382 -
Everything posted by bubba682
swedefiddle if your gettin alot of groaning and creaking in your press send it back and get your money back.I thought John Little only did traditional work when did he go modern with a preess..
Build it yourself..
Hopefully once you vacation thru the country and figure out if you wanna stay i hope you got your own blacksmith gear its expensive to get here especially if you can't make your own tooling.Differant parts of the country will probally pay better than others depending on what you hope to make and your skill .You'll probally have to show on paper you have the skills and our immigration is hard to deal with at times cause of politics.And if you rent a car try to get unlimited milage cause were a big spread out country anyway goodluck if ya got any ques i'll try and help you out....
5hp motor, what components to buy for a decent 25 ton
bubba682 replied to Levi Prince's topic in Presses
From one canucklehead to another i went with a 5hp motor and all componants came from princess auto almost 3 years still sqeesin got about 20t its all you'll need make a flat die and a fuller die they'll do the bulk of your work. -
Something is off cause i got the same set up my press is fast with the 5x10 ram and i'm pretty sure my pump is a little smaller i ain[t no expert but you should be fast and have alot of squeeze so something is defiantly not working right.What is your reservoir capacity mines 5 gallon
Anyang ST - The real deal?
bubba682 replied to Jonnytait's topic in Power Hammers, Treadle Hammers, Olivers
I bought mine a 33lb from the Toronto blacksmith shop great service and its a clone of the anyang and the way i look at whats the difference there all made in china they all run the same parts .I've had it two years and for a compact hammer it has great control and hits hard and if i was a bettin man i'd say most are all made in the same shops and sent out under differant names.I have a buddy that bought a used one that was busted up pretty bad and he got his parts from James Jonhson for his clone and i was told he's great to deal with. -
One thing you need in these presses is speed and a the ability to controll it along with force and i don't see any of that in your design.In other words you need to be able to squeeze the material quickly and release it quickly and repeat before you lose the heat in the material thats why hydraulics are the best.Save your cash till you can build or buy a press..I'm not trying to be to critical on you but i've built one so i got a bit of experience around them and if you look around long enough you can gather the parts and build a nice hydraulic press..
Hydra Hammer/Press
bubba682 replied to Broad River Forge's topic in Power Hammers, Treadle Hammers, Olivers
Nice set up .. -
I would give my eyeteeth just have one of those torpedo welders by lincoln i've used a couple in my time nothing better to me and i love the look for in the shop painted in the red or blue colors...
I bought a lincoln 200 amp square wave tig 2 years ago its an inverter i love it its compact and can be plugged in to 110 or 220 plugs i got it for aluminum but it does stick and tig nice and smooth i'm starten to throw this in the truck when theres power available and leave the mobile home the odd time. Stay away from the chinese stuff on the interweb yeah its cheap but eventually your going to pay. Stick to the tombstones and thunderbolts they are bombproof i got a 40 ish year old thunderbolt still in the shop on hot idle just in case lol. If ya wanna try tig all ya need is an acdc version of the before mentioned machines and scratch start tig is what you'll be doing before to long... Stay away from the online opinions on gear talk to some welders that use the stuff everyday,same as gear for any other trade. Oh and more thing about the machine i got, i hate digital displays but this one is pretty basic but the tech coming on new machines is overblown in my opinion. Years ago all we did was reverse the cables on a acdc and weld. We listened to the rod and watched the size of the puddle for heat cause most of the amp switches were crap no teck can replace that. So practice practice practice no matter how much the esab rebel is pushed as the 2'nd coming. Digital displays don't replace experience..
Nice set up i built mine the same on the hydraulics set up for the same reason low profile and shrouds work fine i like the curve on top i used 4'' tube to build mine basically a simple h frame. Mines at 19/20 ton range it crushes and punches everything i feed it i got to get some time to add the foot control i only been waiting 3 yrs to hook the foot lever up lol. Again nice build by.
To much work for me lol think i'll stick to a wire wheel or a scotchbright buffing wheel on the pencil grinder.
In my shop i run a 50 amp breaker that runs a stove plug recepticle my welders plug into that along with my press there not run at the same time lol but that handles all the heat i wanna run in my welders no problem ,for example.A 20 amp breaker will kick out alot welding you might get away with a 110 machine but it all depends what your welding the old machines like a your talkin about will need amps so i'd say hook up a stove plug set up if ya can or get a price from an electrician..
Nice knife i really like the shape and handle..
What it means to be a "Certified Welder"?
bubba682 replied to OnaMcD's topic in Welding/Fab General Discussion
Go to school get a job welding figure out what kind of welder you want to be actually get tested in those procedures and work in the field for awhile then get your journeymen ticket certified welder does not happen overnight.Alot of people think there great welders cause the can stick two metals together but untill you actually had your welds inspected,xrayed,die tested or ultra-sounded or various other test and your welds are passed by a qualified inspector you are not certified as a welder.You will just be a person who can stick two peices of metal together so go to school then get a job welding and so on.It takes alot of hours to get certified as a journey men good luck enjoy the journey it takes about 7500 hrs to get there give or take i know i just retired but ya never really retire lol....I just checked the dept of labour site up here its been lowered to 6000 hrs up here don't know what it is in the states. -
I used Randys book to build mine i've been usin it for over 2 1/2 years the biggest thing i learned is speed of the ram is more important than tonnage as long as you got 16 ton or more of squeeze. I'M gettin around 21 ton out of short 10'' stroke piston and a 5''' dia cyl with a 5 hp motor with a fast dual stage pump in a simple to build h frame.
How big of a hammer
bubba682 replied to Millennial Blacksmith's topic in Power Hammers, Treadle Hammers, Olivers
I got a 33 anyang myself its all i'll ever need well that and my press they make life easier but i must say there seems to be alot of envy in the blacksmith world lol... -
It sounds worse off the pump that things toast i didn't think it was the pump side but it was hard to tell in the first vid..
Hard to say from the vid it sounds like the shaft is hitting something it can't be the pump if it didn't do it before with the old motor so i would send it back but i'd try the old motor first to make sure its not the pump side of the connection.Nothing worse then sending something back and it wasn't the problem.....
Well thats a good price so what are you goin to do get a 5hp since the 3hp doesn't work good enough i think mine was around 2400 for parts and material from scratch things are a little more expensive up here.
Theres lots most guys are on facebook in the Maritime Blacksmith Assocition.
What do figure the final cost is from start to finish.
Spent close to 15 yrs cdn army alot of it in the infantry in a recce plt 2 tours middle east i was the best rank of all a sarcastic old cpl the rest of my time was spent as a mechanic.I spent 6 months on Ellsmere island about 450 miles from the true north pole .Worked with alot of american herc crews went to Thule greenland one time on a US herc for a steak at a place called the top of the world club the ride cost a couple of pair of cdn winter sunglasses...
Kozzy i couldnt agree more with ya ...
Hit the upright piece with a hammer if it holds ya got some fusion if it don't clean it and try it again do that a few times till ya figure out to run a proper bead ,and remember nobody was a pro the first day...
