Nakedanvil - Grant Sarver Posted May 14, 2009 Share Posted May 14, 2009 (edited) More properly called a "Friction screw press". 'Bout a 6" stroke, has real impact not just squeeze. Doing about 3 feet per second at impact. The screw is 5 inch diameter about six inch travel per revolution. Edited May 14, 2009 by nakedanvil Quote Link to comment Share on other sites More sharing options...
John B Posted May 14, 2009 Share Posted May 14, 2009 Serious piece of kit, and a heck of a pitch for a screw thread, 6" per rev? Quote Link to comment Share on other sites More sharing options...
nuge Posted May 14, 2009 Share Posted May 14, 2009 Wicked. If things are moving so fast, how do you stop the machine where you want to? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 14, 2009 Share Posted May 14, 2009 Screwpress screws are generally multiple lead and so for a 3 or 4 lead screw that pitch is not too strange. To stop you use a stop block the height you want. Screwpresses are famous for their pressure spikes when the ram bottoms out and the system reverses---makes them great for coining as that spike "squirts" the metal into the die cavities. I've used a powered screwpress, very nice and keep EVERYTHING clear of the dies save the workpiece! Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 14, 2009 Share Posted May 14, 2009 Heck of a piece of equipment! If you'll click "User CP" and edit your profile to show your location it can make a big difference. IFI is represented by more than 50 countries and a lot of info is location specific. Frosty Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted May 14, 2009 Author Share Posted May 14, 2009 Wicked. If things are moving so fast, how do you stop the machine where you want to? Speed IS relative, you know. Hammers run at 30 feet pers second AND UP. 3 FPS is quite easy to work with. The flywheel at the top of the screw has a leather belt around the outside edge. The two vertical wheels run on a common shaft driven by the motor. Drive is imparted by moving the shaft and it's two wheels from right to left so that one wheel contacts the leather. Quite sensitive and controlable, I can hit a very light blow or one xxxx of a stomp. Quote Link to comment Share on other sites More sharing options...
Bob JS Posted May 14, 2009 Share Posted May 14, 2009 Thats an impressive piece of kit. Any chance of a video demonstration to show us what it can do? Thanks for sharing it with us. Quote Link to comment Share on other sites More sharing options...
SGropp Posted May 14, 2009 Share Posted May 14, 2009 There was a motor driven screw press for sale a while ago on Ebay. It was rated at 6000 metric tons with a 26'' diameter screw. It was in some shipyard in Baltimore. You could probably use it to forge the frame of one of those little 100 ton presses if you had the right dies. Quote Link to comment Share on other sites More sharing options...
DClaville Posted May 15, 2009 Share Posted May 15, 2009 that is BIG:.... nice hehe DC Quote Link to comment Share on other sites More sharing options...
Jacques Posted May 15, 2009 Share Posted May 15, 2009 A friend of mine used to work at a place that made medals, and they had a few of these presses about twice the height of yours. I stood and watched as the guy punched medals with it, and it was very impressive. I would just not allow anyone to work with one of those without very good safety measures and a healthy dose of cowardice. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted June 4, 2009 Author Share Posted June 4, 2009 Jacques: ONE ton will kill you, more just makes it look messier! Grant "Safety is an attitude, not a device"! Quote Link to comment Share on other sites More sharing options...
AndrewOC Posted June 4, 2009 Share Posted June 4, 2009 (edited) Yep, very nice press! Would you be able to do the '1-inch-square-bar-5-hit-squash' forging test as mentioned in a 'power hammer' section thread? Also I couldn't help but notice what looks like an air upsetter under the window in the photo ; ) I'm sure everyone would love to hear about it and what it can do. regards Andrew O'Connor Edited June 4, 2009 by AndrewOC forgot stuff Quote Link to comment Share on other sites More sharing options...
welder19 Posted June 4, 2009 Share Posted June 4, 2009 Very nice press and nice looking shop also. welder19 Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted June 4, 2009 Author Share Posted June 4, 2009 Andrew: Not sure it's a fair comparison, I can only get about maybe 30 full strokes per minute, but here is my results: 1 X 1 A-36 square x 2 inch long, heated to good yellow not welding heat: .275 thick, oh yeah - one blow! Quote Link to comment Share on other sites More sharing options...
Double Y Posted June 4, 2009 Share Posted June 4, 2009 Nice! That is a heck of a squish machine right there. What are you going to do for tooling? Any built that you want to share pictures of? Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted June 4, 2009 Share Posted June 4, 2009 Nice looking press nakedanvil- Good statement- Safety is and attitude, not a divice!!!! That should be a bumper sticker and furnished to Ralf Nader. Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted June 4, 2009 Author Share Posted June 4, 2009 You know, my old Nazel 4-B (500lb) would have probably taken three blows to do the same. Fe-Wood: There ARE devices that improve safety, but nothing comes close to attitude. Some people look at a machine and say it looks scary. Well, in all honesty, no machine scares me near as much as some people! Quote Link to comment Share on other sites More sharing options...
Fe-Wood Posted June 4, 2009 Share Posted June 4, 2009 Ah-men brother!!! Typically, machines are stupid/simple in that they only do what they are told and they don't anticipate anything. All failures aside- Case in point, CNC machines, one of the few machines that can and will eat itself. Be safe- Quote Link to comment Share on other sites More sharing options...
Frosty Posted June 4, 2009 Share Posted June 4, 2009 Well said Grant. One of the things Father said till I was sick of hearing it was, "You have to respect 'It' but you can't fear it." IT being whatever machine, tool or thing in front of you. He also liked to say, "Familiarity breeds contempt." I'm with you, machinery doesn't scare me, people do. Not all people, all the time but . . . Frosty Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted June 4, 2009 Share Posted June 4, 2009 its no more dangerous than a big power hammer...but its all dangerous in the hands of a idiot... nice tool! i got a chance to use a 50 ton at a friends house (Terrys) and found it to be a wonderful way of squishing metal ..great for makeing dies ! have fun Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted June 4, 2009 Share Posted June 4, 2009 wow nice would love on of those Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted June 5, 2009 Author Share Posted June 5, 2009 found a video of a 100 T screw press, you need broadband:friction screw press / forging press - down stroke and up stroke / vincent press - Maneklal and Sons (Exports) Quote Link to comment Share on other sites More sharing options...
nuge Posted June 6, 2009 Share Posted June 6, 2009 found a video of a 100 T screw press, you need broadband: You found a healthy reality check as well. Them's some tough looking working conditions. Quote Link to comment Share on other sites More sharing options...
Dawg Posted December 4, 2009 Share Posted December 4, 2009 You have a realy nice set up there anvil. I have to say I feel envy and a little turned on, I havent seen press porn in a long time. Quote Link to comment Share on other sites More sharing options...
masons forge Posted January 4, 2010 Share Posted January 4, 2010 I have two of these presses in my shop and I would like to place them in a good home with a fair price. One is a 100ton and one is an 80ton I think. Do you know any one that might be looking for one? They look scarey but they feel safer than an air hammer Quote Link to comment Share on other sites More sharing options...
