marcusb
Everything posted by marcusb
  1. Glad to see the hammer moved. Could you describe the half stroking ? Did you weigh the anvil?
  2. Sounds like a call to the yard is in order, a few minutes with a tape measure would solve the mystery.
  3. Tire hammer rams are filled with lead. If you can spring for it solid is preferable.
  4. Pipe in a pipe/Tube in a tube. Usually with UHMW in between with some kinds bolts to adjust the fit between the whole affair.
  5. This is for ERIE but should get you close to size estimation for that hammer.
  6. Dies on a 1500 pound ERIE, shoe is a size 14
  7. I cost me far more to move my big hammer than it did to purchase it And these hammers require a large hole with some fairly complex form work. Did it have a size marked on it? Anything over 200 pounds requires some serious CFM.
  8. How are the screw threads? Looks columbianish to me
  9. I will be there, still deciding if I want to suffer thru camping again.....
  10. Plywood would be best, and as JHCC said glued and screwed.
  11. marcusb replied to marcusb's topic in Vises
    Thanks Steve. I sure hope it stays put, there's about 400 pounds in that block of concrete.
  12. I would at minimum box the frame in, that would strengthen the structure. Hammering is rough business.
  13. marcusb posted a topic in Vises
    Had my vise bolted to the wall of the shop, and of course I broke that loose. Gathered up some drops/jacks/tractor parts I had laying around the shop and made up a quick and dirty stand. Shop floor is dirt so i cast it into a block for stability. Did a "tap root" in the bottom of the hole about 36" deep to help resist any twisting forces. So far so good, very solid. Only cost me about $20 in concrete.
  14. Its a spare lower die for my big hammer, its designed to put a single sided taper on spud bars. Weighs about 300 pounds. The plate under its 1" thick, not any flex that I can detect, when you forge on it feels pretty solid.
  15. Took a short video of my hammer after I have done some work on it. When I set it up it would only do no blows or full blows. After lots of fiddling with I'm pretty happy with the control now. I was working on a kukri style chopper I forged down from a brush cuter blade. Using a flatter I made to adjust the profile a bit.
  16. 1/2 yard of concrete, 8" deep. My hammer required a 4x6 pad, I would think a rusty would be less.
  17. Pour an inertia block. I have my hammer bolted down on a dirt floor shop. I left the form boards on it to protect the edges. It will also help with an under weight anvil.
  18. I would use that steel in the hammer frame and not a large base. The hammer will need to be bolted down anyways. I know little giants have hollow anvils, my 50 pound did, and i have heard other brands do to. Obviously a solid anvil is best but LG's have moved lots of metal with hollow ones.
  19. I've had a couple 500 pound ish anvils, there hardies were 1.5"
