Everything posted by Dogsoldat
Are bellows required?
Can't find some canvas and give it a wash in borax to make bag bellows? may loose a little efficiency to air loss but rather minor. Nothing says the bag bellows MUST be leather...
one-piece hawk
I like it a LOT! The fuller down the handle just makes for a little icing on a beautiful tool.
- Can you over forge metal ?
Forge welding a chainsaw bar for a tool?
couldn't say without looking at the bars.
More cable damascus...
That's a darned nice looking knife! Bet the customer is pleased, even if your not.
There was a guy nearby that was making stock removal knives from them, They buffed up something shiny. Seem to remember that they may have been 1095 or equivalent.
Special swage block
Looks like a few of those holes are for adzes or mattocks. Very cool.
Gate Progress
Thanks guys! Just making it up as I go along...
Gate Progress
Slowly sneaking up on it. Not sure that I will have it done by June 7th, but we will see. Was hoping to be a little further along but had company for the long weekend and all sorts of rain. Need to check out the steel rack at work and see what there is for 1/8 x 1" strapping to simplify bullrush leaves. Otherwise start flattening a bunch of 1/2 round. Hmmm... looking at the one picture I may have to spread the 'M' a little wider.
How to cut a rail road track
A couple of bicycle wheels and a piece of treaded rod. tie the rail to the axle near the balance point and wheel it out.
Few different things on the go
Was going good for a while, had lunch cleaned out a huge clinker. Watched the rain coming down the valley. Think my fire was choked off from to many small (pea size bits of coal) couldn't get the air through. Wasn't making heat for me again. Packed up just as the rain rolled in. Anyways I think I have a good bit of the gate filled in in my head... just a matter of getting to it.
I caught the Bug in Point Barrow, Alaska
Talk your friendly mechanic into taking a strip off one end of that sharpened cutting edge, and then split that in half and you'll have 2 cut offs. One can be notched and wrapped with a rod for a handled tool. The other can be for your hardy when you figure it out. Looks like you are off and running with the scavenging, packrat gene must be strong, you'll fit right in
How to Strongly Magnetize Tools with Your Welder
The welder would have to be set up for DC, If AC it breaks the magnetic field in an object
Can Silver and Steel be combined to create a viable blade
Correct me if I'm wrong... but I thought electricity went around the outer surface of an object, same reason a farady cage works. So why not plate it with a more conductive surface rather than trying an alloy. may end up with the best of both
One of the drivers from work let me come over and play with his plasma cutter for a bit. WOW! Now do I ever want one. Managed to get the rays of sunshine done. Bit of forge work and welding and I'll have the one corner of the gate filling in. Have to get moving so it's done by June....
welding question
have you tried preheating your melting pot before welding. and just because its cast iron doesn't mean it will explode when quenched, just means that it has the potential to fail.
"On The Beach" blacksmith survival game.
was there a fire axe somewhere in the fishing boat that was being pilfered?
Using Flux As Decarburization Prevention?
I'm thinking that fluxing for heat treat has more to do with scale prevention than decarb. But that's more of a guess on my part.
Almost spent some money
Some coolness at the Kamloops Gunshow. REALLY should have bought them both.... but $300 was a bit more than I had for spending money. First is a Finnish hewing axe (guy had it labeled as English as that's where he had gotten it from) The other is a Goosewing hewing axe. ohhh! did it feel good in the hand. One table had a Massai spearhead about 2' long, should have grabbed a pic of it and more Ruger #1's in calibers I'd love to have than I seen at a show yet.
Heavy Eqt welder ? = Help
We use arctech 223 rod at the shop. Basically a 7018 rod. Bbuild up, either cylindrical stone on the angle grinder or a carbide burr in the die grinder and a finish smooth up with a flap wheel in the die grinder. Just spent a few days doing all the grapple pins for the track loader (322 hoe with an Imac head). When the guy came in to line bore the articulation for the 545 skidder much the same process just had the tooling to machine it out just so. And as far as I know the few rod ends we have sent to a local machine shop have only been welded and then re bored. Most often a new end is made and just welded on. No heat treats involved. But If you have doubts the dealership is phone call away.
Cool that makes sense. Appreciate the info.
Wanted to try something a little bigger, leaf spring seax started out 12" I screwed up and then I found a crack so it got shortened twice. doesn't seem to be any more surprises. Improvised bending jig for making a ring from 1/4 x 1 1/4" with a 11" diameter or so. Along with the lower corner pieces for a gate. While I had a bit of coal burning I used the heat to make a hardy that will be the base of a bending fork. And last but not least, anyone seen a tool like this before. The pointy bit slide in and out.
Hidden Poison
Well that might explain it... I do remember reading someplace about the wobble in the earths rotation changing. And you do have better leverage up there Frosty
It followed me home
To be honest I never even thought of looking for the strops and stones. Wasn't in the upstairs of the house and didn't see anything when I was in the basement, but there was wall to wall boxes and clutter. I am sure there is more than a few treasures stuck somewhere yet. I did ring the unattached stone when I picked it up, remember from the school safety videos how well they can explode. I figured the razor would give me a nice pattern to work from if nothing else
It followed me home
An old gentleman passed away a while ago and his daughter was supposed to let me go through his tools. Guess he had brought a woodworking chest with him from the Netherlands if I remember right. Anyways the kids were up grabbed the stuff they wanted to keep and sold the house last November. So never did get first look around. Driving by I saw a yard sale and the new owners were clearing things out. Found a few goodies. neatest is the top tool for forming collars on diamond drill bits. found a small rail anvil in a back corner, just didn't need it bad enough. There was an Assayers furnace in the corner. with a few small crucibles. Wish I had my camera at the house. Coolest though was the guy was talking about a few rifles and had found a box of 7x57 tucked in a corner. I found the rifle stuffed between the floor joists in the basement. Couldn't talk him out of it though. Externally it was in rough shape no scope no open sights and pretty rusty on the bottom side from were the mice were living on the blanket it sat on. Bunch of other odds and ends there but anything better he was holding onto for now. Spent $40, oh and a small kids compound bow that my daughter had already walked off with. as they are getting interested in archery
