Everything posted by civilwarblacksmith
Fire Pot Depth? Answer quick
I needed to fill in around my coke pot, I used a high temperature grout. You should be able to find refractory cement at any place that sells fireplace equipment, wood stoves or inserts.
Some images of projects completed
Very Very Nice. Wish I had room to make some thing like that. Keep up the work.
The scrolls of life
Nice Scroll work. Can't wait to see the rest of the gate.
14" shopcraft band saw
Thanks BT, I'll look them up.
Hey all, I picked up a 14' Shopcraft Bandsaw that is in need of new rubber "shoe"(?) belts that go around the pulleys that the blade rests on. Anyone know where I can find these and if this is even the right term for it? I did find the drive belt at McMaster-Carr.
Very productive day at the forge, and question
These can easly be rounded over the anvil horn. No special tools. Once you have the end rounded, just hang it over the far-side of the anvil and bend it 90 degrees. Ask one question to a group of smiths and you come away with many different ways to do the same thing.
What should I do with this?
Go to a civil war re-enactment and talk to a sutler (civil war general store in a tent). They would use this to apply heel plates to the heels of brogans and cavalry boots. Basically there are skoeing men.
My forge at the Union Mills Homestead is a brick colonial style forge. It had a brick firepot that was the depth of the length of the brick which is about 7". A duck nest tuyer rested under it with the clinker breaker. Much too deep to make the firepot effecient. I had to place a 3" dia. pipe in the middle that was about 3-4" in length and pack clay from the bank of the creek around it to make the firepot about 4" in depth and place a grate over the pipe. It was ok until the clinker built up and adhered itself to the clay when forge welding. We would have to repair the clay. Eventually got rid of it and dropped a 13" round coke pot into the brick firepot that was 4" deep.
- Reb at the forge at Union Mills
solved a problem
Can you post a picture of it. I have a small track anvil in my trailer that could use one. Reb The Civil War Blacksmith
Disc gates fitted
I've alot of yard art that I would have actually hidden from view, but this isn't one of them. It looks great, you did an incredible job on it. Reb The Civil War Blacksmith
What to do with gas bottles
If you are set on getting rid of them, check with the local land fill to see if the hava a recycling area for metal. Here where I live many people take the larger propane tanks for Gas grills there. Alot of time they are full. The people at the land fill just let out the gas and then recylcle them if they don't take them home and use them first. Reb The Civil War Blacksmith
Porta Forge is done
Very nice. Just watch your fingers. Reb The Civil War Blacksmith
How big is your shop?
I live in a townhouse community with a yard that ia 18 ft wide x about 30ft. Within those measurements is a 12ft x 16 ft shop, a 14ft patio and not enough grass to feed a goat. Reb The Civil War Blacksmith
Word Assoc, Blacksmithing
hammer...........
Oven tempering
You can also place the knife on aluminum foil sheet to help protect from the rack. Reb The Civil War Blacksmith
Patch knife?
You can also look in Dixie Gun works catalog or pretty much most catalog selling primitive muzzleloaders for patch knife styles. Reb The Civil War Blacksmith
Finally!!! first knife!
Great looking knife. I made a couple of knive in a basic knife class this year, but can't say they have actually gotten finished. Reb The Civil War Blacksmith
Making Frying Pans
Thanks Jymm, I will have to look at the swedge block in my mobile forge trailer. I think it has a 6- 8 in bowl impression in it that will also work. I can give it a try. Reb The Civil War Blacksmith
Metal Cutting Safety
I am glad all turned out well. There are many lessons learned as we go through life, hopefully this is one lesson that won't need to be relearned. I even wear safety glasses at re-enactments that have the appearance of period glasses. Reb The Civil War Blacksmith
Wooden anvil stand plan??
These are the type of stands we use at Blacksmith Guild of Central Maryland for our anvils. they are a simple 2x4 construction and have held up for many years. Reb The Civil War Blacksmith
Making Frying Pans
Hey Jymm, Thanks for how-to-do on your type of fry pan. They look really great. How long did it take to make one? I plan on using 12ga black, since that is the lightest guage we carry at work. Usta carry 14ga. Can you post pictures of your jig? Reb The Civil War Blacksmith
Making Frying Pans
Thanks for the tip Steve. I sent them an e-mail for pricing. Reb The Civil War Blacksmith
- oregon ridge demo
