Content Count
91 -
Calendar
Everything posted by RogerrogerD
i’ll try that, thanks TP.
Renovating a Bradson No15 drill press.
RogerrogerD replied to RogerrogerD's topic in Drills, Post drills, Mag drills, etc
Some work on it today. Painting the gear covers. Working off the rust from the base. The pillar is rusted, and seized. A swim in wd40 penetrating oil, plus the application of some heat just started to move it, with some effort snd hammering. Will repeat tomorrow with even more heat. The original colours were indeed red and green. -
And its back together... strangely it now won’t close tight... I’m having a think about why. Here it is in a temporary mount. My other vice, somewhat smaller, on the other side of the the trunk.
I use the metal store online and it works easily enough like amazon but they dont seem to stock carbon steel. But fine for all sorts of mild. Delivery is efficient. I have used metals4u in the past, same simple online ordering.
Been thinking about how it might be raised and lowered on the pillar. Im guessing the best way to raise would be to place lumber under the chuck, loosen the pillar screw and wind it up on its own mechanism. And for “lowering” it onto a piece needing drilling, simply put a plank under the piece needing drilling...and forget about lowering.... sort of. Which maybe gives me a clue how to dismantle the seized pillar collar... -
The whole mechanism is mounted on a single steel pillar, maybe inch and a half in diameter. The mechanism can be moved up and down but I’m a little surprised that there’s just a single screw holding the mechanism to the steel pillar. I guess it was designed to be pretty tight on the pillar and you tap it down, but it seems crude, and frankly difficult. Probably easier to have the object being drilled on a stack of wood, and add to it. I’ll probably convert to a jacobs chuck so I’ll need a little more height. here’s the bolt holding the mechanism to the pillar. Anyone have advice on how -
Curing the beeswax and linseed coating on a cooling forge.
Rubbed down all parts with a home made mix of beeswax, BLO and turpentine. Fascinating examining the parts and working out how they were made especially the massive drift of both legs where the screw thread goes. Next step is to finish off the surface treatment. I’ll place all the parts around the edge of my coke forge after I next use it. The heat will warm up the metal and its coating, then cool slowly leaving a nice shiny finish. My hands smell of linseed and beeswax. No better aroma. New pivot bolt should arrive by post tomorrow and then I can put it all togeth
UK-US blacksmithing differences
RogerrogerD replied to RogerrogerD's topic in Blacksmithing, General Discussion
They certainly roll -
At least its all of us... -
No, not sure... but fairly certain. As a quick test i entered blacksmith coke forge onto UK ebay. Top six hits were side blowers, one bottom blower. That proves nothing, I know, but bottom blowers in my limited experience are rare. But I am no expert. -
spent the day wire wheeling it. Comes up nice, no makers mark. Now I have the pivot point cleaned up its apparent the cheeks are in matching halves, forged welded together and the two together then forge welded on the leg. Strange. You can see the join but it looks solid. It’ll need a new pivot bolt, and I was flat out of 3/4 inch bolts, so ordered some and they are on the way. Smallest component easily the most expensive. In the meantime, I put the parts together temporarily to test the spring. I was worried that 50 years plus of being clamped tight with the spring under tension woul
I’ve been only at this blacksmithing game a few months so this post may be nonsense. I’m a Brit but love the US and have worked there a lot. It intrigues me that in some aspects there are different approaches to certain blacksmithing techniques and equipment. Some examples I’ve noticed so far: 1. A lot more use of coke forges in UK. Seems to be the standard. Coke is pretty easy to obtain in most parts over here. Charcoal less so. Most US pals seems to use gas mostly. 2. Most solid fuel forges over here seem to be side blown, water cooled. Compared to bottom blown in the US. From
Ok I’ll follow that guidance, thanks.
I was lucky on ebay. Guy selling it was 25 minutes away. Threads on the screw box look fine at first glance, but I need to clean it out and shine a light in there. A little surprised no thrust washer, and on the box side there are the remains of a leather washer. We’ll see how it works when cleaned up and then if I need to, I’ll work a thrust washer out. A few interesting anomalies. 1. The spring bracket was encouraged to stay in place at the top of the leg by a strange bead of weld horizontally on both sides of the leg. The weld wasn't to the bracket just a raised lip on the l
Yesterday I picked up this heavy old leg vise. £50 on ebay, along with a pillar drill press for another £20. I’ll do a seperate thread as I resrore that but first to the vise. Generally very good condition, nice straight jaws. A few signs of some odd welding done in the vicinity, but nothing too serious. Probably locked tight shut for 50 years plus, totally seized at the pivot joint. It came apart with a bit of patience, a swim overnight in wd40 magic juice, a spanner, a soft hammer, some wooden wedges and the application of some heat. Thomas Powers advised I may find some
Got it apart after an overnight swim in wd40. As you predicted TP there was some odd pitting and unevenness on the pivot joint cheeks. Strange. I’ll make a new thread with pics in the vice section and get off this thread.
Thanks TP I’ll use that reasoning when my wife asks. :- )
Will do. :- ) I suspect that the vice has been cranked tight closed for a few decades. Spring looks OK but perhaps all that time under pressure will have deformed it a bit. I dunno... My plan is to clean it all up, fit it together and then check if the spring has enough oomph (technical term round these parts) to push the vice jaws apart. If not, I’ll whap it in the forge, warm it up and bend a bit more of a bend in it. I’m guessing I dont need to worry about heat treating it after, should be enough stiffness there with a simple air cool. Once done I’ll post a before and after pic on the
Its flat, TP
This is where I think there should be a washer, but isn’t
Thanks TP. I intend to do just that, and have mostly got there, apart from the pivot nut and bolt which are tight. I’ll leave it in wd40 over night and try in the morning. Any thoughts on the need for a thrust washer?
Just picked up a nice 6 1/2 “ leg vice and a No 15 Bradson pillar drill. Both not functioning but 5 mins work in them and I've spotted the issues. The pivot bracket on the vice is seized up preventing the jaws from moving but a swim overnight in wd40 magic juice should fix that. Its the one on the floor. The pawl spring was missing on the pillar drill but otherwise apart from rust and grime all working. Heres the pics . The pillar drill has a 50” dia flywheel and stands 2 1/2 feet tall. On the vice there is no thrust washer - can I ask advice from those here if I need one? Fe
Repurposing a soft anvil
RogerrogerD replied to RogerrogerD's topic in Anvils, Swage Blocks, and Mandrels
OK I spark tested my “soft” anvil. Its definitely cast mild steel. So I appreciate everyone’s useful input. Because I already have a big “hard” anvil, I’m going to leave this soft, use it as a cutting table, and also semi permanently mount my “smithin’ magician” in the hardy. Welding up a hard face is bit beyond me and I don’t need a second hard anvil, so its luxury. Makes me wonder what was going on in that east european factory that I think was making Branco anvils on a sub contract. Looks like a Branco “blacksmith” anvil. Just for interest does anyone know if these go against the modern t
