GaryL Posted June 15, 2022 Share Posted June 15, 2022 I am not a Smith but I do lots of basic repair on lots of different things. I also frequent yard and estate sales when I have some free time on the weekends. It is amazing to me that just about every sale has a bunch of older metal files, most are trash or at least half rusted because they sat in a damp tool box on one side. I don't buy any of them unless they have some life left in them but buddies who like to forge stuff like knives seem love old files. What am I missing when I can buy pounds upon pounds of old files for pennies and often take them away for free? There is a Smithing gal around here who knows I am a cabinetmaker and she stops by a few times every year searching for my dull saw blades but she has no interest in old files. She has made me a few nice fixed blade knives from the old saw blades and wood scraps I gladly gave her. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted June 15, 2022 Share Posted June 15, 2022 Most quality files are tool steel. They make great material for other tools. Be it body slappers, chisels, knife blades etc. a dip in aqua Regina or another etchant will often revive them as well. They won’t be as good as new but they will serviceable Quote Link to comment Share on other sites More sharing options...
arkie Posted June 15, 2022 Share Posted June 15, 2022 To add to Charles' statement, the other part of "Most quality files", are the ones such as foreign files and farrier's rasps, which may be case hardened. Not so good. *Usually*, the older the file, the better quality tool steel. I love old Nicholson files and some Heller's. Quote Link to comment Share on other sites More sharing options...
GaryL Posted June 15, 2022 Author Share Posted June 15, 2022 Thanks Charles and Arkie, I am far from knowledgeable on this subject but in my experience, most good metal files from Nicholson are made to be directional which many novices are not aware of. Once the tips get worn or folded from back filing they become dull and just don't file as they should. Back in Metal Shop in the mid 60s my instructor spent an entire class on the proper use of files and told us he would rap our knuckles if he found us using them wrong. I had a big box of old files that were just about completely worn out and I tossed them and the recyclers but wonder if I should have given them to a buddy who does play with smithing and makes some nice knives. Quote Link to comment Share on other sites More sharing options...
Latticino Posted June 15, 2022 Share Posted June 15, 2022 Yes, most likely your old files were worth more as stock than scrap. It is pretty easy to test whether a particular file is easily hardenable, and your smithing friend should know how to do that. Quote Link to comment Share on other sites More sharing options...
dickb Posted June 15, 2022 Share Posted June 15, 2022 4 hours ago, Charles R. Stevens said: Most quality files are tool steel. They make great material for other tools. Be it body slappers, chisels, knife blades etc. a dip in aqua Regina or another etchant will often revive them as well. They won’t be as good as new but they will serviceable To clarify, aqua Regina is actually Aqua regia Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted June 16, 2022 Share Posted June 16, 2022 Thanks for the correction Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted June 16, 2022 Share Posted June 16, 2022 To revive old files I soak them in 30% cleaning vinegar overnight. Usually gives them new life, especially old rusted but not abused ones. Quote Link to comment Share on other sites More sharing options...
Gazz Posted June 17, 2022 Share Posted June 17, 2022 If you use any acids on them be sure to neutralize them after with some baking soda solution and then dry promptly. Quote Link to comment Share on other sites More sharing options...
BillyBones Posted June 17, 2022 Share Posted June 17, 2022 I like rasps for the bit in an axe. They already have teeth to bite into the mild steel to set them. Quote Link to comment Share on other sites More sharing options...
Jobtiel1 Posted June 17, 2022 Share Posted June 17, 2022 yeah, I like files/rasps for that too, makes it easier to weld as they're not moving around, I do still cut teeth in them with a chisel before setting them in though. Quote Link to comment Share on other sites More sharing options...
Scott NC Posted June 17, 2022 Share Posted June 17, 2022 Not forging, but if you grind a 45 degree bevel on the very end of the large, quality worn out files they make good bb scrapers and slag chippers, if you do much welding and cutting, that is. Especially in tight spots. Suggest putting a wood handle on the tang end though.... Sometimes we broke them in half and then ground them, less unwieldy/clumsy to use. Quote Link to comment Share on other sites More sharing options...
JHCC Posted June 17, 2022 Share Posted June 17, 2022 At Quad-State 2019, the smiths from Colonial Williamsburg said that they used such scrapers to remove forge scale, since wire brushes were not period-correct. Quote Link to comment Share on other sites More sharing options...
anvil Posted June 17, 2022 Share Posted June 17, 2022 Period correct or not, I discovered how good they are when prepared as Nodebt and JHCC said and rarely use a brush. And they last forever. Lol, i think its funny watching smiths work harder using a butcher block brush than they do with a hammer! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 23, 2022 Share Posted June 23, 2022 Old files can also be good for pattern welded billets or San Mai blades. I like the old black diamond NOT stamped Nicholson---1.2% Carbon and great for "juicing up" billets. Also steels for flint and steel sets. However a lot of smiths have little or no use for them; like racing tires the folks that use them may love a "donation", but most people don't have a need for them. Quote Link to comment Share on other sites More sharing options...
