Everything posted by Nakedanvil - Grant Sarver
Can this anvil be fixed?
Something that thick would be nice, especially because you have no way to bond the surfaces like in a forge-welded plate. Have to machine the anvil flat first though.
Well, I'd probably machine the middle part flat and cut a dovetail in it. Make a 6" long die and wedge it in. That would give a reasonable working area. Then weld up around the hardy with 7018 to make it usable. That way you end up with nice heavy anvil with a good working surface, a usable hardy hole and a nice horn. What else does a chap need to have a good time?
melting copper
If you are meting it in the trough, it will bond to the trough, 100% guaranteed!
Junkyard Find
Nakedanvil - Grant Sarver replied to Wesley Chambers's topic in Power Hammers, Treadle Hammers, OliversYou're right, that's a better match for sure. Wouldn't be unusual for them to change the base.
Junkyard Find
Nakedanvil - Grant Sarver replied to Wesley Chambers's topic in Power Hammers, Treadle Hammers, OliversLooks to be a Flint-Lomax. They were pretty light in the anvil, but I'd use it for your project.
can a hydraulic piston push arm be forged
Most hydraulic guys (even if they are good at hydraulics) know diddly-squat about steel. You got an answer cause he didn't want to admit that he didn't know.
Often (usually?) 1045 or in higher end stuff 4140.
Drilling a Square hole
Another Watts drill video:
square holes
Real Video of a "Watts" drill:
Guys,,,,,,,Is this stuff "Blacksmithing" or "Metalworking"..........??
Yeah well, that's easy. It's all the "tween" stuff that causes the questions.
Can I forge a DUCTILE IRON Bick to fit my hardy hole?
Patrick: Was that in Indiana? They had a really different hammer, like maybe 100 pound?
- Window Sash Weights
Can someone help me with heat treating these punches?
I'm with Phil, but I'll add a little. When heating with the torch, don't put the heat right on the end. Heat further back and let the heat "run" out to the end.
Blacksmiths are just natural born gamblers!
Brian Brazeal Striking anvil
Instant? You use the term loosely I presume.
Diamond pattern
Let me guess; threaded rod, hammer square, chisel, twist, hammer square, chisel, untwist. Close? Kewl!
Saw blades
Most solid circular saw blades I've seen were a water hardening steel. The production line I saw had the blades coming out of the furnace on a conveyor, dropped it on the spindle in a quench press and the press would close. All automatic. The quench press had water cooled platens that held the blade perfectly flat while they were cooling. Very fast quench. Then they were drawn, the teeth set and sharpened. In this thin of a section, I'd expect them to be anything from 1045 to maybe a little better.
organic matter deposited in my coal
Nakedanvil - Grant Sarver replied to Bigred1o1's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etcRun it through the wash machine when your wife is at bingo?
Here's rotary broaching. Square, hex, whatever:
vertical roller machine
Rolling half-rings, ah! There are some cheap hand-powered rolls out there. Remember; it won't roll the first and last couple inches. If you need it perfect you need to cut a little off the ends after rolling. Also, you usually want to roll them a little tight and adjust open rather than even attempting the other way around.
Be pretty hard to use grooving rolls on square bar.
electric die grinder bits and use
Friend of mine used to bring me piles of carbide burrs in different configurations. Place he worked at used them on titanium for a couple hours and tossed em! Still worked fine on steel. Same with diamond abrasives from the glass blowers.
My hammer jammed
Stick a 2 X 4 down from the top and hit it.
What Preparations Should Be Made For Setting Up a Hammer-in
The Northwest Blacksmith Association is able to extend it's liability insurance to NWBA SANCTIONED events and hammer-ins. There is also a difference depending on whether you're charging or it's just some friends getting together.
AIM Kiln for heatreating
Just as long as the charcoal is in the chamber it will consume the oxygen.
