Everything posted by marcusb
Hans Peot Shop Built Hammer
Reading thru my centaur catolog I saw a set of plans with above title. Anyone build or use a hammer made from these plans? Any comparisons to the clay spencer design?
Anvils in WV...
:rolleyes: Have no fear, scrappers know there valuable
Small shop for $500
10x10
Striking Vise
Finally made up and mounted a striking vise in my new shop I built. Basically I found a nice heavy 4.5" vise cheap that someone had cut the leg off :( . Had some disc bolt that made a perfect stub leg, so I did a heavy bevel and welded it up with 7018. Mounted is opposite my anvil on the same stump. Forged a staple for the leg. Im trying to think up a nice clamp for the jaws that will let me lay large stock across the anvil, clamp it then use sledge.
Small shop for $500
Thanks for the comments guys, finally got the place straightened up, great to have a shop again, even on a smaller scale! Heres a pic of my current setup. I need to figure out a better metal stock storage system and add some tin on top of my table.
Trenton ID question
Wow, shes a beauty and in my back yard, great find! Congrats
Machete design
I have a 20" tramontina with that collins profile, they call it a BOLO. Cuts deep like a hatchet, no real loss of chopping power compared to the longer only loose reach. My favorite machete.
Show me your anvil
Finally got my main anvil on a proper stump. Please excuse the mess :)
Small shop for $500
Forgot to add im living on a rental property, shed has to be moved when we move. One reason I kept it small and the fact I had such a small budget. I moved out of a 25x25 into this, real adjustment. My main concern was theft, have alot of money invested into my tools, and I was worried they might walk off.
Small shop for $500
I was shooting for a $300 budget but sprang for some pressure treat on the bottom to resist rot and new roofing. Came in just over $500 when completed. I built it similar to a barn so I can lift of the structure and attach anything to the walls with a simple nail etc. Long term plan is to convert it into a hunting cabin when I get a permanent shop built. I built a few add ons inside, small work bench and a hammer rack, currently installing a hood and stack. Man do they fill up fast!
Small shop for $500
Finally getting around to posting pics of the small shop I have been working on. Moved here in January so some days it was -20 below when I was working on the building! Rough Sawn wood is local mills "outs". Building is held together with coated exterior screws.
nicholson files
Dont know what they are made of, but when they made the switch to mexcio I bought every usa made one I can find, Got a pretty good pile, good things come and go I guess
Fisher 1200# anvil !?
i see they posted more pics, looks like the 1200 pounder is a 500 pounder
Thinking this is A&H....
I think that is a trenton, horn sure looks like one to me. The underside of the heel looks to clean for an arm/hammer. My take on it is thats its an early plated trenton with the plate milled down. I have seen several with the thin plates. My wild guess is they made a hard plate and were prone to chip.
Mexican cast anvils
Saw a similar anvil at an auction last fall. Tried to talk the local "collector" out of it but he went home with it for $600
My first mistake at smithing
Closest Group to you is most likely NOB, Northwest ohio blacksmiths. They have meetings in Toledo http://www.nob-blacksmiths.org/
- What do I have here?
1920 205lb Fisher
Fostoria
It followed me home
Grapnel Anchor
It followed me home
Seen a bunch of those in musems , said they were anchors from 1700's
Hay Budden
304 pounds Plateless made around 1914 No ball bearings yet to test rebound Came from a shop in KY All I could find on it was came out of old tiimers shop, but due to size and the saftey green I figure some industrial shop before that Very good rebound, nice ring and durable. Has withstood my hammer control for several years :) 486 pounds Plateless made around 1920 No bearing to test rebound Some factory in New Hampshire, before that i dont know When I found anvil of this size, in this conditon by this fine maker, I went and got it Have yet to forge on it, picked it up and then moved across the state, looking foward to working it out I highly reccomend this maker to folks, I especially like the late plateless ones, very very durable anvils
- Weight Forward Hammers
To the fellow wanting to know if I ever shut up
Something froze over, I see pics!
My new baby
Big Blu anvil?
Your favorite anvil
I see you have been in contact with Bernhard :)
