Show me your Forge
My Chiminea mesquite fueled forge, its temporary till my other forge is finished.  This was used to heat and quench a single blade.  I love mesquite so much, my 1.99 hair dryer blower and a little bit of scavenged exhaust pipe tubing, and of course a quench bucket.
post-41229-0-06155700-1368991423_thumb.j
  • Replies 509
  • Views 262.3k
Most Popular Posts
  • yesteryearforge
    yesteryearforge
    Here is my forge shown in the old building, and a view of the new shop with all three in place forges made from either 3/8 or 1/2 inch plate hoods made from 3/16 plate The big one is mine and the
  • frankyluckman
    frankyluckman
    I had it laser cut...(on my laser)....
  • Dutchmancreek
    Dutchmancreek
    This is the front of the forge now...I forgot to include it in the previous post. Steve
I thought I had already posted to this thread, since I didnt here it is.  I used 2 pallets of brick and 12 feet of 12 inch tile, and 3/8 diamond plate for top and fire pot. Please notice the rr track anvil with measurements cut into side, I made a tape that wont melt !!
post-2529-0-99944900-1368993036_thumb.jp
post-2529-0-14255000-1368993047_thumb.jp
I've update mine a little, changed the wheels out, added a small spring to help keep the ash dump gate shut tight, and made a removable stock support.
Here'e my new forge that I built today from scratch, and by scratch I really mean it. I welded many 1/4" plates to make the floor and many sheet for the walls. Took me more time than I thought...
Anyways, I'll fire this new baby probably tomorrow. It should works well because it has the same dimensions as before with my brick forge.
post-9026-0-86957200-1369689420_thumb.jp
post-9026-0-94360500-1369689438_thumb.jp
post-9026-0-37212200-1369689496_thumb.jp
My forge set up under my carport. first time to have it set up to use on a few years.  My wife's grandfathers forge and my great-grandfather's anvil.
Greetings All,
This is a small forge I use in my teaching studio....   NOTICE ANYTHING DIFFERENT....
Jim
post-30666-0-11944300-1370181473_thumb.j
Jim
that a blacksmith's shop is painted white, and is far too clean and tidy?
Greetings Neil,
NAAAA  look at where the air goes in....   Look close...
Jim
Neil: I'll bet Jim's teaching studio is clean, white and tidy BECAUSE his troublesome student's need something to do or go home.
Warpig,
How does the heat affect the chiminea?
I have thought of having one in iron.
Greetings Frosty/Neil/3pd,
Yea my shop is clean...    The forge is one I designed for a small area .  The lower chamber is  pressurized by the blower and air is routed to the firepot .  I can also route air to induce a draft by the valve on the side when green coal is added...  There is a venture blow pipe in the stack..  Woosshhh no smoke..
The ladies love my white shop and I do like the ladies..
Forge on
Jim
Excellent application of an induction device Jim. Making the shop comfortable for the ladies is a good thing.
Here is my brake drum forge.
photobucket-3435-1370288797954_zps9be71b
The fire tools are actually tied to the cross bar with string in this pic but I am making some S hooks for them to hang from. I will be using a blow dryer for air.
Here is a better picture of the ash dump...
photobucket-10116-1370555713529_zps6b370
Here is a "hot coke" shot. The way it was taken makes the forge look like it is really close to a bunch of flammable stuff but in reality there was a pretty good buffer (and plenty of water/fire extinguishers near by)
Well it hasnt been built yet but here are some of my models, it also has a telescoping stock holder
post-41233-0-99450000-1370617464_thumb.p
post-41233-0-26004400-1370617471_thumb.p
Hello all. Ian still building my forge and will post pics soon. Just wanted to throw it out there, if anyone wants to build a forge from a big rig brake drum, I get them free fairly often. I live in central California. Lots of leaf spring also.
  • 1 month later...
Been fiddling around with this variable length forge for some time,
Since the pictures I have increased the size of the holes and removed the galvanization from them. Been going well, but now found after a few hours forging the ash starts to build up in between the coke and seem to cool the fire slowly. Thinking I might make even bigger holes and an ash dump valve at the end of the regulating pipe to solve this issue.
Used some heat bricks to cut down on forge size and help with maintaining heat. Due to length of forge it makes heating long projects really easy, no crazy balancing games required.
No flue on it as I am outside and dont find my forge gives off much smoke anyways.
Enjoy, very open to criticism as I am trying something new out and would love to improve on my design.
My new 55/brake drum forge. The rim underneath and the table is quite temporary though. I will make a frame out of angle iron soon.
I love this, do you mind is I copy this design?
Thats why I put it up here, Its a give and take relationship on this site ;-)
thinking of adding a ash dump valve at the end of the pipe and bigger air holes to help the ash drop through into the pipe.
I missed this one, looks good Steve
