June 24, 20178 yr I'd be interested in learning the pros and cons of tempering to about 400 degrees Fahrenheit by immersing the work in a pot of heated oil. You could measue the temperature of the oil with a deep frying thermometer of maybe a thermocouple . There are plenty of oils (peanut oil, soybean oil, etc.) with smoke points higher than 400 degrees. Thanks
June 24, 20178 yr At that low of a temperature it shouldn't matter? I feel a science experiment is coming on soon... Would it stay warm enough for long enough to get a proper temper would be my question.
June 24, 20178 yr A friend of mine was doing that using a PID controller to keep the oil at temperature. He has since moved to a salt bath. I think that he is using bluing salts
August 29, 20178 yr I was having the same question and found your post here. I did a search on the flash points of different liquids. Found two that may be suitable but at least one that I think could actually work. Would be great for people like me who could just heat a small pot with a thermometer for tempering. No oven. Guess which one Glycerin - celsius 290 / fahrenheit 554 Linseed Oil - celsius 287 / fahrenheit 548 Source: http://www.engineeringtoolbox.com/boiling-points-fluids-gases-d_155.html
August 29, 20178 yr Watch out for pre-flash vapourization and BOOM! I like to use tempering tongs and so do a differential temper. They are tongs with heavy crossbars on the tips of the jaws: to use you heat them in the forge and grab the spine of the blade and let the heat travel making for a softer spine and a harder edge---as you quench in water when the edge is the correct colour. I even found a pair at the fleamarket once...
August 30, 20178 yr I tempered swords in mar quenching oil for a long time, but I have had the oil bubble up and empty its self a couple of times now and i no longer do it. The advantages are even heat distribution. but 450C oil is terribly dangerous and any unheated oil or water droplets turn it nasty quickly.
August 30, 20178 yr W.W.N., The price of glycerin may be prohibitive. Unless you live by, and have access to a fish processing plant. (a possibility in Kerala). Have you checked out the properties of peanut oil? It has a high flash point. Also, thank you for the engineering reference above. SLAG.
August 30, 20178 yr Nah, glycerin is a commonly used substance worldwide. It goes into pharmaceuticals, paint, resins, explosives, cellophane, cosmetics, sausage casings, Pop Tarts, pet foods etc. etc. We haul it on a regular basis at 45,000 lbs per load. I guess that doesn't mean you can easily obtain it in consumer level quantities though.
August 30, 20178 yr I have had trouble finding it in decent quantities retail to tan a snake skin before.
August 30, 20178 yr Glycerin is a by-product of making bio-diesel from waste oils and fats. If you could find someone doing that it may be a source. Also suppliers for soap making. I haven't had a reason to look for it, so I don't know about availability and quantity.
August 30, 20178 yr Why let oil smoke at all? Put a cover on it and purge the air with your mig welder's shielding gas, even 75/25 it doesn't need to be inert just displace the oxygen. Oh heck a piece of dry ice or puff from a CO2 fire extinguisher will work. Open the valve so there's positive pressure in the tank, open the cap, slip the piece(s) to be tempered through a curtain, close the cap and set the timer. Frosty The Lucky.
September 30, 20178 yr In bulk I got it from a website called bulk apothecary. Of course that was after really odd questions at the pharmacy about why I needed it by the gallon... And the price was vastly cheaper.
October 9, 20178 yr This from Tom Bredlow years ago. When tempering small springs, anneal, harden, then flash them in corn oil once or twice. According to him the flashpoint of corn oil is what makes a good temper for springs out of 10xx or W1 tool steel. Works for me
November 10, 20178 yr If you are looking for glycerin, try Craigslist. I have seen several biodiesel makers giving away 55 gallon drums of the stuff. They usually just want it gone. Terry
