EtownAndrew Posted March 3, 2013 Share Posted March 3, 2013 I forged a small frying pan this weekend. It was the first thing like this I had ever done. So I went looking on the internet for advice. The only thing I found was a youtube video featuring Jymm Hoffman. I basically followed his method. The only difference was that he pounded the sheet metal into a dished form. I didn’t have one and so used a 4” O.D. dishing ring hardy tool that I made. It seemed to work well but may have beat up the metal more than using a form. I started out with a 14 ga x 8” round blank. The finished pan was 7” O.D, 5 ½” OD bottom, x 1 ¼” tall inside. The first step is to create a bowl. This is shown in the attached pictures. My bowl was 2” deep. The final step was to flatten the bottom and create the pan shape. I made a 5 ½” round flat form to pound the pan bottom down onto. Jymm Hoffman did not use one of these for the demo but mentioned them. It was also usefull to hammer the pan againt the anvil as a sandwitch to try and create an overall flat bottom. Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 4, 2013 Share Posted March 4, 2013 Looks like a perfectly workable frying pan to me but isn't the coal fire a little hot for cooking? Frosty The lucky Quote Link to comment Share on other sites More sharing options...
bosox Posted March 5, 2013 Share Posted March 5, 2013 Very creative. Your work is wonderful. Cool project. Quote Link to comment Share on other sites More sharing options...
eseemann Posted April 11, 2013 Share Posted April 11, 2013 What kind of steel is that? Just normal sheet steel? Quote Link to comment Share on other sites More sharing options...
tjdaggett Posted October 15, 2013 Share Posted October 15, 2013 I am so glad someone has already done this! Cookware is one of the things I will be shooting for first once I get a forge-space. Truly well done. Quote Link to comment Share on other sites More sharing options...
Nick Posted October 15, 2013 Share Posted October 15, 2013 That's a nice little pan. What did you use for a final finish? As an alternative to dishing the sides, you could try raising them over a T-stake or side stake. Then you'd start with a more defined corner where bottom and sides meet, and the bottom would be kept mostly flat, then you can use the big bottoming tool to clean up the edges and the bottom. I don't know if it would be easier or quicker, just a possibility. Quote Link to comment Share on other sites More sharing options...
EtownAndrew Posted October 17, 2013 Author Share Posted October 17, 2013 I used 14 ga (1/16") sheet metal for this. It was a former lawn mower hood cover. I used a portion where it had originally been broke at 90 degrees. The crease still shows. Next time I need to start with a piece that was not previously bent. Nick that sounds like a valid thing to try. Before I tried this I watched a very long series of youtube videos showing Jymm Hoffman forging a fry pan. He said that he had tried many times to just raise the sides and leave the bottom alone and it had not worked for him. His breakthrough method was to also dish the bottom and then go back to flatten it. The pan does not really have an official finish on it other than cooking oil. The care of this pan is similar to a cast iron pan but I don't think that it needs an official seasoning other than giving it a light coat of cooking oil and starting to cook. Try to avoid washing it in soapy water as that does remove the surface oil that it needs. Most of the time the pan is pretty clean after I am done cooking and so I just wipe away the excess oil with a paper towel and put it away warm. If it does need water I take it hot over to the sink and rinse it off and then put it back on the warm burner to dry. The 8" diameter blank that I started with produced a nice small fry pan that is really good for frying an egg or two. It is a tiny bit small for making a pancake but I have still made a lot of pancakes in it. Also I brought the sides up too much. They would be best left at a more shallow angle so they don't interfere with getting a spatula under the food. This pan was about at the limit of my normal blacksmithing hammer to reach into the dished pan. I am about half done with a longer "sheet metal" hammer that has about 3 1/2" of reach from the handle center line and a more radiused face. So some time in the next few months I will probably make a slightly larger pan and put a basket weave handle on it which should be cooler. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted October 17, 2013 Share Posted October 17, 2013 A couple of thoughts, from the cooking side of things. The thicker (with in reason) the bottom the better, rinsed or wiped clean is good enough (the pan will be heated to 250+, with practice less steep sides will alow you to flip eggs and pancakes with out a spatula. You will drop a few before you get the hang of it. Make sure to give the dog pepto and clean up the kitchen before the wife finds out... Quote Link to comment Share on other sites More sharing options...
HIGHSIDER Posted October 17, 2013 Share Posted October 17, 2013 Very nice work, Oh that has me thinking... A good fry up for tea!.. :ph34r: Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted October 17, 2013 Share Posted October 17, 2013 Got to love y'all from the other side of the pond. I miss tea in a British mess. Had a survival instructor that said if you could stop and make a cup'a you had everything you needed. Fond memories. Quote Link to comment Share on other sites More sharing options...
beth Posted October 17, 2013 Share Posted October 17, 2013 charles - absolutely right :) tea, aparts from love, is all you need :) andrew thats a nice little pan - i could cook with that :) and i reckon i could flip a pancake in it.. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted October 17, 2013 Share Posted October 17, 2013 Developed a taste for cream and sugar in it. I tried real hard to keep track of British units in the field. If you walked in at tea, they always gave you 10 min. Head start before resuming their exercise. Quote Link to comment Share on other sites More sharing options...
DSW Posted October 17, 2013 Share Posted October 17, 2013 Nice job. One thing you may already know is those ceramic range tops don't heat pans well that are not fairly flat and make contact with the surface. Thus the flatter you get the bottom for more contact, the better. I wonder if going at the bottom with a flatter wouldn't help take out some more of the hammer marks. Usually with food service items, the smoother the better so they don't have nooks and crannies to collect crud and bacteria. Probably not a huge issue with a fry pan though at the heat it usually gets used at. I might be tempted to make a round faced flatter if I was doing a bunch of these. That or just weld a 1/2" thick 3-4" dia slug to an old "hammer" and radius the edges a bit. The smaller size would transfer more power to the bottom to help clean up the marks better than that big one you used. The only other side note is that 1/16" is typically closer to 16 ga than 14 ga. That makes it easy to remember. 14 ga would come out closer to 3/32" on most of my gauge charts. Gauge thicknesses do change with material, so 14 ga alum isn't the same thickness as 14 ga steel or brass. Quote Link to comment Share on other sites More sharing options...
EtownAndrew Posted October 18, 2013 Author Share Posted October 18, 2013 Cleaning up the marks is certainly something to work on. I don't have an official flatner but one would not be too hard to make. Quote Link to comment Share on other sites More sharing options...
windancer Posted October 18, 2013 Share Posted October 18, 2013 You did good. Easily serviceable fry pan. I like it! Dave Quote Link to comment Share on other sites More sharing options...
David Gaddis Posted October 19, 2013 Share Posted October 19, 2013 I make these quite often and quite differently. A skillet must have a completely clean flat bottom, but I like the look yours has a for a rustic view.If you check back there are a bunch of pics that I posted in April this year.Good luck with your projectCarry on Quote Link to comment Share on other sites More sharing options...
Davor Posted October 19, 2013 Share Posted October 19, 2013 Great idea and a great work. Love it. Quote Link to comment Share on other sites More sharing options...
Bob S Posted October 19, 2013 Share Posted October 19, 2013 '?do=embed' frameborder='0' data-embedContent>> Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 19, 2013 Share Posted October 19, 2013 how about a jig for your large post vise---a couple of thick arc'd pieces that you could trap the pan bottom between and then work the edge over on? (Me I'd probably use my large H frame screwpress to convince the bottom to stay flat...) I bought a couple of large thick sheetmetal disks at the fleamarket but plan to use them for medieval round bottom pots---made a long reach dishing hammer out of a RRbolt (not spike, bolt---nice domed head for dishing) Pots are a lot of work! Quote Link to comment Share on other sites More sharing options...
David Gaddis Posted October 20, 2013 Share Posted October 20, 2013 Thomas...do you form your pots hot or cold? How about annealing or stress relieving?We could enjoy some pics of the operation please.Carry on Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 20, 2013 Share Posted October 20, 2013 I'm a blacksmith and tend to use thick material for my pots and work them hot! Generally dishing over raising. I have found that if you leave the last little bit of the outer rim untouched it makes for a nice turn in Quote Link to comment Share on other sites More sharing options...
Bob S Posted October 20, 2013 Share Posted October 20, 2013 I'm a blacksmith and tend to use thick material for my pots and work them hot! Generally dishing over raising. I have found that if you leave the last little bit of the outer rim untouched it makes for a nice turn in would like to see some pictures. Quote Link to comment Share on other sites More sharing options...
David Gaddis Posted October 21, 2013 Share Posted October 21, 2013 from the skillets that I have made I have determined that it is imperitive to keep the steel blank very secured to the anvil form by some technique. Recently an extra thick spacer is clamped onto the piece while allowing enough area along the edge to apply heat, working the metal. I have heard that some skillet smiths are making some 3 and 4 inches deep. Now that would be a very intersting project for me to witness. When all that metal is raised from flat to vertical(ish) one finds a whole lot of extra metal to deal with. With the raising process it is easy to start a cold shut and the taller the skillet wall difficulty increases rapidly. A true celebration should be in place for the smith to free form a skillet and keep the bottom as flat as my anvils and frame allow. Not saying that it cannot be done by any means, but I honestly feel it to be extremely difficult. As far as a flat bottom goes, there should be little if any wrinkles. The wrinkle may look "old timey" but a magician could not cook a decent plate of cornbread in one...I think. If anyone feels there is a need for more private views of my project please PM me. For the originator of this thread I appoligize for hijacking this item. Maybe someday I may do you a favor as a small repayment. Carry on Quote Link to comment Share on other sites More sharing options...
EtownAndrew Posted October 21, 2013 Author Share Posted October 21, 2013 I have a theory that the oriental Wok had a round bottom because the smiths couldn't figure out how to keep it flat. Then from there they just adapted their cooking process to accommodate the round bottom. Quote Link to comment Share on other sites More sharing options...
