-clamped down ( I didnt drill the holes they were there when I bought it) my own variation on the hold down, foot lever you can lift with you toe and hold down with your foot for fairly strong clamping, in the middle of the linkage is a one way slip joint like on a hog catcher (works like a snare) so you can slip the hold down, up far enough to grip 1/4" stock or 2" stock then apply pressure with you foot while you heel is still planted on the ground. Dont want to be punching or chiseling with an unfirm footing, no point in holding the stock real still if your balancing on one foot yourself. Made from white oak and ash, should be heavier for stability, but when it was built 10 years ago I needed to be able to travel "light" fit the forge kit and tenting gear and fuel in a normal car so the stand also served as a box to house tools while in transit. Still use it all the time even in the shop for the hammer rack, hold down, and quietness of the anvil, heavier work goes to my bigger anvil on a stump
July 28, 20178 yr Made of old crossties (i hope, that's the correct word for it). I added some layers of tar paper between anvil and stand. Due to the size of the anvil i don't need any extra tool rack or so On the right side you can see the support for my hold down.
July 28, 20178 yr Ooh, that's a beast! How much does it weigh? By cross ties, do you mean the timbers that support rail road rails? I agree, you have enough room for tools . . . and DINNER! Beautiful anvil, now I'm feeling anvil envy. Frosty The Lucky.
July 28, 20178 yr 2 hours ago, Frosty said: By cross ties, do you mean the timbers that support rail road rails? That's what i mean. The beauty weighs 400kg (about 882 lb). It's been quite a challenge to get it on the stand
July 28, 20178 yr 2 hours ago, c.baum said: That's what i mean. The beauty weighs 400kg (about 882 lb). It's been quite a challenge to get it on the stand Please post a face shot with a ruler or measuring tape.. Nice stand for sure.. 7 hours ago, woodsmith said: The stand I use for demonstration, 109lb HB, bolt-clamped down ( I didnt drill the holes they were there when I bought it) my own variation on the hold down, foot lever you can lift with you toe and hold down with your foot for fairly strong clamping, in the middle of the linkage is a one way slip joint like on a hog catcher (works like a snare) so you can slip the hold down, up far enough to grip 1/4" stock or 2" stock then apply pressure with you foot while you heel is still planted on the ground. Dont want to be punching or chiseling with an unfirm footing, no point in holding the stock real still if your balancing on one foot yourself. Made from white oak and ash, should be heavier for stability, but when it was built 10 years ago I needed to be able to travel "light" fit the forge kit and tenting gear and fuel in a normal car so the stand also served as a box to house tools while in transit. Still use it all the time even in the shop for the hammer rack, hold down, and quietness of the anvil, heavier work goes to my bigger anvil on a stump That there is a nifty stand.. Something like that made out of heavy plate steel would be handy.. I love foot hold downs.. Really nice design..
July 28, 20178 yr 1 hour ago, jlpservicesinc said: Please post a face shot with a ruler or measuring tape.. Do you need any specific information? The face is about 195mmx890mm incl. horn, hardy 44x44mm. I'll post a photo.
July 28, 20178 yr 2 hours ago, c.baum said: Do you need any specific information? The face is about 195mmx890mm incl. horn, hardy 44x44mm. I'll post a photo. Thank you.. I just love to see the overall package.. I love you guys have these huge anvils there..
July 28, 20178 yr Main line ties in America and Canada are 8" x 8" but I don't know about Germany. Regardless it's BIG. If a person isn't very organized, all bins, racks, etc. do is add something you have to organize, I have lots racks, bins, tool chests, etc. cluttering up my shop. <sigh> Uh HUH, the lady says size counts but we knew that all along didn't we boys? Frosty The Lucky.
July 29, 20178 yr On 28.7.2017 at 4:51 PM, Scrambler82 said: Is this anvil posted in the "Show me your Anvil" Thread; I would like to know more about it, please ?it Yes it is. in german it is "steirische Form" (styrian shape?). Largest anvil you can by on the market as far as i know. It's been used in a smithy in a salt mine where usually tools were made. See the mentioned thread for the story how it followed me home (i wish it was that easy ). On 28.7.2017 at 4:51 PM, Scrambler82 said: From the side view picture, there are no blemishes on her ! oh, there are some tiny ones. seems it has been used as a cutting and welding table. And the corner on the far side has a lot of chips. On 28.7.2017 at 4:51 PM, Scrambler82 said: Your Stand is great, if Ties are 8" x 8" that puts the base of the anvil around the 40" x 24" mark... holy ---- ? the base is about 730 x 470mm. The ties are about 230x150mm, but a good friend dressed them up on the planing bench. Don't know the original dimensions. On 28.7.2017 at 4:51 PM, Scrambler82 said: things organized, if someone is not an organized person or an Engineer engineer
July 29, 20178 yr Why is there something about large anvils? What makes me see this beast and be like.. Ooohh.. It's so big.. I want one.. Mind you some Jimmy choos will do it to but on a different level..
July 29, 20178 yr I explained it a couple of decades ago as "Anvil Envy" a terribly Freudian condition that many blacksmiths suffer from. Most common treatment is finding bigger anvils. When I got my 515# anvil I was able to go from acute to a low grade chronic case myself.
July 29, 20178 yr I've said it before... organized people are just too lazy to look for stuff. I usually find what I'm looking for in the last place I look.
July 29, 20178 yr I find that if I just put my small tools in my pockets they are easy to find---till my pants fall off; or my wife finds them in the washing machine and then my aerobic exercise period of running for my life starts!
July 29, 20178 yr 1 hour ago, ThomasPowers said: I explained it a couple of decades ago as "Anvil Envy" a terribly Freudian condition that many blacksmiths suffer from. Most common treatment is finding bigger anvils. When I got my 515# anvil I was able to go from acute to a low grade chronic case myself. And I didn't even make an offer on a 1,200lb. Fisher just because I lived in a trailer court and didn't have anywhere to put it. There was a lot of tooling in that shop I didn't make an offer on, pity I wasn't living here then. Frosty The Lucky.
July 29, 20178 yr I'd have used it for a pillow! but a trailer couldn't stand the weight I know... I know a couple of people with 750# wests including one who was *given* it in good shape!
July 29, 20178 yr 46 minutes ago, Scrambler82 said: I have to go around twice, sometimes, and then I find it where I looked a minute ago, always blame the Muse for hiding things and then putting them in front of me ! When I worked in the art restoration studio, one of my coworkers articulated "Farrell's Law": that the longer you look for something, the shorter the amount of time between asking a coworker if they'd seen it and finding it yourself.
July 31, 20178 yr On 7/29/2017 at 4:47 PM, jlpservicesinc said: Why is there something about large anvils? What makes me see this beast and be like.. Ooohh.. It's so big.. I want one.. Mind you some Jimmy choos will do it to but on a different level.. Funniest thing I've read in a while. Blacksmithing in Jimmy Choo shoes is about the most ridiculous and decadent thing a blacksmith could do and you made me picture it. Formthe price of a pair of those shoes you could get another new anvil.
July 31, 20178 yr Funny right.. If I could somehow keep from getting hot scale in them, I'd be there..
July 31, 20178 yr On 7/29/2017 at 6:53 PM, Frosty said: And I didn't even make an offer on a 1,200lb. Fisher 1200 lbs??? I... Want... It...
July 31, 20178 yr 1 hour ago, jlpservicesinc said: Funny right.. If I could somehow keep from getting hot scale in them, I'd be there.. Depending on the height of the heel, you'd probably have to adjust the height of your anvil stand as well.
July 31, 20178 yr You betcha.. I was laughing thinking that is another way to adjust anvil height.. Just change from flats, to low heel, mid and high 6" heels..
July 31, 20178 yr I have a "step" built from 4x4's by my heavy pounding postvise to bring me up a bit when I need to bring the hammer down!
