Everything posted by Dragons lair
Making a leaf spring out of a sword
If the spring has broken 3 times I would say your living on borrowed time now. Pay the experts if it fails and ya get hurt sue um. Had a co worker yrs ago in FL Had a 150K boat. Only trailered it 2-3 times a yr. Broke a spring thought "I can make a new set" 25 miles up the road hit a pot hole. Springs broke rolled the boat. Ins investigator spotted the springs and would not pay. How much are your parts/life worth? Ken.
Anvil quality advice
Second that, Have run the gasser over 1/2 hr with the doors closed. Small exhaust fan at roof peak. CO meter never moved. Drove the JD in for maintance alarms went off in less than 30 sec. If ya run any thing inside get atleast a CO meter or better yet A CO& gas meter. Ken.
carburizing and anvil?
Ya need to put up some pics. Unless ya have a good background in welding Find someone who is a welder and has repaired anvils before. There are several posts here on anvil repair. Hardface comes in many forms. Underlay, abraiaison resistant and impact resistant. Rockwell varies about 30 points. Some listed As welded some after work hardening. Tell us where ya are someone here may be close. Ken.
What can you tell me about this old post vise?
The bracket has 2 wedges to tighten it on the leg(drive one one way the other the other way) The ears on the bracket sit on the bench or post. Mount in the ground? If your not using a post or bench(welded to a rim/tub of concrete) replace the bracket with a U bolt to hold the spring. Have one just like it No clue to age or mfg. Ken
Is it ridiculous to think this?
Just a note here. The question was can he make $12-15 PROFIT. My shop is dormant at the moment. That $600 a mounth overhead still comes due every mounth. Can it be done? Sure ya just need to add in the overhead. A few steady outlets are what ya need. Ken
Clay Tire Hammer
Around here drop prices are 50% of new. Scrap is about $.20 a lb. Scrap is always cheaper. Ken.
Anvil ID
Only if he got the # reversed. Trenton Has weight on left And serial on the right. Ken
My gloat (i think)
Keep the iron HOT Vulcans that small can't take a lot of cooler hammering. Ken.
What happened to this anvil?
Where ya getting them? Here in WNC a 100 lber is $607. A usable 300 lber vs a new 100 lber I am going heaver every time. That anvil is 20 minutes from me. I already have a 88 and 142 lb H-B and a 194 lb trenton total cost $610. Ken.
pricing
Phil, Hope ya got something for cutting his labor costs by 75%. Beer? Had one friend stop by "I need to finish this today can I borrow your gasser anvil and hammer" I had to tell him. Bring your own gas anvil and hammer. Or buy some coal for your forge. Says I can't afford it. So what do I get for making him money(lots) Nada Zip Ziltch. At this time my welding/blacksmithing shop is closed so no income still paying the overhead. Oh well 1 less FRIEND. Ken.
Old welder and ... family politics
Yes they do die. place I worked had an old dialarc HF 250. One day I started seeing reflected sparks in my hood. Got one of the guys to watch. He says you watch now. Looked like a cutting torch under the welder. The main transformer(copper) was melting. Finished the part and it was still working. 4weeks and $780 later I got it back. Bought it when they closed. Used it in my own shop for 2yrs then upgraded to an older 330 A/BP. Ken.
High Speed Hammer Company
The smaller one was described as a rivit hammer. By the same mfg. Ken.
Off To War
Harold, Two words for you and yours, Semper Fi. Ken
Hello from POrtland OR...need heat!
How fast can ya cook a pizza at 2400 degrees? Pulling your leg. Solid fuel or gas? Don't think ya can go less than 36 inch for a pizza oven. Would think indirect gas oven around 36 in would be doable.
Vintage Aluminum
Just think of the ball gunner(belly turrent) landing with the runway a short way from your butt. And I thought door gunner in a chopper was bad. Ken.
heat dam?
Yeh have used that one and the gel from the big box stores. They do work. Still need to work as quick as possable. Try it on some scrap so ya know how long ya have. I have moved inlets and outlets on them without the gel. Now I have a bottle sitting on the tigger. Ken.
So, Whats your favorite shop Machine?
Hey Mike, I didn't count your 3 as they are in the office(with the AC) So the handles are the same. Ken.
Inhaling Coal smoke
No matter what fuel ya use spend the bucks for a good CO meter. If ya got gas get the one that reads both CO and propane. About $50. Ken.
Another hook
Tried one like that. Was harder to drive it in. Ken
It followed me home
Bentiron, seems I remember reading semisteel is chilled cast iron. Ken.
what are they worth
I would not pay more than $1.50-2.00 a lb for either. That being said. How many turn up un your area? Might check craigslook. If ya don't pick an area it will give ya the whole country. Also depends on your idea of good condtion. I like mine with flat faces, unchunked edges, minimal cuts and dings. A beat up brand name is no better than a minty bottom of the line brand. Ken.
Phil, After ya clean out the crud in the holes get an approprate size bore brush. Chuck in a drill and polish them. Boss was gonna toss one cause of bad contacts. Ken.
Favorite machine would be the one that helps me do the job. Ken
pricing
Had one of those the other day. Have done a lot of farm repairs for him and his dad. Called on Sat Asked if I could do a 10 min fit up on a push bumper. 2 1/2 hrs later it was done. If ya haven't done it before and well go with the clock. Ken.
spruce pine festivals
Hey John, Is it all weekend? I might try for Sunday. Ken
