January 11, 20206 yr Looking at the local FB marketplace I saw this old 34” saw blade for $100. Assuming it’s good steel, how much would you pay for it?
January 11, 20206 yr I would buy known steel from a steel supplier if I had that amount of money. I'm not really sure how much that would be though.
January 11, 20206 yr It is worth a lot more to someone who wants to paint a picture on it. Scrap price for me. 23 cents per lb.
January 11, 20206 yr Folks, You can probably buy many new circular saw blades for $100. Sorry I.D. F. & C, Herr SLAG bids $5.15 for it. SLAG.
January 11, 20206 yr For $100 you could buy a nice 2" wide monosteel bandsaw blade new and know what you have. Senor Slag clearly outbids me. Frosty The Lucky.
January 12, 20206 yr As usual questions about 'worth' are subjective. If I was making a sculpture and the final missing piece was a large circular saw, perhaps I would pay a higher than scrap price. So it is all about how much it is worth for me ... or rather for you. For the others it obviously is overpriced because they are hinking in steel value. Bieing it most likely comes from an old mill, it can have value for different reasons that are not it's steel content. They do very well for target practice because you can hear when you hit it
January 12, 20206 yr 2 hours ago, Frosty said: "Senor Slag clearly outbids me." In the interest of better Missouri - Alaska friendly relations SLAG, Industries L.L.C. will be most pleased to gift said circular saw blade to representative Hon. J. Frosty of the exalted state of Alaska. Respectfully submitted, Herr SLAG. Edited January 12, 20206 yr by SLAG removing redundency
January 12, 20206 yr That's quite an old school blade, not having the usual semicircular inserts for replaceable cutting teeth. I wouldn't use it for blades as it's value is really in being an "antique" decorator piece..or painted as someone mentioned. The price reflects that use and it would go for pretty close to that around here plus or minus. Much better value to buy known steel in a shape and size that's appropriate for the work and use that...or, if one really wants to "recycle", buy good scrap of a similar nature that doesn't have the premium cost adder of being a semi-antique. Your local pawn shop probably has a bunch of smaller blades at something like a buck or two each and you could harvest far more steel for the buck.
January 13, 20206 yr Any local sawmills? They often have a pile of old blades around. Doughnuts make a good winter conversation starter.
