ThomasPowers Posted May 9, 2018 Share Posted May 9, 2018 I read that as 4310X (some other number) Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 10, 2018 Share Posted May 10, 2018 Looks like 43106 to me I think I can see the top of the six in one pic. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted May 10, 2018 Share Posted May 10, 2018 Me too... Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 10, 2018 Share Posted May 10, 2018 I think the circular Wrought starts with the W at 9 o'clock Quote Link to comment Share on other sites More sharing options...
JDC Posted May 11, 2018 Share Posted May 11, 2018 You all have better eyes than I do. but now that you mention it, a six might be it. Anyone know how to date the anvil? Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 11, 2018 Share Posted May 11, 2018 Start with an informal get-together for lunch or coffee, which is a great way to get to know each other without the pressure of dinner and a movie. Listen more than you talk. Respect the anvil's boundaries, and don't try to take things too far to fast. If it's right, you'll both know. Quote Link to comment Share on other sites More sharing options...
JDC Posted May 11, 2018 Share Posted May 11, 2018 So I brought this home, had it sand blasted, then repaired a 4" crack on the back top of the slide and made up a new 45 degree lower end corner of the slide, corner that had been busted out. Previous welding on the fixed body where the lower jaw meets the body, on each side, looked like clay had been smudged on. Not a weld form I've seen before - very wide weld likes, about 1/2" wide 'smudge'. Ground that off a bit. Same type of welding on the lock bolt where the top/base meets the screw, which had the old top/base welded to the top of a bolt head. Filled the spaces and cleaned that up. Fun time. Quote Link to comment Share on other sites More sharing options...
JDC Posted May 11, 2018 Share Posted May 11, 2018 34 minutes ago, JHCC said: Start with an informal get-together for lunch or coffee, which is a great way to get to know each other without the pressure of dinner and a movie. Listen more than you talk. Respect the anvil's boundaries, and don't try to take things too far to fast. If it's right, you'll both know. We are definitely on The Love Connection Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 11, 2018 Share Posted May 11, 2018 About 8-10 feet of twisty rebar picked up from the side of the road on the way to the airport, a 6 lb or so lead sash weight that was given to me by someone I was meeting with on other business, and the obligatory note from the TSA. (The rest of the scrap was already in the car.) Quote Link to comment Share on other sites More sharing options...
JDC Posted May 11, 2018 Share Posted May 11, 2018 Nice pickup. Using that for a forge? Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 11, 2018 Share Posted May 11, 2018 No clue. We'll see what projects present themselves. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted May 11, 2018 Share Posted May 11, 2018 JHCC, I too have found that if you keep a little scrap in the vehicle that it helps to attract more to you.... Quote Link to comment Share on other sites More sharing options...
JDC Posted May 11, 2018 Share Posted May 11, 2018 I'm planning on setting up a small forge this fall, after all the fun summer kid events/distractions. Have to do some reading. I'd like to make something long enough for about 3-4 feet lengths. I don't think the font sizing is working for me here . . . I'm using 14 and I still need my telefocals. 12 minutes ago, BIGGUNDOCTOR said: JHCC, I too have found that if you keep a little scrap in the vehicle that it helps to attract more to you.... That't a good one, made me smile. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 11, 2018 Share Posted May 11, 2018 Gotta tell us more about what you want to do. You can forge a 3' sword in a forge with a 6" hot zone but doing an even twist on a 3' baluster of 1" steel may take a sizable heated section. Will your forge be burning: wood, charcoal, peat, lignite, bituminous coal, anthracite, natural gas, propane, electricity? What tools/skills do you have or can access? Details!----Like on my computer all I have to do is ctrl+ to get the font to expand, I'm running Chrome on Windows 10 and on KUBUNTU Plasma of course ctrl- shrinks it. Quote Link to comment Share on other sites More sharing options...
D.C. Posted May 11, 2018 Share Posted May 11, 2018 A good day! The stone is from a trip to the local landfill to make a deposit, and the steel is from a logging companies scrap pile. They use 2" 4140 for stakes, And the bent ones get thrown in the bone pile! Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 11, 2018 Share Posted May 11, 2018 1 hour ago, JDC said: I don't think the font sizing is working for me here . . . I'm using 14 and I still need my telefocals. Try ctrl + and enlarge the size in the window. Every once in a while Iforge will revert itself to some tiny little screen size and I can't read anything. Ctrl + works till I find where I can change the view size in the setting. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JDC Posted May 11, 2018 Share Posted May 11, 2018 1 hour ago, ThomasPowers said: Gotta tell us more about what you want to do. You can forge a 3' sword in a forge with a 6" hot zone but doing an even twist on a 3' baluster of 1" steel may take a sizable heated section. Will your forge be burning: wood, charcoal, peat, lignite, bituminous coal, anthracite, natural gas, propane, electricity? What tools/skills do you have or can access? Details!----Like on my computer all I have to do is ctrl+ to get the font to expand, I'm running Chrome on Windows 10 and on KUBUNTU Plasma of course ctrl- shrinks it. Yes, at this time my thoughts are pretty general and still in the clouds. I'd most likely be using some type of gas. I'm thinking of building the forge, but that could change as I get into the meat of the subject. I did see a gas forge for sale, it appears to be about the size of a 55 gal drum. The owner said it's too big for what he needs now. I don't know enough about forges to have a clear idea of what I'd need or would work well. Those ideas will come this summer and fall as I get time to do the homework, in-between visiting the kids and other obligations. I'm looking forward to the research. I received some 1/2" ball bearing this morning, and was disappointed in the ball bearing drop test on the Trenton. Maybe about 50% rebound. So I took out a few older, small blacksmith ball-peen hammers to test rebound. Three of the 4 did poorly. One of the hammers had very nice rebound. I'm going to look for a more scientific method to test the hardness. If I use the 'edge' of one of the hammers face, and do a small whack, it will leave a very small edge indent. So I'm questioning the greater and also central portion of the anvils hardness. By visual appearance, the anvil seems in pretty good shape for it's age, and it has just a very shallow saddle, about 1/16th inch. The shoulders have some rounding, and gauging on my very new experience of owning an anvil, I'd say mild rounding. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 11, 2018 Share Posted May 11, 2018 Large gas forges are costly to run---it's like buying a dump truck as your daily commuter car because once or twice a year you need to haul gravel for the driveway. If the face of the anvil is CLEAN then that rebound is suspicious. (also check the ball bearing to make sure it's properly hardened, I've know folks to buy steel spheres for ornamental ironwork thinking they would do but they are dead soft too!) As anvils tended to be used in wooden structures here in the USA, fires were not unknown and could draw the temper of an anvil to quite soft. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 12, 2018 Share Posted May 12, 2018 A new phone and service provider followed me home today. I switched from IPhone I've had for years to andrroid so please forgive any new weird spelling errors or such from me. It's a learning curve. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 12, 2018 Share Posted May 12, 2018 When the tool rental guy in the big box store has bits for a Hilti jackhammer he no longer carries, you get them for a buck each. Quote Link to comment Share on other sites More sharing options...
Hans Richter Posted May 12, 2018 Share Posted May 12, 2018 Actually it follows the lady of the house (flower boxes on the windows). Please don’t call me names (like sissy or wiener) especially my fellow biker brothers. But the shop is connected right to the terrace and has to fit in to the back yard appearance. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted May 12, 2018 Share Posted May 12, 2018 All good Hans, like having a tee party with your daughters or grand daughters, catering to a good womans sense of style is an act of strength. A lesser man would bow to fear of embarrassment, while a great man reminds you that he one hands a 16# sledge and gets up after being kicked buy a ton and a half of horse. The lesser men generaly get the point, risk the ire of a real man or his wife, at your own peril. You do need to do somthing about those come comertial hangers tho. Quote Link to comment Share on other sites More sharing options...
Hans Richter Posted May 12, 2018 Share Posted May 12, 2018 My dear Charles, thanks for the kind words. Indeed to please the ladies is one of the most important duty’s we have. Have my hands full on the ‘big chief and my daughter’ and don’t even think of grandchild’s. Regarding the commercial hangers, it’s all about corrosion, and the free hanging garden decoration around it it’s all hand made. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 12, 2018 Share Posted May 12, 2018 Bikers I have met know the merits of camouflage! (and the merits of being seen/heard while on the road!) Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted May 12, 2018 Share Posted May 12, 2018 Then we are talking to a classical Smith, lol. If they look machine made then it’s exelent work Quote Link to comment Share on other sites More sharing options...
