paradox1559 Posted October 29, 2016 Share Posted October 29, 2016 Just picked this big boy out of a pawn shop tool bin. Id like to restore it to its former glory before putting it back to work Thoughts? Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted October 29, 2016 Share Posted October 29, 2016 check the screw thread, both internal and external for wear Quote Link to comment Share on other sites More sharing options...
Marc1 Posted October 29, 2016 Share Posted October 29, 2016 If you want it to look good, Pull it apart carefully and put it in molass bath. Like TID said, if the screw is good, and the spring works, probably needs nothing. Are the jaws in good nick? Line up, no big cuts? Quote Link to comment Share on other sites More sharing options...
paradox1559 Posted October 29, 2016 Author Share Posted October 29, 2016 What's the best way to mount one of these? Specificly, how tall should it be? In 6'5". Should it be to my waist? Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted October 30, 2016 Share Posted October 30, 2016 Good Morning, Para-Docks It looks like you have to make a wedge, to hold the upper post to the Bracket. The Spring is 180 degrees out, the top gets clamped in when you drive the wedge in and the bottom of the Springs leans against the outer (short) post. I use an old automotive "Throw-Out Bearing" at the Thrust Washer, It makes them easier to Tighten and Loosen. just my $0.02 Neil Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted October 30, 2016 Share Posted October 30, 2016 Mount it so the leg rests on the floor. If you don't mind, how much did u pay for it, and how wide are the jaws? Quote Link to comment Share on other sites More sharing options...
paradox1559 Posted October 30, 2016 Author Share Posted October 30, 2016 Swede your right the spring is loose, I didn't know there was supposed to be a wedge there. I'm going to make a replacment. C-1 I played $150, and the jaws are 8" as my eye can see. Quote Link to comment Share on other sites More sharing options...
C-1ToolSteel Posted October 31, 2016 Share Posted October 31, 2016 8 inches!!! That is a MAN! Great deal! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 31, 2016 Share Posted October 31, 2016 Height depends on how you will be using it. Since you are asking us to determine that: Please box it up and ship it to me. There problem solved! With your extra height you will probably want to put an extension on the foot holder. If you will mainly be using it to file on, grab a file and get in position and measure the distance from the file to the floor. For needle file work you may even want to mount it higher so you can sit in front of it and file. For heavy hammering using top tools then it may be low enough for you as it comes. Perhaps you can experiment with it to find the height that works best for *YOU*. Quote Link to comment Share on other sites More sharing options...
Gold Country Forger Posted October 31, 2016 Share Posted October 31, 2016 At the risk of being burned for heresy I'll admit I put an extension on the leg of my vise. I am 6"2 and work with several vises that are set on the ground and find them too low. I think there ended up being a 4" lift from the very bottom of the post due to a miscommunication with the fabricator, I am very glad for the extra height but do wish it was just a hair less. I also have another vise I will mount without an extension at some point, and i took that into account before messing with the height. Being too low is just mildly annoying especially when it comes to operating that handle, too high however can make it almost unusable. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted October 31, 2016 Share Posted October 31, 2016 tp is right. YOUR tools in YOUR shop should be how YOU want them. find what works for you and do it. Quote Link to comment Share on other sites More sharing options...
JHCC Posted October 31, 2016 Share Posted October 31, 2016 That is a crappy post vice. Absolutely not worth your time. Send it to me; I'll dispose of it properly for you. Quote Link to comment Share on other sites More sharing options...
paradox1559 Posted October 31, 2016 Author Share Posted October 31, 2016 3 hours ago, JHCC said: That is a crappy post vice. Absolutely not worth your time. Send it to me; I'll dispose of it properly for you. Lol, nice try Quote Link to comment Share on other sites More sharing options...
lazarus Posted October 31, 2016 Share Posted October 31, 2016 On some post vises, I've seen 2 opposing wedges (rather than a single wedge) to tighten the vise and top mounting bracket. Quote Link to comment Share on other sites More sharing options...
Tubalcain2 Posted November 1, 2016 Share Posted November 1, 2016 one off mine is an indian chief and it has 2 wedges. Quote Link to comment Share on other sites More sharing options...
paradox1559 Posted November 1, 2016 Author Share Posted November 1, 2016 2 hours ago, lazarus said: On some post vises, I've seen 2 opposing wedges (rather than a single wedge) to tighten the vise and top mounting bracket. Do you happen to have a good picture? Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted November 1, 2016 Share Posted November 1, 2016 Good Morning Para-Docks Picture a straight piece of 1/2" Flat Bar with the ends bent 1/2" back like a large "U". The ends stop the two tails of the bracket from spreading out, when you drive the wedges in. Take a piece of Flat Bar not as wide as the opening remaining, cut it at an angle, You now have two perfectly matching Wedges to fill the void. One goes in from the Left, the other from the Right. K.I.S.S. Neil Quote Link to comment Share on other sites More sharing options...
John McPherson Posted November 1, 2016 Share Posted November 1, 2016 "Do you happen to have a good picture?" Posted two weeks ago in a thread on Oct. 14th. Quote Link to comment Share on other sites More sharing options...
aessinus Posted November 1, 2016 Share Posted November 1, 2016 15 hours ago, John McPherson said: "Do you happen to have a good picture?" Posted two weeks ago in a thread on Oct. 14th. I recalled that picture. 5th reply, 2nd picture. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted November 2, 2016 Share Posted November 2, 2016 Here you go.. The ears go towards the mounting bracket and the wedge goes closest to the vise. Make sure your ears are plenty strong.. Especially on an 8" vise.. Nice find and good price.. Would like to see more pictures.. Maybe some detail shots of the screw, jaws, etc, etc.. looks like you need a new bolt? Is the bolt hole tapered? Quote Link to comment Share on other sites More sharing options...
