You might be a machinist if
Glenn
  • 2 months later...
  • 3 months later...
  • 3 weeks later...
  • 10 months later...
You might be a machinist if it takes you longer than a smith takes to put a square tapered hole in a bar
You might be a machinist if you use a hacksaw to put a slit in to make a Celtic / Fredrickson cross, fork end, or animal head etc when it would be more appropriate / economical / and quicker to slit it with a hot chisel/cutter
  • 1 month later...
if an RCH is a "loose" tolerance your a machinist.
if an RCH is a hammer tap away your a blacksmith
if you don't know what an RCH is your an engineer
I guess I'm an engineer so please tell me what RCH is:D, The silly part is that I'm in school right now to become an industrial tech engineer.
  • 3 weeks later...
  • 1 month later...
I picked up a trashed micrometer at the fleamarket for $1 once just so I could use it as a welding clamp when machinist friends drop by---they gibber so nicely...
That's just mean.
It's a pleasure to know you. Father was a metal spinner and machinist, I would've loved to see the look on his face.
Frosty
