May 10, 200818 yr Looking to buy an oxyacetylene welding outfit. Plan on using it for some basic welding as in making jigs and such for smithing work and, at times, providing some localized heat. Harris? Victor? Others? Thanks
May 10, 200818 yr I would buy anything you can get local from your local welding company. Esp the bottles because if you buy them some places won't exchange them and you will wait for a refill plus its up to you to get them rechecked every 10 years or so. As far as a torch i have used them all. Harris is cheaper than Victor but you will never wear it out. I use Oxweld only because i got a pile of it free. You can get cylinders at Home depot now at least around here but the price is higher than the LWS. Some NAPA stores sell bottles also and you can swap them there...Bob
May 10, 200818 yr I have always preferred Victor personally, in my expierience it is much easier to find replacement tips for them than it is for other brands. I have used them all, and they all generally perform well, but with gas cutting and welding equipment I have found that you get what you pay for. If you can afford a Victor, Smith, or Harris torch set it will last you a few lifetimes if you take care of it. One thing to take into concideration is that you want to make sure that the torch set you get is equipped with reverse flow check valves and flash back arrestors (either built in tothe torch or connected to the supply hoses). Some of the older used torches and cheaper off brands don't have these essential saftey features. And though yes, the chances are slim that if used properly 99 out of 100 welders will not expierience a flashback, It's still worth a little extra to ensure your personal safty and eliminate the possible risk to your shop and everything else around it.
May 10, 200818 yr I currently use a small harris port-a-torch set which I exchange the cylinders at the lws. I also like victor but ain`t ever used smith. I would go with what my LWS (FYI: local welding supply ) has . Thanks,chris
May 11, 200818 yr #1---Victor Harris, Smith, and Oxweld, are all excellent torches, come in second. My personal preference is the Victor. 35+yrs in the trade and no problems with one. It's like Jose said about the ease of getting parts, tips, etc. for a Victor. Also, get the arresters and check valves, period. You may have to get them seperate from a LWS, but GET THEM! We need you around for a while longer! Check craigslist classifieds. I have seen complete rigs; bottles, hose, regulators, torches and tips fairly reasonable. Remember some gases will not allow you to oxy/fuel weld even tho you can cut with it.
May 11, 200818 yr It's all pretty much preferance. If it's clean work any of them are good. I'm used to terible conditions, with alot of grease dirt and water and I can tell you Victor has proven to outlast the others with Harris being second and no need to try a Smith. They are good torches but to sensitive for bad conditions. Just my opinion Travis
May 11, 200818 yr Your local welding supplier may or may not have torch "sets " hanging on the wall. This inc torch set and regulators and may or may not inc checkvalves ( flashback suppressors). My checkvalves are on the regulator end and I had to buy them seperately. The selection of tips in the set will be a consideration ( you may have the option of a rosebud ). My current set ( 5-6 years ago) is a Smith because the set was $ 169.95 IIRC. The old regulators finally were to the point that they would not economically re-build although the torch was good to go. I bought a Henrob torch a few years ago and weld with it ( was using it on old regulators ). The new Smith torch set pretty much sets in the box ( exception rosebud a few times ) but the regulators were what I needed. I also use a Smith gas saver valve. I have picked up a LOT of information over the years from this site and others regarding equipment. Thanks Glenn ( and the list could go on for many other folks ). BTW if you have no training in bottles or torches I would strongly suggest you get the training. Bottles are missles and acetelyne/propane have different issues to consider regarding fuel gasses. Hose connections /regulator connections as well. Don't mean to preach.The net can teach you a lot. A course in torch safety and use should teach you what you need to know. Acetelyne welding works very nicely in my business. You will notice that you have recieved several different brand loyalty posts and yes I have used them all ( Harris for LP too ). Where are you in the world ? Edited May 11, 200818 yr by Ten Hammers
May 11, 200818 yr I had a Harris set that was stolen out of my truck. It worked great but I replaced them with Victor because it was easier to obtain and support.
May 11, 200818 yr rfdecarter go to the top of the forum page and click on user cp click on edit profile go to the bottom of the page, enter your location and save. We would like to know where in the world you are located.
May 11, 200818 yr I have used Smith, Harris, and Victor over the years. Never really got along with Smith. I was glad employer switched to Harris but my all time favorite is Victor. I have a Victor my dad gave me and have never had a problem with it. Its older than I am and the only reason I would replace it is its size. I would prefer a smaller lighter one, but the price was right ;)
May 11, 200818 yr I am gonna have to agree with the previous posts....... My old boss had Smiths , and we always had trouble getting tips in the size we wanted . The tips were pricey if I remember right too. Ive been doing structural steel for over twenty years and I like the Victors , they are comfortable, and parts and accesories are everywhere. Good luck.......chrisp
May 12, 200818 yr I use Smith at the school I go to. They are very nice, but I personally like the Victor over them all. My reason for this is I like using my thumb to operate the oxygen cutting lever instead of my fingers. (I get a better/more steady of a hold on the torch that way.) But Smith is the best on the market to my knowledge.
May 12, 200818 yr Victor is hands down the best as far as easy to get parts, quality, and will last a life time if taken care of, they cost a little more than most but is worth the $....but that's my opinion, however it is based on years of useing all brands and still have sets that my grandfather used in his body shop (Victor). welder19
June 6, 200818 yr Look into buying tanks from Tractor Supply Co if there is one near you. They sell the tanks and exchange for refills. Do comparison pricing with local welding shops.... They market several sizes.
June 6, 200818 yr The Henrob welding torch should not be discounted. I use one almost daily ( smith regulators and a smith gas saver ).
June 6, 200818 yr I have used a Victor for every thing, from brazing to cutting 6" plate. I wouldn't buy anything else.
June 6, 200818 yr Steve (Ten Hammers) is so right about a Henrob torch; I have to thank Garey Ford for introducing me to it. All the other A/O torches are great and I still occasionally use mine, but once I added a Henrob rig to my shop I noticed a massive reduction in tank refills. Just another handy tool with its own niche area. For those not familiar with a Henrob, consider checking this link:Henrob 2000
June 8, 200818 yr I have some Smiths. They are "vintage." Victor parts fit-tips and all. One(small size) is what some call "aircraft" because of its fine reputation among experimental airplane builders- that is what I have been told by builders. My large is marked Smith as well; same "standard" threads. That one I have rebuilt and used Victor seals. Dillon-Henrob-Cobra- invented by an Australian gent. My present one is my second. It does everything that the advertising claims. My first was before a long reach tip was offered- occasionally that was frustrating. I also own the "Little Torch." A zero tip on the Dillon( that is what I call them because that is the first brand I had) will come close to the delicacy of the "LT." I think that they cut cleaner- that might just be that I have never been particularly great at cutting. If I could make one change in the Dillon- I would have a carbon fiber or glass filled heat resistant "plastic" for the clamshell handles- maybe even stamped aluminum or magnesium alloy. My tanks are owned- the tote set and the ones that are standard diiameter but only about 3 feet or less tall. Here in Iowa we have S. J. Smith stores at five locations- main store here in Davenport. I also own my argon and 25/75 tanks- can't recall the number for those- about 7" diameter and 2 feet tall- I have 2 of the mix and just the one argon. My mig is a Lincoln SP170- it is a good little "work-pony." After all of this unneccessary rambling, I agree that Victor is the top for conventional O/A equipment.jet
June 8, 200818 yr I love my Smith, But to be fair for comparison, its a "Little Torch" the jewelry set up, small, tiny, great for my knife work. The 3 smallest tips have synthetic sapphires for the jets and produce a flame that can barely be seen in strong light, so a very localized heat.
June 8, 200818 yr i have a travel victor, and a medium size victor, both great torches. use them often. just a week ago i was poken around in my grandfathers shop and came across a dillon, or henrob as seems to be the new name. i just stated playing with it and he gave it to me. ive only spent maybe 20 minuets fiddelin around with this thing but im vary excited to see what it can do! my OXY knob seems to be pretty stuck, guess that happens after 10 or 20 years sitting there. i know that its dangerous to use any type of grease or oil on torches(BOOM). so what can i use to ease it up, graphite powder?
June 30, 200818 yr To the guys that use a Henrob, do you think its necessary to have a normal oxy/acet rig if you buy the henrob as well? What kinds of things do you still use your old torch for?
June 30, 200818 yr Andrei, Cutting 6" plate or thicker LOL. After buying and using my Henrob, I can now kick myself for ever buying my 50 amp plasma cutter that requires a steady supply of Dry air. DRY air in Mudville, USA? That would be like a having an actual snowball fight in Arizona someday!
July 2, 200818 yr The Henrob torch is just that, a torch. No hoses, regulators etc. I cut with plasma and weld with the Henrob.
July 2, 200818 yr A Henrob needs to be attached in place of a standard A/O torch and uses the A/O rig's gauges, regulators, hoses, and tanks. Only changes to be made are the pressure settings on the regulators as a Henrob torch operates best at the recommended manufacturer's 4# setting on both tanks, thus the economical gas consumption. It works great for welding, small isolated, drawing temper colors, cutting, piercing, etc. For general shop use buy the complete A/O rig and torches. Later add a Henrob to your equipment; you will be glad you did!
