381 -
Everything posted by bubba682
Newbie Power Hammer Questions
bubba682 replied to NewfoundlandLaw's topic in Power Hammers, Treadle Hammers, Olivers
Newf i got the same hammer mine gets warm as well the oil can be slowed down by turning the screws and the oil goes everywhere out of the ram lol but they work great. -
Hydraulics are not compressable but isnt your plan goin to use the cyl to push against the h frame which is welded to the table or did that change but anyway not to dribble on if thats the plan go down to a local pro shop tell them your weld plan.Get there advice on if ya got enough amperage in that mig or at least go over to the hydalic press building site on facebook and ask that ques from guys that build these presses.
I got a 170 lincoln amp mig that runs on a 210 plug and i wouldn't trust it for those forces it would be differant for me if i had a big shop mig but those little ones i've got ,give me doughts , stick ya know your getting good fusion and penetration .If you weld to the table top your definatly going to have to preheat where your welding or i'd say your going to get some cold lap,lack of fusion into the plate.And thats where that weld can fail 18 ton will go thru your roof and if you start playin with the detent then i think that'll drive the tonnage up and stress those welds more.Talk to some certified welders down there see what they think and what process you should use don't always be leave whats shown on the inside of a mig welders cover better to be safe than dead or worse...
If it were me i would weld an h frame to the table i'd use 2x4 tube steel at a 1/4 '' thick minimum, the table in the pic looks 1'' thick so i would sweat the weld zone on the table to 250 deg stick weld 3 passes all the way around the tubes .I'd put wheels on the legs i love being able to move mine around the shop and you will want to increase the speed of the ram speed is your friend on a press.I think i read your at 18 ton thats no joke your welds will be tested make sure theres no undercut or porosity and thats more than enough squeeze everybody now wants 50 next it'll be a 100.Mines at 24 ton its been squeezing steady for a year
Hauling a hammer a LONG way
bubba682 replied to RKM556's topic in Power Hammers, Treadle Hammers, Olivers
I had mine shipped it wasn't to expensive and alot cheaper than me driving up and back to get it i asked for it to be delivered on a truck with a lift gate and a strong enough pallet jack .WE had it off the truck and in place pretty quick very little lifting and rigging required. -
On mine Peppie i used a shaft off a shear tooth from a continuous miner and a i cut the web off a railroad track and flattened the track on my belt sander to make combo dies i wish i had access to a good machine shop that did little jobs for a half decent price.I'm lookin at gettin a small mill for doin my own little machining jobs.
Air hammer foundation
bubba682 replied to Cast and Forge's topic in Power Hammers, Treadle Hammers, Olivers
I anchored my 33 lb anyang to the garage floor with ready rod and dewalt bolt compound i put a 1/2 piece of plywood and a rubber pad under it the floor is about 4-5'' thick its solid no movement..The hammer and base weigh 1200 lbs so far no problems and i don't expect any knock on wood... -
Its been so long working on the shop i posted this in the wrong section lol oh well thxs 58er for motivating me to finally redo my shop i built a new barn for storage and to give me some room.I got to finish the ceiling before winter and install a heat pump.I finally tuned the forge on this week first time in awhile.
how big of a shop do i need
bubba682 replied to lumettamichel3's topic in Building, Designing a Shop
LOL i started with a 24x24 now im building another 24x24 for storage its a sickness the wife say's .Go as big as you can afford thats my advice... -
I would grab it for that price and because its ac dc you can teach yourself tig welding as well now if ya get it practice practice and more practice...
Works good makes the same noises mine does they make life easier lol...
Nice footcontroll i think i might steal your design lol hope ya dont mind...
Peppie is right and where you live it should be no problem findin a certified welder to build it just keep your plan simple prep all the parts for the guy if ya can.Go down to your local welding supply shop chances are they can give ya the name of a certified welder that does small projects on the weekends for cash .What i did for the hydraulics is go to the supply shop told them what i wanted which is basically the workin parts of a wood splitter he done up a diagram to hook up everything up then i got a 5hp motor and had a friend wire it up.I think i had 12 hrs of welding time in mine at most 20 theres a referance for ya to ask a price on, i built a simple h frame nuthen fancy.You might save some money by askin around it defenitly won't hurt anyway good luck hopefully this helps ya...
Nuthens cheap in this rackett lol i got lucky on the hoses and connections i knew a guy that knew a guy who had the connections lol and the hoses to get it done for a pretty good price.What was your overall price i'll give ya mine just pm me to compare ...
As long as it puts the squeeze on is what matters looks good.
I'm just looking for what works no bs its to costly especially where im at in Canada its hard gettin componants thats why i asked im gettin ready to do my shop over then i'm building the forges so i'm doin my research for the gasser i want heat for damascus.So with that bein said along with the numbers you put up i'll start readin up on yours and start lookin at componants guess i got some readin thxs for the repiy
- 49 replies
- diamondback
- majestic
Lol icandry that last line you put on your post is the funniest thing i read in years...so Mickey what temps is your forge getting to..
- 49 replies
- diamondback
- majestic
I agree,and in most cases it doesn't take long for owners to become builders so it would also be nice to have the builders rate theirs from hottest to coldest for example to save new builders with time and money as well.I probably should of done a search first before typing that last comment oops...
- 49 replies
- diamondback
- majestic
Dan i agree a 100% i'm building 2 new forges soon 1 coal and the other a gas with an air blower i bought the 3 burner not knowing much about them at the time i took the dealers word especially since they forge damascus with them on forged in fire they must have them maxed out at 35 psi lol cause i had mine up to 20 and nuthin would fuse completly.There was alot of delams and it ate the gas.It is what it is time to move on for me at least we saved one guy the same mistake...
- 49 replies
- diamondback
- majestic
I got a 3 burner majestic it doesn't get hot enough to forge weld i have it hooked up to a 100lb tank it gets to about 2000 degrees .
- 49 replies
- diamondback
- majestic
Got to have a hoodie on especially when were out workin in the minuses alot of places up here require the fire resistance ones for the last 10 yrs that i can remember, i think they come without strings. UP here long sleeves are required when doin hot work cuttin ,grinding and welding and don't caught without gloves on by dept of labour they are starting to fine individuals who don't comply with the safety laws.
I just built one a few months ago there great tools its 24 ton but for skill set im a journeymen welder i'm not sayin you have to be one to build it but if your welding skill isn't there at those pressures you'll find out quick.Other than that there not hard to build and they save alot of arm work all my hydraulics are based off a a wood spliter except the cyl.Mine cost about 2400 to build but i live in Canada where prices are higher.Just for example its 65 bucks for 5lb of 7018 welding rod...
I finally done the math on mine i'm just over 24 ton and its crushed everything i put thru in the last 8 months so with yours hittin the same tonnage it should be fast and strong which is what you want.One problem i had at first was cant like Jspool was talkin about i just welded in more reinforcement problem solved i think you should be fine you've got lots of reinforcement but its somthing to check right away and get corrected once you start squeezing.It can cause uneven wear quick in the movin parts.And one other thing you'll find out quick is if your freinds a good welder or not with 24 ton...Thought i'd finish with a little welder humor your welder bud should get a laugh out of it...
We go by cyl size here when we build thats why i asked so 4'' is good 5'' is gooder anyway it'll be a fun build to do i enjoyed building mine.
I like it if the price is right a 4'' stroke is fine see if you can get the controlls and pump from a log splitter it can't be hard to get a 5hp motor in the states used , dont quote me on the math but you should i think get it pushin 15/20 ton fast.What size is the cylinder its hard to tell in the pic.
