You might be a machinist if
if you ever made a 1/4 20 screw because it was quicker than going to the hardware store.
  • 2 months later...
If you're building a deck and you write all the tape measurements down in decimals, to the third place. My brother-in-law kinda gave me a weird look. Jim
  • 3 months later...
if when you say tenths you mean tenths of .001 not tenths of an inch
If you buy plain cigarette papers to shim with or to polish with.
If the carpet in the house sparkles from tracked in chips.
If you beat your carpenter friend senseless because he gave you a measurement that ended in"..and a heavy eighth". I just cut stuff an extra couple inches long when someone does that to me. I tell them sorry, I don't know how to use those big numbers.:D
Dave
if a customer comes in holds his finger X distance apart and you grab your measuring tool to measure between his fingers, all custom ordered metal sales are final.
  • 3 weeks later...
  • 10 months later...
if an RCH is a "loose" tolerance your a machinist.
if an RCH is a hammer tap away your a blacksmith
if you don't know what an RCH is your an engineer
you might be a machinist if you can't put a 1/2" hole in 1/2" bar stock (a blacksmith can).
I picked up a trashed micrometer at the fleamarket for $1 once just so I could use it as a welding clamp when machinist friends drop by---they gibber so nicely...
You might be a machinist if it takes you longer than a smith takes to put a square tapered hole in a bar
You might be a machinist if you use a hacksaw to put a slit in to make a Celtic / Fredrickson cross, fork end, or animal head etc when it would be more appropriate / economical / and quicker to slit it with a hot chisel/cutter
  • 1 month later...
I guess I'm an engineer so please tell me what RCH is:D, The silly part is that I'm in school right now to become an industrial tech engineer.
  • 3 weeks later...
  • 1 month later...
If, "the color of straw", has nothing to do with hay.:)
That's just mean.
It's a pleasure to know you. Father was a metal spinner and machinist, I would've loved to see the look on his face.
Frosty
