717 -
Everything posted by Dave51B
Thank you Sir......Very informative and enjoyable.....enjoying the tour a bunch. Dave
If you would, could you comment on your lube schedule? Like, how often do you lube all those shafts and how long does it take? Is there a ladder involved, getting to some of those countershafts? I use some old farm equipment pretty regular and have to inspect and lube daily, some pieces more often. This is a beautiful shop and I am really enjoying the tour... Thanks for your time. Dave
Littleblacksmith... 3/8 square stock ( I make mine from 1/2" rebar) 2 1/2" long....top cut, 1".....bottom cut, 1 3/4"....remove 3/4" from one bottom leg. I found this info on IFI some where. If you want a different size stock, just use the same proportions.....I've made them out 3/4" down to 1/8"..... Search for Fredricks Cross. Enjoy Dave
Randy, I think if I had access to a lathe and some 2 3/4 id pipe. I'd make a cone mandrel to slip vertically back on top of the post anvil. But, after thinking a bit...... that may be a problem if your post gets mushroomed a bit from use. Dave
Randy, just a lucky guess....I have a couple of those extra, when that A comes along, let me know..... I've been eyeing one also. Got any plans for the cut off piece? Dave IPS
Randy, looks like a 10 spline axel from an unstyled JD A. 34' to mid 37' year. Am I close? Dave
Thanks JHCC, I do come up with one, every once in a while......he he, Maybe I'll just use it for a small drift and a punch or two. Forgemaster, I did have just a bit of knowledge on this, but not near enough to be sure of the results. Thanks for the confirmation. Sometimes I know just enough to fail..... Dave
Sweet....... Dave
night66, turn your tank valve on with the torch off and let it sit a few seconds before you open the torch valve, slowly...there is something in these new tri-knob tanks, that checks the flow. I use a hosed torch of similar style. See if that helps.....let us know Dave
Treadle hammer mechanics?
Dave51B replied to Blister Fingers's topic in Power Hammers, Treadle Hammers, Olivers
Yea Jim, something like that....after the foot vice build, this looks pretty straight forward. I have an old buss saw axel with the pulley blocks, and belt pulley complete. Some belt and a 12lb. sledge just waiting........wonder if a 12lb. is big enough? hmmm... Dave- 104 replies
- treadle
- treadle hammer
(and 2 more)
Oh no......I think I see another build in my future. That looks like something I could coble together. Thanks Alan..... Dave- 104 replies
- treadle
- treadle hammer
(and 2 more)
Thank yooou, Kozzy.......That was kinda my thought 2 months ago, but wasn't sure. And afraid to say...... I just remember ,back in the day as a kid, my dad pulling clinkers out of the coal stoker furnace in the basement. The handles were different , but the claw was real close to that. He had to reach through a door about 16" square, I think...I duknow, that was over 50 years ago... Dave
Yip, I'm as tickled as a 3 year old in a pack of puppies... Life is Good Dave
Smoggy, the only thing I know to do with it is to make a sword.........NOT lol Dave
Yer right on the patina Biggundoctor. Plus, I got to avoid my heat treating phobia......Life is Good Dave
Well, I got it bent. I did it cold in the 6" vice. It was about all I and the vice wanted for sure. After bending, the angle grinder took care of the cut. I got it installed and looks good. No obvious cracks, time will tell. thanks again for all the input.....pics attached, I hope... Life is Good Dave
I'm really enjoying this thread........ Dave
I'm glad I asked this question now....lots of input....Thanks a bunch. Right now I'm thinking to try it cold. I know , I said I couldn't do it cold....But, if I put a piece of angle iron on one jaw of my 6" leg vice, I may be able to squeeze it in like a wedge, between the coils....maybe....How does that sound? Dave
Thanks for the input guys. I do know this spring is to strong 'for me' to bend cold. Dave
Thanks Jim, I do have a plug that screws into the spring that is used on the hitch spring of these plows. I may go that way if I don't get this worked out....I just ran out and took a couple of pics so you can see what I want to do..... Thanks Dave (not sure the 2nd pic loaded or not, tried twice.....we'll see) ds
Thanks Jim, actually it's a lift spring on an old IH rope trip plow. Once I cut to length, I need to bend a loop back on the end to attach to an eye bolt for adjustment. Just so happens there are two different lengths of springs on these plows. I have an extra long one but not the short one...Once I heat to bend the loop in, I'll need to heat treat to maintain the integrity of the original....not to soft, not to hard..... Thanks Dave
Sorry guys, I can't find the info I need...I need to shorten pull type coil spring from about 23" to 20" and reuse it. The spring is about 2" diam. with 5/16" stock. Any tips for heat treat? All I have found is how to make knifes out of it ...LOL.... 1162 threads on coil spring.....Thanks Dave
I found a anvil and don't know what it is
Dave51B replied to Fuzz557's topic in Anvils, Swage Blocks, and Mandrels
Hey Fuzz, that would be a Vulcan anvil...Looks to be in good shape. It is in the low range of quality anvils, due to the thin faceplate. Dave -
Good to see ya Spanky. Here's to a speedy and successful recovery. Take care.....Life is Good Dave
