828 -
Everything posted by Dogsoldat
How to deal with a curmudgeon
Dogsoldat replied to evfreek's topic in Welding/Fab General Discussion
Makes me think of a friend that home schools. She was having a xxxx of a time with math and her youngest. Then things started to click into place... A month later Mom realized she had grabbed the wrong book to work out of and now the kids a year ahead in her math. -
That made my day! Must be a tremendously great hammer that swings itself for that price
Peening both sides of a plate or knife
Dogsoldat replied to Jonah k's topic in Blacksmithing, General Discussion
Good to see I have learned a few things here. -
I may be wrong, but you should be able to put your work on a block of wood and peen the other side without mucking up the texture that's against the wood. A spring swage would be another way of doing it -
Hi, there is a guy out in Westbank Summerland area and another out in Joe Rich (BCRob I think). I'm out in Greenwood. That's the closest of us that I can remember right off hand
Not it, but thanks for something interesting to watch.
I started beating on some copper a friend gave me one day.
Dogsoldat replied to kustomizer's topic in Copper Alloys
Awesome work, minus the spurs it makes me think of my Dad and his various boots and hats over the years. -
you have to take into account the included angles of your cutting edge and what it's for. Pretty sure that a cold chisel can get away with being harder and a bit more on the brittle side due to the angle of the cutting edge and the support that that offers. A feather fine edge will be more prone to chipping the harder it is.
Was a short video. Maybe 5 min tops. It could have even been a bone handle now that I think about it more. Anyways not what I was after but same idea. http://www.hewn.ie/blog-content/2015/2/23/making-an-antler-knife-handle
Did anyone else notice the dies used in the press to shape the Viking sword last night. Thought that was a pretty slick idea.
Been thinking of it all day at work. Nothing that really stands out. Guess I'll keep plugging in variations into the search engine and see if it gets me somewhere. Be sure to post it if and when I find it
Pretty certain but, not positive that there was a youtube video posted of a guy drilling out an antler. Fitting the tang in a dowel and epoxying the works together. My google is weak tonight and I was sure I had saved the link to my computer... but have had to format and reinstall since. Have a coworker that is being brought over to the darkside. Gave him a small blade to put a handle on. He's tying to figure out how. Figure that with how skinny the tang was on this blade it's his best bet in the chunk on antler he was telling me about.
The small gauge stuff used in the mines around here for the carts might work well in a similar application. Need a little more snow gone and I can go exploring.
Maybe design the handle so the horn/antler section can be easily replaced every now and again when needed.
Oil stains after heat treating
Dogsoldat replied to Bastian Sweeney's topic in Heat Treating Knives, Blades etc
Still have to finish grind and polish the blade right? Little sanding and you should be good as new. Keep your eyes open for some used veggie oil. much nicer to work with. -
I was trying to remember how I had done it before when I had started a few more this last weekend. I think how I was doing it was step it down behind the lump. and take it to the bench grinder till the tenon fit the monkey tool I had made. Stick it in the clamp and set the shoulder with the monkey tool. You do have to be careful if you reheat the peened end as the copper heats much faster than the steel and you never seem to get a proper fit afterwards. This is were a good known mild steel works best along with a long slow cool down so it doesn't harden any. I do remember I ended up with a piece of medium/high carbon round that would air harden easily being so small. That set of stems ended up in the scrap bucket simple couldn't peen the end over. Can't remember whether that curved chisel was for roses or something else but it does help on the copper sepals.
That must be a piece of 3/4" tubing Das. The 1/2" tubing I unzipped this last weekend is 1 7/8" wide when flat. I cut out the circles, drill the 1/8" center hole. Stack like petals together with a nail or drill bit though the holes. Clamp in vise and cut between the petals with a hacksaw. Then a few nips on the corners and the right shape is achieved. Texture and Dish. Anneal, then they are ready for assembly. I hope my plans are clear enough to help out.
In the picture of the chisels you can see the start of some small copper roses. 1/4" round for stems and leaves and the tubing I had kicking around was 1/2". with the copper I have been using three layers of petals. I'd have to dig out the measurements for the diameters on the petals but can post if you like. Other thing with copper pipe/tubing is anneal between steps. Comes fairly hard as drawn.
I've notched between the petals with the super thin zip disk and made a really narrow chisel to cut out the outside. Not the fastest but does go good once your in a groove. The material I have been using for petals has been a 45 gal drum. the stems and leaves are made from 3/8 round.
Looks very much similar to a stake spring or a mudflap spring from a logging truck. in a pinch we have heated the end up and bent whatever we needed for a loop in . They do tend to wear faster or depending on load straighten out. But it does buy time to find the something new.
Ideas for these camshafts?
Dogsoldat replied to Quench.'s topic in Blacksmithing, General Discussion
What about a windmill that has something moving. Say a blacksmith and striker/ power hammer come to mind -
heres mine and some measurements if they are legible. thought I had another larger rustier one but maybe I never bought it.
Been through the whole shovel or handle thing a few times... never fails find a nice one you like and the handle gets thrashed.
Heres another idea for birds guys. Was looking for axes and these popped up. There was even one painted red and black that looked very much like a vulture. I believe it also had a pick for a head.
