11,928 -
For our portable vise I used an old automotive flywheel, scrounged from a scrap steel bin for the base. The rest of the stand is also scrounged material. For stability when using it on dirt, I forged some spikes that are driven through the holes in the flywheel for stability. On hard surfaces a plate that gets bolted to the flywheel I can stand on.
Building my first gas forge , critique my ideas
Irondragon Forge ClayWorks replied to PedroS's topic in Gas Forges
Have you done a search for Plistix 900 F kiln wash?- 10 replies
- ribbon burner
- gas forge
Cutting Tanks
Irondragon Forge ClayWorks replied to 671jungle's topic in Welding/Fab General Discussion
I found that when working with people under pressure, I usually could talk them into opening the valve to vent. Some times my guys were amazed how I could get them into the patrol car without fighting. -
Cutting Tanks
Opening the valve first is a given, I should have mentioned that because there are some folks not smart enough to realize that. But then they should not be using dangerous equipment at all. -
Cutting Tanks
Better yet remove the valve. I've cut a few tanks and always get that pucker factor even with the valve removed. -
Auto Zone should have acetone and Dexron automatic transmission fluid, in quart cans, so does Walmart. A 50/50 mix of that will out preform any commercial mix penetrating oil on the market. I put the mixture in a small spray bottle and label it.
Belco anvil marked Canada
Irondragon Forge ClayWorks replied to Iron Raven's topic in Anvil Reviews by brand
I don't have many pictures showing the shop, especially organization which doesn't exist in mine. However I know where everything is so I don't have to spend a lot of time looking for stuff. We just added a 12X14 foot addition, making the shop 10 foot wide by 42 feet long and the pictures show a lot of disorganization as I move stuff around. Looking at the power hammer & coal forge. We also have an outside pad that we roll the propane forge out to when using it. The anvil is now mounted to a wood stump like the improvised anvil is on. Looking in the outside door at the new addition area on the far end. Another shot with that half wall removed. The other side with the garage where the grinder's, welder's and mechanical tools are located. The addition to the blacksmith shop is on the right. Still a lot to do with it as far as organizing stuff. -
I made mine from glued laminated wood bolted to a V-belt pulley, turned to diameter. Put a slight crown in the wood to help the flat belt stay on the pulley. You can use a V-belt, better to use two,matched belts. The nice thing about a flat leather belt is no need to disassemble anything to install/change it.
Will I damage a 4.5” post leg vice with a mini sledge ?
Irondragon Forge ClayWorks replied to Jon108's topic in Vises
Is your "mini-sledge" actually a hammer like a drilling 3 pounder? -
I have used several commercial forges that had a spark igniter of some sort. The spark plug igniter worked for a while then quit working, the Piezo igniter never worked and both forges were regressed to using a propane torch to light them. We have a Piezo propane burner head that screws on to a standard propane bottle that we use to start the propane and coal forges.
Show me your blacksmith pets
Irondragon Forge ClayWorks replied to Glenn's topic in Blacksmithing, General Discussion
Our Schnauzer Max, lived to a ripe old age on insulin. He was such a treat. He would go outside and pee into a cup on a handle so we could check his GL and if it dropped too low, he knew to go over to the cabinet where his Kayro syrup was and ask for it. -
It followed me home
I clean mine with WD-40 and an old tooth brush, then wipe it good with an old T-shirt. Only have to do that if the stone starts to get clogged up, which doesn't happen if it well lubed while sharpening. Looking at the picture of yours it doesn't look worn or clogged. -
First of all, we won't remember you are in Finland once leaving this post, hence the suggestion to edit your profile to show location. This thread Read This First located up in the blue banner explains how to get the best out of the forum. Second is all you have read about bottom blast VS side blast is true. Bottom works best with coal/coke and side blast is better with charcoal. With your sketch it should work but you don't need a sloping wall on the off side but it won't hurt. I have seen many side blast forges with both wall's at a slant and both straight, they all work very well. There is a thread by Charles Stevens with a steel side blast he built, I'll see if I can find it for you. The JABOD threads you have seen are built with wood boxes, hence the heavy insulation to prevent the wood from burning, not a problem with heavy steel plate. I couldn't find it maybe Charles will chime in and post some pictures. To answer the question about building a side blast without a bosh water cooled tuyere, is yes you can but the tuyere pipe will burn out eventually and is easy to replace. I make mine longer than needed and just push the tuyere farther in when the tip burns off.
Worth the asking price?
Irondragon Forge ClayWorks replied to Jealdi's topic in Anvils, Swage Blocks, and Mandrels
If I needed another anvil and it checks out, I would pay the asking price. The edge in the picture is not bad enough to bother me. I have a Hay Budden with worse edge's and it does not cause any problems. As a matter of fact sharp edges on an anvil are a detriment to good forging. -
In today's market $3 a pound is not out of line, however with the (minor) edge damage you may be able to haggle a little. I would offer $350 to see what happens. Make sure you tell the seller you intend to use it in your blacksmith shop as that has convinced some sellers to lower the asking price. Like Frosty said the ring & rebound would indicate the condition of the hardened face plate. From what I have read they are good anvils and fairly scarce. If you do a search with your favorite search engine like this Dunn and Murcott brooklyn ny iforgeiron.com there are about 5 threads about them. This is but one. -
Intro Topic - New to Blacksmithing
Irondragon Forge ClayWorks replied to TheWanderingLlama's topic in Introduce Yourself
Have you read the Read This First thread located up in the blue banner. It is full of tips to help in getting the best out of the forum. One tip addresses using the @name tag. -
It would definitely melt if left in the forge. Any way to set the sparker in the forge then pull it out after lighting the burner. A lot of folks just light a small ball of newspaper and toss it in the forge to light it.
