Everything posted by bubba682
Power hammer build and effect of a larger anvil mass
I wish i had of seen this hammer before i bought my anyang i think its a bit of a game changer for the more serious back yard guys shop cause its cheap to build and run and thats the play of the game for alot of folks.I think he done a great job and if it holds up ok great if you got to do some maintenance once in awhile so be it they all require maintanace.I agree with you Greebe cool concept and glad he built it.
Nice hammer it hits great and real good control whats the over all cost do ya figure.
What is a good size for a welding table?
Great thread just gettin ready to make one i'm thinkin 2x4 with adapters to add length and defiantly on wheels i seen one made with flat bar on top with 1'' gap for clamps i like the gap idea but i also like tackin my work to a table anyway decisions decisions got to gather a little more material then time to cut and weld.
Forging Press -Build vs Buy?
swedefiddle if your gettin alot of groaning and creaking in your press send it back and get your money back.I thought John Little only did traditional work when did he go modern with a preess..
Build it yourself..
Moving to Canada as a Blacksmith
bubba682 replied to Getithotterhititharder's topic in Ontario Artisan Blacksmiths Association (OABA)Hopefully once you vacation thru the country and figure out if you wanna stay i hope you got your own blacksmith gear its expensive to get here especially if you can't make your own tooling.Differant parts of the country will probally pay better than others depending on what you hope to make and your skill .You'll probally have to show on paper you have the skills and our immigration is hard to deal with at times cause of politics.And if you rent a car try to get unlimited milage cause were a big spread out country anyway goodluck if ya got any ques i'll try and help you out....
5hp motor, what components to buy for a decent 25 ton
From one canucklehead to another i went with a 5hp motor and all componants came from princess auto almost 3 years still sqeesin got about 20t its all you'll need make a flat die and a fuller die they'll do the bulk of your work.
Press is not as powerful as it should be
Something is off cause i got the same set up my press is fast with the 5x10 ram and i'm pretty sure my pump is a little smaller i ain[t no expert but you should be fast and have alot of squeeze so something is defiantly not working right.What is your reservoir capacity mines 5 gallon
Anyang ST - The real deal?
I bought mine a 33lb from the Toronto blacksmith shop great service and its a clone of the anyang and the way i look at whats the difference there all made in china they all run the same parts .I've had it two years and for a compact hammer it has great control and hits hard and if i was a bettin man i'd say most are all made in the same shops and sent out under differant names.I have a buddy that bought a used one that was busted up pretty bad and he got his parts from James Jonhson for his clone and i was told he's great to deal with.
90 Ton Hydraulic Press For Under $500 [Mockup]
One thing you need in these presses is speed and a the ability to controll it along with force and i don't see any of that in your design.In other words you need to be able to squeeze the material quickly and release it quickly and repeat before you lose the heat in the material thats why hydraulics are the best.Save your cash till you can build or buy a press..I'm not trying to be to critical on you but i've built one so i got a bit of experience around them and if you look around long enough you can gather the parts and build a nice hydraulic press..
Hydra Hammer/Press
Nice set up ..
Welder Questions
I would give my eyeteeth just have one of those torpedo welders by lincoln i've used a couple in my time nothing better to me and i love the look for in the shop painted in the red or blue colors...
Found "my" Tombstone Welder !
I bought a lincoln 200 amp square wave tig 2 years ago its an inverter i love it its compact and can be plugged in to 110 or 220 plugs i got it for aluminum but it does stick and tig nice and smooth i'm starten to throw this in the truck when theres power available and leave the mobile home the odd time. Stay away from the chinese stuff on the interweb yeah its cheap but eventually your going to pay. Stick to the tombstones and thunderbolts they are bombproof i got a 40 ish year old thunderbolt still in the shop on hot idle just in case lol. If ya wanna try tig all ya need is an acdc version of the before mentioned machines and scratch start tig is what you'll be doing before to long... Stay away from the online opinions on gear talk to some welders that use the stuff everyday,same as gear for any other trade. Oh and more thing about the machine i got, i hate digital displays but this one is pretty basic but the tech coming on new machines is overblown in my opinion. Years ago all we did was reverse the cables on a acdc and weld. We listened to the rod and watched the size of the puddle for heat cause most of the amp switches were crap no teck can replace that. So practice practice practice no matter how much the esab rebel is pushed as the 2'nd coming. Digital displays don't replace experience..
Juggernaut Forging Press
Nice set up i built mine the same on the hydraulics set up for the same reason low profile and shrouds work fine i like the curve on top i used 4'' tube to build mine basically a simple h frame. Mines at 19/20 ton range it crushes and punches everything i feed it i got to get some time to add the foot control i only been waiting 3 yrs to hook the foot lever up lol. Again nice build by.
Finishing Stainless/Inconel
To much work for me lol think i'll stick to a wire wheel or a scotchbright buffing wheel on the pencil grinder.
Welder Questions
In my shop i run a 50 amp breaker that runs a stove plug recepticle my welders plug into that along with my press there not run at the same time lol but that handles all the heat i wanna run in my welders no problem ,for example.A 20 amp breaker will kick out alot welding you might get away with a 110 machine but it all depends what your welding the old machines like a your talkin about will need amps so i'd say hook up a stove plug set up if ya can or get a price from an electrician..
Forged 1084 antler, birch bark and brass
Nice knife i really like the shape and handle..
What it means to be a "Certified Welder"?
Go to school get a job welding figure out what kind of welder you want to be actually get tested in those procedures and work in the field for awhile then get your journeymen ticket certified welder does not happen overnight.Alot of people think there great welders cause the can stick two metals together but untill you actually had your welds inspected,xrayed,die tested or ultra-sounded or various other test and your welds are passed by a qualified inspector you are not certified as a welder.You will just be a person who can stick two peices of metal together so go to school then get a job welding and so on.It takes alot of hours to get certified as a journey men good luck enjoy the journey it takes about 7500 hrs to get there give or take i know i just retired but ya never really retire lol....I just checked the dept of labour site up here its been lowered to 6000 hrs up here don't know what it is in the states.
Hydraulic Press Builds
I used Randys book to build mine i've been usin it for over 2 1/2 years the biggest thing i learned is speed of the ram is more important than tonnage as long as you got 16 ton or more of squeeze. I'M gettin around 21 ton out of short 10'' stroke piston and a 5''' dia cyl with a 5 hp motor with a fast dual stage pump in a simple to build h frame.
- How big of a hammer
Converting an inverted hydraulic press into a light-duty forging press
It sounds worse off the pump that things toast i didn't think it was the pump side but it was hard to tell in the first vid..
Hard to say from the vid it sounds like the shaft is hitting something it can't be the pump if it didn't do it before with the old motor so i would send it back but i'd try the old motor first to make sure its not the pump side of the connection.Nothing worse then sending something back and it wasn't the problem.....
Well thats a good price so what are you goin to do get a 5hp since the 3hp doesn't work good enough i think mine was around 2400 for parts and material from scratch things are a little more expensive up here.
Any atlantic canada knife makers here?
Theres lots most guys are on facebook in the Maritime Blacksmith Assocition.
What do figure the final cost is from start to finish.
