  • Replies 30.4k
  • Views 2.9m
Working on a convex/concave forming stake, with some little brackets for holding firmly in the vise. Still needs grinding to shape and finishing.
After grinding the working surfaces of the double forming stake to shape, I case hardened them and give them a basic finish. Needs a bit more polish, but basically done.
(Kasenit isn’t especially toxic, but it sure smells nasty.)
Nice tool John & good pics to show it coming to life! Still whittling away at your supply of hex.
--Larry
Thanks, Larry!
I actually have two supplies of hex (three, if you count my Wiccan friends): the mild shafting that I used for this project, and the large supply of worn-out jackhammer bits I’ve picked up from tool rental places.
(And yes, I know that traditional Wiccans don’t cast hexes, as it goes against the principle of not causing harm to others.)
I made some edits to the original feather before bringing it for the trade item last Saturday. I was much happier with the results.
I messed up the elbow on my hammering arm over vacation. The symptoms are pointing to tennis elbow AND golfers elbow... But I'm hopeful that I'm wrong, lol
So far I'm 5 days into babying it, trying to remember ibuprofen, trying to remember to wear the forearm arm brace, and just not using it as much as possible. I tried grinding on some pieces for a new anvil stand I was working on and it made it worse so I guess I really need to be serious about resting it. Which sucks because I'm really not good at that.
Might get more proficient with my left arm, lol
Just don't try switching to hammering with your left thinking that holding tongs in the right will be easier. My first brush with golfer's elbow was actually in my left (non-dominant) arm, from poorly fitted tongs and over-gripping!
I figured I could use tong clips! Then just let the tongs 'rest' in my right hand. We'll see. Right now I don't even want to test the waters. I thought I'd work on my needlefelting but even that started aggravating it last night so it's definitely not ready for anything more. I'm going to dive back into Dutch for awhile and maybe finally get the workshop organized but I'm sure within a few weeks, I'll be itching to beat on metal again, lol
I will have to be extra careful to not go and mess up my left arm from improper handling of the hammer though!
Resting is the worst. If I'm not active or spend too long sitting on the couch my mental health takes a hit. I messed my knee up at the Aman Amarth/Dethklok concert a few weeks ago and it's still healing up because I won't sit still.
Last night I decided to try making a vase from some 3 inch round tube I had on hand. Took me a couple attempts to get it to open up the way I wanted. I then used a pair of tongs and pushed it out from the inside. Once that happened I got close to the shape I wanted. The next challenge is figuring out how to twist it or decide to cut the slats at an angle to make it look twisted.
My state of mental well-being is the same. I'm hoping the Dutch studies with be sufficient though.
That's a cool idea for the vase! Looking forward to seeing it finished
I'm left to my own devices as the gf is out of town. Soooooo, as I do from time to time, i started in on another sword to add to the pile of unfinished swords and knives. Looking to get it forged out today, but the axle that's in working with us a royal pain. Almost as stubborn as I am.
I’ve been working on making Viking crafting plier. I’ve got a pile of failed plier halves laying in the shop, but today I got the first set finished:
Forged from a 3/4” diameter coil spring, drawn down to 1/2” square. They’re not quite symmetrical, but I’m still pretty happy with the first finished attempt.
Keep it fun,
David
Nice!
The blade is rough formed. I'll post a picture tomorrow. That axel I'm using really doesn't like moving at less than orange and it laughed at me when I tried using my 1.5 pound cross peen to give my shoulder a rest. Blade is a little long at 49 inches and the tang is still oversized but I like it like that. It's still pretty thick too, so more anvil work there. I'll eventually cut it down to the length I want once it's to my thickness goals.
I have spent 15 hours on this blade. I still have maybe 20 more to go, not counting figuring out the heat treat. This is a fun challenge, keeping it straight, moving it around, getting the initial fuller forged in. But my shoulder is TOAST after three days. I had to break the Trenton anvil back out and turn her lengthwise to keep it fairly straight and work on the bevels.
Good luck recovering Shainarue, smart to not try and push through. Veel plezier met het Nederlands leren.
Very cool pliers, Goods. I've also been thinking about making small tongs/pliers ever since I saw a picture of Peter Braspenninx' infinitongs keyrings (now that's small tongs...!). Figured I'd need an anvil block for sharper corners than those on my very 'experienced' anvil, and larger bolt jaw tongs to forge the anvil block. So when the weather gets cooler and the grass stops growing, I'll be turning back to all our favorite passtime: making a tool to make a tool to make a tool...
Chad, you must be a masochist. Very impressive without a striker.
During a rainy day, I lit the fire and forged a simple handrail for my aunty. She's getting on a bit, and had some trouble getting up the cellar stairs so requested a handrail. Let's hope it helps her get up the stairs for years to come.
Edited by pragtich
clarity
Pragtich you have dimensions? It looks thin? But it could be 20x20mm and in that case, it is very long!
I have been forcing myself to make things more slender. This one may or may not have gone too far -- I actually feel like it will be ok as long as I manage to screw it securely. We'll see, I guess.
It's 60cm long and a flattened ø10mm cross section. So it's quite light. I suspect the weakest part might be that I sightly over forged the feet.
The weakest part will be the screws you put into the wall. But I got distracted by your footwear. Are those clogs?
I was just working on roses tonight v myself. For some reason my shoulder fatigued quickly.
Yep :-)
I love them for pottering about the yard. They're great in wet grass and on soft ground.
I don't usually forge in them (although some do): stepping on a small piece of dropped steel can be very slippery).
My right one broke a few weeks ago, I fixed it with some glue and one of these old-fashioned nail strips.
I worked at the monastery for about a month. There are a lot of roses on the grounds. I was ordered supports for them. Other orders are a little behind schedule.
The shelf has taken its place. A corner of the pool maintenance room has been allocated for a gun safe and a place for gun maintenance.
Blacksmith Jymm Hoffman forges in klompen; he adds a steel horseshoe under the heel so that they don't wear out as quickly.
We bought a small homeowners wood chipper on Sunday from Face Book Market Place. It cost $350 (new it's $599.99) and it's in very good condition. I serviced it on Monday, changed the oil, cleaned the air filter stuff like that. Runs good and starts on the second pull of the recoil starter rope.
The main thing about it is the handles to move it around are too low, so I had to stoop over to move it. Kinda hard on the back. So I fired up the coal forge and took a 36 inch piece of half inch round mild steel stock from the resource pile and forged a new handle. Used the Star 30 pound power hammer to draw out the ends for mounting, then a hardy scroll bender to shape the bends. Worked out just fine and only took about an hour to make it.
That turned wood handle in the second picture, I made by lag bolting a U bracket to a scrap piece of 4X4 then bolting the turned handle to it. Makes a good safe pusher to keep hands out of the blades and when the chipper is not being used it keeps critters (mice) from building nests in with the cutters blocking the entrance.
I can’t control the wind. All I can do is adjust my sails. ~Semper Paratus~ USCG 1964-1970
I finally figured out the Fredrich's cross Dragon Fly i was working on. First attempt with the new design. This should get better from here. Maybe something to help shape the eyes a bit better.
