November 18, 20196 yr ratfink310, great find. You couldn't have found a finer vise beginner or expert. the jaws look like new. Congrats on the find.
November 19, 20196 yr Yep, ya done good. Did you ask her if she had any more of her father's Smithing items/tools?
November 19, 20196 yr Irondragon, she said that he used it to hold parts when he was welding stuff and basic vise holding of parts. She asked me what I was going to do with it and told her I am just starting to pick up blacksmithing. She was glad to hear that I was going to use it for what it was intended to be used. I did not ask about other tools as where she was living did not see any thing that would allude to him having a forge.
November 19, 20196 yr Hammer's, tongs, top tools, swages. Where a person is living and where the old falling down shed full of blacksmith GOLD, (it rusts), is need not be the same...
December 16, 20196 yr Managed to get this for £10 p/inch last month, need to give the bolt and the handle a bit of love but other than some squeaking and rust friction its in great working order. Only 3" but it was a lot harder to track one down locally than it was the anvil. not sure if i want to just give it some lube where it needs it and let it be or take it all apart and clean it up. The foot is sitting in a 5kg weight that's solid in place
December 16, 20196 yr I would take the screw & screw box apart and clean them of old lube & gunk, oil them and pivot points then put it to work. A 3 inch vise will do a lot of work and 30 pounds sounds like a good deal.
December 16, 20196 yr Cleaning the bearing surfaces, (cheeks & pivot, screw&screwbox) and lubing them well will make the vise/vice a lot nicer to use. The rest is personal preference.
December 16, 20196 yr I will get to it over the weekend, it couldnt definitely be smoother to use. I'm a bit torn on the rest really, i don't like the faded sky thing it has going on but i a shiny clean steel anything would stand out like a sore thumb given the rest of the shop(inc the roof, door and windows) is built from scrap and salvage. Ill have a think and come post clean up picture when i decide
December 16, 20196 yr I didn't know what was an option, ill have a look at tea'd steel on google and decide then, thanks for the idea
December 16, 20196 yr You may want to look up coffee as well. Tea is the tannic acid so a peat bog soak should also work. (Don't include the screw/screwbox of course!) I had one friend who cleaned, polished and then heat coloured his vise/vice and then clear coated it. There is always paint as well. Many people wipe down a cleaned tool with boiled linseed oil; but that won't colour it.
December 18, 20196 yr Hi All, I'm new to the forum and just moved into my new place late summer and I'm excited to finally have the shop I've always wanted. This is my postvise that will finally have a place to be used. Everything works fine and other than rust and cobwebs everything turns smoothly and all of the threads are intact. This is what it looked like for starters After soaking overnight in evaporust and a lot of wire brushing, it's looking much better: After overnight soaking I want to decide what to do for a finish before I reassemble. In the original pictures you can see that there was some blue paint on it but based on the quality of the painting I think it was added later and wasn't original. I like the raw metal and thought about maybe just clear coating the non-working parts and oiling the rest. I've also got to put together a floor plate of some sort since I'll be using it on a concrete slab floor. I found a scrapyard fairly close by and need to go rummage around there to see what I can find. Does anyone know who/what the "JB" on the one leg might refer to? Thanks!
December 18, 20196 yr Welcome to IFI! If you haven't yet, please READ THIS FIRST!!! That's a lovely vise you have there. I don't recall ever before seeing one with a replaceable post.
December 18, 20196 yr John Brooks, English, and they used blue paint in fairly recent times as I recall. Also makes anvils! Looks nicely "robustus" and ready for heavy use! Where did you find it? (I've found some british broad arrow sledges at a fleamarket right close to the TX/NM/MX border before, one date stamped from WWII and one from the 1980's.)
December 18, 20196 yr Thanks ThomasPowers, that's good info! I bought the vise from a farm when I was living in England and got to use it a little but it's been in storage for far too long.
December 18, 20196 yr They don't go stale; a bit of clean up and oiling and they are ready to go for another generation or 4 of use.
September 9, 20205 yr I bought my first post vises the other day. there was someone selling blacksmithing equipment on Kijiji in Alberta. It was a great deal so me and my dad drove 13 hours return to pick it all up. Along with a few blowers and post drills I got three leg vises. The front one was tuned up by the guy I bought them from and works well. The next one works but is missing the spring and wedges for the mount. the back one was siezed at the pivot point. After much WD-40 and some falling wedges I finally got it moving. I continued working the jaw back and forth and It now pivots smoothly. they all are 3 3/4" wide and have good screws.
May 23, 20242 yr Got a job new job a different body shop and this Columbian #504 is at my station. It's mounted on a flimsy table though it does what I need it to do. I thought it is a pretty cool vise to be in a body shop!
May 24, 20242 yr Nice vise, maybe they'll de-flimsy the bench or pay you to. Maybe they have occasion to straighten out Brinks armored trucks? Frosty The Lucky.
July 7, 20242 yr Just picked up this big vise, it has 5-1/2 inch jaws and weighs around 70 pounds I don’t exactly know what brand it is but there are some markings on it. Got it mounted and it works like a charm! I drove about 4 and a half hours to south Texas near canyon lake. The guy I bought it from was funny an 18 year old whose hobby was buying and restoring old vices. Pretty cool dude!
July 8, 20241 yr Nice Vise, should serve you well. It reminds me, I have an extra one in the shed that needs my attn. Rusty and crusty from the flea market.
July 26, 20241 yr my main go to vise. Sand filled stand. ...and my smallest vise. my main go to vise. Sand filled stand.
July 26, 20241 yr I really like your stand and the smallest one is cute, would work for small fine work. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
July 27, 20241 yr thanks, yea I like working on it too. When I built it , I thought the feet could potentially be annoying but to me they provide a kind of stable contact position to work from. Although it looks like a tripod, it does have a pretty large floor surface and tends to wiggle a little when the concrete is not totally flat. I use a small wedge to kick in the slotts under the feet if needed. I could use an adjustment bolt but I guess that would really be something to trip over... This one is a tad high for sledgehammer work. I think I`ll build another set up which will be a couple inches lower.
