Latticino
2023 Donor
  1. I've used Mizzou, but not casted anything with it for over 20 years, so going by dim memory here. I used it to cast burner blocks and did some light troweling into the bottom of my ceramic blanket glassblowing glory hole for molten glass resistance. I don't recall it troweling any better than Kastolite, and I've never tried to do successive sections of either to build an arch from a series of installations. I have troweled Greencast 97 over the top of a large clay form to make an arch for the top of my glass furnace. That worked very well, though the form had to be removed carefully while the refractory was setting. I did add SS needles to the dry mix for that, which made it not a whole lot of fun to mix up by hand. Personally I'm in favor of casting the inner skin of the forge in Kastolite with a removable inner form. This is certainly feasible in 3/4" thickness, which IMHO is a good compromise for an inner liner.
  2. Another alternative would be to go over to natural gas. It is pretty convenient, though you will need either a dedicated blower for a fan powered burner, or gas compressor for a NA one..
  3. I think you are underestimating the side forces the pressing of a piece of stock may have on your frame and guides. There is a good reason for those heavy weight guides on fly presses, hydraulic forging presses and power hammers. I would be careful of the potential for off center force, the guides binding, and the whole thing wracking. Just the offset of the chain from the center of the axle may cause you trouble. Still, best of luck with your build. I'd love to be proved wrong.
  4. It has been so long since I signed on as a new member that I have forgotten. Perhaps if we don't already have it, instituting a gate keeping question or two about blacksmithing would help keep down the spam posters...
  5. Such a cute little press. Don't have too much to add to the above, though I expect that two factors will come into play that haven't been considered: type of steel and how hot you will get it when you stamp your touchmark. There is going to be a large difference between stamping, say, H-13, 52100, and D2 vs. mild steel or wrought iron. There will be a similar difference between stamping steel at a red heat vs. at a high yellow. I suspect you will be able to get this to stamp a 1/2" square touchmark on hot steel with not much trouble. I have a 3/4" round touchmark and stamp it with a 4# hand hammer. Needless to say it will be important to lag your press down to something that is rigid and relatively immobile for best effect.
  6. If you can't find an air/acetylene torch kit used on Craig's List, MAPP gas torches put out a lot more heat than the cheap plumbers propane ones. I got one of the larger ones at a big box store and have used it for tempering back tangs more than once. I would certainly follow Buzzkill's recommendation to have some sort of heat sink to avoid having the heat run back up the blade.
  7. How hot your forge skin will get will be determined by the insulation value of your inner layer (type and thickness of the "refractory bricks"), the way the combustion exhaust exits from your door openings, and how hot you run the interior of your forge. This is very difficult to predict (and can vary quite a bit depending on the insulating value of the bricks used). I would use it, as is, for initial firings and measure the peak surface temperature. Then select a coating to suit that temperature. Are those "hard" kiln bricks, or "soft"? If the former, they will have substantial thermal mass to heat up and potentially more thermal transfer losses. If the latter, please keep us posted on how long the forge "roof" holds up. Soft bricks are very prone to thermal shock and/or brittle failure. Hopefully your design includes provisions for relining your forge. Even under the best of circumstances you may have to replace it periodically. On my first brick forge, I used some leftover 2300 deg. F rated bricks that I had from another project and the bricks opposite the burner melted away...
  8. I'm not sure I follow your logic. If you work 6/12s on a regular basis and never have time to take off for vacation, when are you going to build all this equipment much less use it? Hydraulic presses and power hammers definitely make work easier, but if you don't have basic blacksmith skills under your belt (at best) they can just screw things up more quickly. At worst you can get badly hurt. Sounds like time is your most valuable commodity. You will learn so much more quickly from direct instruction, starting with safe blacksmith practices. There appear to be several shops/schools in your area, a New Mexico Artist Blacksmith Association in Corrales and even the Turley school in Santa Fe. If you don't have the time to attend, perhaps you should send your father and he can teach you once he learns.
  9. For the air filter shell: 16" - 4" (for the two layers of 1" blanket) gets you an ID of 12". You will want to limit your shell thickness as much as possible (say 3/4" max) since it is currently a "hard" refractory (like Mizzou) rather than an insulating one (like Kastolite 30). The high alumina content of Mizzou is certainly preferable, even better would be Greencast 97. If you have never cast refractory before, it isn't all that easy to ram into a 3/4" thick shell, but it is possible. To be able to remove the inner form you will need both a release and method of reducing it's diameter. I also used a sonotube when I cast my Kastolite shell at around 3/4" thickness, but cut a slice out of it and put in a flat section for the floor with tape, so I could remove it after the refractory set. Fortunately these refractories don't shrink a lot while drying, but if you don't preplan to remove the inner form you will regret it. Mizzou doors will be effective, but heat sinks as well. Heat sinks are a balancing act. Good on one hand as they act like "heat batteries" when you open a forge door or put in a mass of cold steel, bad as they take longer to heat up to forging temperatures (thermal mass) and reduce the overall insulation skin value of an equivalent forge liner that used a castable insulating refractory. You have made the typical forge designer mistake of making your first forge a bit oversized. We all typically go that route. Two issues with this: use of excess fuel and lack of ability to heat effective sections of the stock without overheating others. This latter becomes a particular problem if you are primarily working in high carbon steel (say for blades). If you do end up building tire hammers and hydraulic presses you will be able to work larger stock, but as a beginner I wouldn't necessarily go that route. I would strongly recommend that you and your father take a week long smithing class at one of the better schools to see if and what type of blacksmith work you enjoy before you jump completely into the deep end. Some folks find out it really isn't for them, or they prefer a different type of smithing that doesn't involve as much post forging work (bladesmithing, for example, is typically around 10-20% forging with the rest being stock removal, heat treatment, handle/guard/sheath finishing...). Don't be fooled by Forged in Fire. Blacksmith tools and equipment are currently selling at relatively high prices, but the bubble appears to be getting ready to burst. Don't be sure you will recoup your investment if you decide this isn't your thing after getting fully setup. You can make some incredible metalwork with a small fraction of the tools and equipment you are contemplating getting. That is a beautiful (French?) double horn anvil. Certainly won't hold you back at all.
  10. As I understand it the area being tested is proportional to the distance the test is at, and the temperature is averaged within that area. Apparently the mechanism used for determining the temperature has some relation to the emissivity of the material in question and can be confused by metering multiple materials simultaneously (and Jarrod indicated that was worse at elevated temperatures, which doesn't make sense to me - but I'm not a physicist). Bottom line is that closer sensing is probably fine up to a point (probably related to the size of the optical sensor being used). He may be concerned with accuracy within +/-0.5% , while I don't need quite that level of accuracy at 1,500 degrees (+/- 1 or 2% is probably acceptable for the heat treatment I do).
  11. I purchased one of those from Amazon as well. Around $60, if I recall correctly. Seems fairly accurate based on comparisons with thermocouples in a heat treat oven, but have read other postings from "authorities" that indicated there can be fairly large discrepancies based on the size of the cone and emissivity (note that the one he is commenting on is only rated to 1,500 deg. F, not the same as the one John and I have): This from Jerrod Miller (a metallurgist): I have yet to find one I trust for what I would call a reasonable amount of money. Two big things that a lot of people do not realize with IR thermometers is the size of the cone for the reader (close to the gun reads a small area, farther away a bigger area) and emissivity constants (a material dependent value). When we get to the temperatures we care about in smithing, emissivity constants become important and you will need to calibrate and adjust it for the material. The cone for the one you linked has a 12:1 ratio, so at 12 inches your diameter being measured is 1 inch. So unless you can be sure to be measuring just your steel, you will get contaminated readings (measuring the forge wall with the wrong emissivity constant for it).
  12. The limitations on your burner operation are also related to a number of factors, so it isn't a simple answer. The forge interior temperature directly influences the flame front speed (the velocity of the flame burning back towards the fuel/air source at the outlet of the burner). You want this flame to be stable, and located right at the outlet of the burner. As I've noted on numerous occasions, it is a balance between the velocity of the air/gas mix at the outlet (set by the volumetric flowrate) and the flame front speed. If it is too far off, it can easily "flame out" and, hopefully reignite (forge will appear to be "huffing". If too far into the burner outlet you can get preiginition in the mixing chamber (anything from "popping" to small explosions). Burner outlet area may need to be adjusted to achieve a "sweet spot" (though there are also burner outlet designs that work at a wider range - flame retention outlets and multiport outlets). As is pretty logical, a larger outlet will support more fuel/gas mixture at a lower flow speed, typically leading to a more "powerful" burner, but one that may not be able to be turned down as far without burning back into the mixer. You also have to be careful, again for flame front speed reasons, when turning down your forge from high to low fire. My recommendation is always to turn off the gas and just run on the blower until the forge drops to the desired temperature to avoid having the flame burning back faster than the lower air/fuel mixture can support. Overall length of flame can also be a factor (as Thomas stated), with how long the dwell time is inside the forge. Longer dwell leads to more energy transfer. Choice between oxidizing and reducing flames have been well described by Buzzkill. There are also characteristic forge interior sizes that work better with different flame configurations (both forge interior volume - for proper combustion, and forge width opposite the burner outlet - for properly developed flame length). I expect the 1" burner may be too large for your 250 cubic inch forge, but that is hard to tell without experimentation. You can always choke it down to a 3/4" outlet with a reducer to see. Best and most efficient path to increasing forge temperature IMHO is to ensure you have good operable doors. This is easier with a blown burner, so you are already on the road to success. Good luck.
  13. There are a couple of different ways to reduce the airflow from a blower. If the motor is capable of speed control you can reduce the RPM. On most blowers, but not all, you can "ride the fan curve" by increasing the resistance on the blower outlet with a valve or slide gate of some sort (some can go unstable at elevated external pressure). On some blowers you can reduce the airflow by restricting the inlet (but this can be a problem for others, overheating the motor). You can also add a waste gate that directs some of the air elsewhere (possibly to a slot diffuser at the opening of you forge to direct the dragons breath upwards). Lots of options, but first you have to ask yourself: How do I know I have too much air? How much fuel/air mixture is needed to burn to maintain a stable flame at the forge temperature I need for the forge I built (changes at different interior temperatures)? Should I reconfigure the burner outlet before reducing airflow?
  14. Absolutely on the crab cakes. Sorry for the situation, but 15 years is a great run. Good times on both sides I'm sure.
  15. Unfortunately I can't watch your video at work, but will try to check it out later. The typical "rule of thumb" for hood capture velocities is around 100 ft/min, so assuming you have a hood on the order of 2' x 4' your current 1,530 CFM should be more than adequate (if it is actually operating at that flowrate). The 10" nominal duct size at that airflow will result in a duct friction loss of around 1.2" WG/100' of duct (1.2 inches of water gauge head loss every 100' of duct). This doesn't seem like much until you realize that a duct elbow is an equivalent 15' of duct and the abrupt transition from the hood to duct is equivalent to around 35'. It can start to impact on your fan selection (fan curve vs system curve), but not knowing the specifics of your fan I can't theorize on what you actually have going. My guess is that you are riding the fan curve down and actually the fan capacity is 1,530 CFM at essentially no static pressure loss, and likely a lot less at the current flowrate. Since you may only need around 800 CFM of exhaust, it is likely not an issue. In fact at 1,530 CFM I would have selected a 16" duct for both static loss and air noise. Depending on the specific fan selection, it may only develop 1 or 2 inches of static before stalling, so likely you are balancing out at significantly less exhaust flow than you think. As I indicated, this may be fine, as long as the cooling effect is working for you. I'm not a big supporter of having the fan motor being in the airstream for a hot fume exhaust system. I look forward to seeing your solution for this. A belt drive system with the motor out of the stack is typically preferable, but you may be capturing enough shop air to keep it running acceptably. Just make sure you have an adequate makeup air opening to the outdoors to supplant the fan. I really like your 4-bar forge door, fan powered burner with PID controller and powered rolling mill. The dies on the bottom shelf look to be for a press as well, so I expect you have a very efficient shop. It is certainly a lot cleaner and better organized than mine...
  16. Well said John.
  17. Frosty, I'm afraid that you have come to my limit in fan/blower design terminology. I've heard of overloading and non-overloading fans (which basically has to do with fan system effects on the driving motor), but I've never heard or seen the terms positive vs free flow, or transparent vs. opaque used in the HVAC field as a description for fans or blowers, and I've been in this on and off since the early 80's. Doesn't mean it isn't common for specific trade applications (automotive for example), or something that a blower designer might be aware of. Some good bullet points regarding fan design in this ASHRAE PowerPoint presentation: https://rockymtnashrae.com/downloads/2012_Tech_Conference/introduction_to_fans___ashrae_4_20_12.pdf
  18. O-1 is the canonical oil hardening steel, and has been in use for a relatively long time. Please note that heat treatment "recipes" used for knife crossections are likely not appropriate for a 1" shaft used in a mower. For this kind of application you should be using industrial grade heat treatment services and quality tempering as the last thing you want is a brittle steel part rotating at high RPM. I'm not sure why you chose O-1 in the first place. I would expect a mower shaft would need more toughness than hardness. I would be selecting needle bearings with an inner ring (or race) that is appropriately high chromium to limit corrosion (see below) and most likely use 1045 or 4140 shaft stock (that is water hardening) for toughness. Honestly, even if the needle bearings were directly resting on the shaft, I would still probably go with 4140 or similar (though I would expect a machined and appropriately polished race would greatly increase the lifespan of the bearings and shaft). Note there is a great, free, downloadable heat treatment app (Heat Treater's Guide Companion) that is sponsored by the Heat Treatment Society under the ASM International Umbrella. They recommend austentizing O-1 between 1455 and 1500 deg F prior to oil quenching for 63-65 HRC, then tempering between 345 and 500 deg. F for hardness ranges between 62 and 57 HRC on a sliding scale. To answer your direct questions: Double heat treatment is typically bad, particularly if you don't control grain growth or have an accurate way to measure stock temperatures. File hardness depends on the file being used to check the surface and the experience of the tester(and can be confused by the potential for surface decarbonization). Also, "annealing" is to soften the stock so it can be machined. This differs from tempering to remove brittleness after the hardening quench. I would be very wary about using the shaft you have made.
  19. Mikey, More often than not these will be axial fans (at least if you mean the ones shown in the first picture below). Whether they are called tube axial or box axial appears to be a matter of length of the casing. Some manufacturers will call these mixed flow fans due to the geometry of the impeller, but essentially they will fall under the general umbrella of axial fans IMHO. By the way, as I understand it the word "impeller" refers to the function of a fan or blower blade, not it's configuration (used to move, or "impel" the fluid from one location to another. Note this same designation is used for the "business" part of most pumps)... While families of fans do tend to have common defining characteristics, the real key to proper fan selection is to review a fan curve and chose one that properly matches your distribution system (system operating point intersecting with a stable, efficient and quiet (if possible) point on the fan curve. Also note that some computer elements are cooled with centrifugal fans, which can be subcategorized as forward curved, backward curved, airfoil...
  20. Frosty, Well I've been in the business for a little while and have heard of a lot of different kinds of blower: centrifugal, forward inclined, backward inclined, radial, vane axial, mixed flow, plenum, squirrel cage, sidewall, high pressure/low flow, low flow/high pressure, high plume lab exhaust... but I've never heard of transparent and opaque blowers. Did you coin those terms? Do they have a reference for a particular application (like bilge blowers being used to exhaust out boat enclosures)? As I've mentioned before blowers or fans need both a airflow and external static pressure rating at a number of conditions to establish a fan curve. In my experience, for "gun" burners, the better choice is one that is relatively high pressure and low flow (typically, in the hobbist world, a centrifugal fan with an radial impeller) Some examples from the fabulous interweb...
  21. Nice looking vise, and one of the often overlooked key tools for setting up a good blacksmith shop. Prices vary a lot with location. In my area that would be on the higher side for a vise with 4' wide jaws, but just about right for one with either 5 or 6" wide jaws (that is width of jaw, not jaw opening size). Screw threads and jaws look to be in excellent condition and all the parts are there, so you are ahead on that account. Hope you can get into the class, sounds like fun. From all I've heard the Northwest Blacksmith Association is a pretty active group, so it is certainly worth getting involved with them.
  22. Yes, most likely your old files were worth more as stock than scrap. It is pretty easy to test whether a particular file is easily hardenable, and your smithing friend should know how to do that.
  23. I wouldn't worry about pressure, the key is keeping a good flame profile in high and low fire. As I've said in the past, while ribbon burners have many advantages, one key disadvantage is that you need to be careful in turning down the burner to a low fire condition after your forge has been running at high fire long enough to get very hot. Note, I started with a blower that size for my forced air natural gas forge and switched to a larger one to get more BTU output. Your forge shouldn't "choke" due to too much fuel, you should see a lot more dragons breath reduction flame at the forge doors where the gas fuel mix is hunting for more air to burn. If your flame is not heavily reducing, but just lifting off the burner face, it is a function of the burner outlet port size as related to forge interior temperature (and consequent flame front speed).
  24. Very good name hammer. Quite large size as well. Looks to need some significant work for reassembly, but likely quite promising if all the parts are there and the pistons haven't seized from that rust. Good luck with it, careful rigging it home if you get it, that's no light weight either.
  25. Excellent advice from George. Don't overlook shared rental of industrial space either. Not all of those old large factories got renovated into condos, some got partitioned up and have light industrial tenants. My first, and best, shop was in an industrial building with fine woodworkers, a filter manufacturing company, toymaker, and two other glassblowers, among others. It was nice to have metered natural gas, a freight elevator, periodic loan of an electric forklift, 3 phase power.. They are out there as well.
