It followed me home
nice find, perfect for getting those occasional bits of wire brush out of your fingers.
  • Replies 17.1k
  • Views 2.2m
At the local second hand store I picked up one of those little wrenches which you can weld another handle onto for twisting (been wishing I had one for years), and a 1.5 pound brass hammer. I figure I can use it for hot cutting, so as not to ding the hot cut face, any other uses?
thomas dean id show a pic but i cant get it to happen for some reason ill try later k
I'll keep checking back!
Last night a Champion #40 blower with the original stand and a box of ball peen hammers followed me home. The gears on the blower are in good shape and it turns smooth. Not much blacksmithing equipment comes up for sale in my area so I was very excited to find this blower.
14317.attach
14318.attach
14319.attach
This Henry Wright anvil followed me home from the N. Calif. Classic this weekend. It had a very bold price tag attached to it, $1220.00. I traded some iron work for it with no cash leaving my pocket. It looked as if there had never been any repairs on it, so when I got it home, I etched it in sodium bisulfate and water over night. Sure enough, it was all there. I did a little clean up on it, and the only damage is some slight pitting on the face near the horn and at the heel. Now I'll have to make a new stand for it and all new hardy tools, and it will be my new traveling anvil. It's sitting on a bigger Peter Wright anvil in the pictures.
14331.attach
14332.attach
14333.attach
14334.attach
14335.attach
man thats nice...some people have all the luck! you didn't say what the weight was?
Wow what a find the last henry wright that i looked at last year was really damaged and needed alot of welding. But we did save it and sold it to another blacksmith in southern Utah. But it sure is nice to find one that looks like that with no repairs.
Nice find and it always good to find a good trade once in awhile.
Gaylan
That is a very nice anvil indeed Brian, probably well worth the money you paid for it. My find is a little smaller but I was very happy to find it. For some time I have wanted a 4lb sledge hammer, but was wasn't willing to pay the $50 plus they are asking for them over here in Oz. On the weekend we went for a drive down the coast to investigate a coke supply company and went past a second hand shop, always worth a look, and came across outside a large rusty ball pein hammer head. The bloke wanted $3 for it, how could I refuse? I took it home cleaned up the faces, beveled the main face and hit it with wire wheel and bunged a new handle in. I got a new hammer with the weight I wanted, right on 4 lbs.
14434.attach
14435.attach
Edited by IanR
grammer
Nice one Ian, I envy your luck :)
I went hammer hunting today I still dont own a cross pein. :rolleyes:
Had my eye on a cheapo 3lb, I quite fancy trying a re-forge but despite two attempts to bring the the price down the guy still insisted it was a great hammer and worth more - I politely explained that hammer faces arnt supposed to mushroom.
Did pick up a reasonable 2lb straight pein - and one of those 3 legged cobblers irons, must be usefull for something.
at a recent auction I was able to obtain these 2 items, a nice pipe vice for 8 bucks and the cast Iron plate it is sitting on for 4, The plate will be set in the gravel floor for bar upsetting, it is quite thick and heavy.
The vise is a neon green Wilton with a 5 inch jaw. Fellow did not know what happened to the base and it was useless to him without a base, so it was offered to me. I think I can build a base (grin).
I was given a Buffalo 162H agricultural forge last week. We built new legs for it, and I've got to get a belt made and a new lever for the blower. It appears the grate is also missing in the fire pot. Can I still get one of these? I know some forge parts are still available, but not sure for which forges. I'll get a pic up soon.
Also an electric blower, I think it was a No. 3 Buff., and some tongs, including a set that has two parallel jaws about a foot wide. Pics of those will be forthcoming also.
Check out centaur forge. they sell a cast replacement Tuyere for $25.
Dave,
Consider going to the plumbing supply and buying a cast Iron floor drain cover. They are in-expensive and have worked great for me!
Ted Throckmorton
Every 6 months the local council has a "large rubbish' collection week. Each street gets a specific week to put all thier large stuff out front, and everyone that wants helps themselves, unless the council gets there first!
This time I got 2 hoovers which I hope will become 1 or 2 blowers. An end of a 55gallon drum that someone had brazed handles onto, I guess it was some type of table top thing. It's going to be a solid fuel forge. I also got a section of chassis with a tow ball on it. I cleaned up the end of one box section & use it for a hot cut, and the ball as sort of a nthing for bending stuff around. I'm sure it'll be usuful for lots of other things, but ideas fellas? Finally, I had to change an exhaust fan at work, and the old one had some ready-made legs for the forge, although they need extending. They're at the left of the photo.
I also recently replaced 2 fan pulleys, one 200mm dia. & the other 400mm dia, both dual vee. THey're cast & pretty heavy! Already used then stacked one on the other, on a milk crate, as an expediency anvil to mash a section of copper pipe into something else at work one day. I figure they'll maybe useful for bending around. Any other ideas welcome.
I think maybe I should add that I replace stuff at work because it needs to be, not becasue I want bits of it! :D
15227.attach
I wish my council did something like that. I doubt it would be allowed in the UK for health and safety reasons - groan.
I wonder if you could use the edge of the pulleys for decorative fullering?? Ive got a few too, so I will report back if I try it - if your pulleys have dished faces, could they be used for making bowls etc too?
I had a very luck day picked up a do all saw, horizontal saw, 13" lathe and hardinge milling machine, all I went to buy was a magnetic drill!
14632.attach
Edited by saintjohnbarleycorn
I would like to find one of those DoAll bandsaws. We kept one around work for quite a few years after the saw "Died" just for the use of the band cutter/welder/grinder. It worked very well. Now you can buy band in bulk, various pitch and width, just cut and weld to fit different saws.
WOW, what a score!
Where's the mag drill or did you forget to get it in your excitement?
Frosty
The welder is pretty easy to use, just takes some practice. Clamp the blade in each side, set heat and pull the lever to weld. (it will squeeze the blade clamps together at the same time) Make sure you anneal the blade after welded while it is still in the clamps, there should be a button on the welder for this. After welded and annealed take out of the clamps and grind the weld joint smooth.
You should be able to get bulk band at any machine shop supply or industrial supply house. I would just keep your eyes open for it to go on sale. I have also found rolls of it really cheap at business liquidation sales and shops that are going out of business.
16 hammers - mainly ball peins including a nice George Barnsley cobblers' hammer, an interesting hand forged cross pien (at last!!) a couple of lumps for possible reworking and a chipped claw hammer destined to become an adze, and a handfull of chisels/punches followed me home this weekend.
Total Cost:
Deb and I have developed a little after church tradition, have brunch and then hit some garage/yard/etc. sales. The last few weekends have been pretty disappointing so we weren't planning on hitting any today. However, on the way to brunch we passed a well done home made garage sale sign so on the way back we decided to hit this ONE sale.
Now, to diverge slightly, have you ever had a job you were dreading? Well, after drilling two holes to tap for 5/16" bolts in my recently acquired 50# LG I've been dreading drilling one for the brake pivot. What I need is a mag drill but if I could afford a mag drill . . . Nevermind. ;)
Anyway, after getting beat up pretty badly drilling the small holes I was NOT looking forward to drilling one to tap 1/2" 13!
Okay, back to the garage sale. Below is a $5 haul I made, both worked when I plugged them in though I don't know how the little buffer tool will work I think a good cleaning will clear up the burning electrical smell I get when turning it on but if it's junk. . . Oh well.
The little Craftsman drill press has already paid for itself as far as I'm concerned. It's my PoBoy magdrill as illustrated in the last pic. The hole is about 1/2" from depth and it's straight, square and clean. I stopped because it was dinner time and will finish it off tomorrow.
I am a HAPPY guy. :D
Frosty
14642.attach
14643.attach
14644.attach
Edited by Frosty
