Posted
Got me, Steve.  ;)  Of course I meant "what kind of steel".  Is it high or medium carbon?  I know lug wrenches are often used as punches and chisels, but would they make a good blacksmith's knife?  (would it be able to be hardened enough to use satisfactorily as a knife?)
Posted
I guess they need hardened to hold their shape, My old teacher was a test engineer so he got various things tested at his work in his down time, a few things he tested surprised us like L6 for the leather wrapped Estwing claw hammer
Posted
I hadn't thought about them before but they do need to be pretty rigid and light. Long, thin, rigid pretty well means high end of medium to low end high carbon or higher alloy. I'll bet there are vanadium alloys too. I'm thinking it sounds like good axe steel.
I've passed on old Estwing hammers at yard sales for considerably less than a SMALL piece of L6 at the Anchorage Metalsupermarket. My distaste for them stems mostly from one guy who kept trying to sell me steel for stock removal when I specifically told him I was  doing a pattern welded billet. Wouldn't ball park prices without writing up a quote either. Refused to just give me a price per foot or lb.
Were I in the market for blade steel prices are about a wash from one of the mail order companies and availability is much better. A yard sale Estwing claw hammer beats the socks off both maybe make it worth experimenting on pattern weld.
Funny world eh?
Posted
Finding out that estwing hammers are of a good steel, I'll happily use them to forge something actually useful out of them.  (I hate those hammers, they make my elbow hurt)
  • 9 months later...
Posted
Lug wrenches, as in the kind that are sold with cars to help swap in a spare tire? I've forged them plenty, and they make decent chisels and punches. I've made a few knives with them as well, hardened in oil and tempered to 450 F for an hour. They hold a good edge. I'm sure that it varies by manufacturer, but they're something along the lines of a 1080-1084 as far as I can tell.
  • 4 weeks later...
Posted
I’m really glad I found this. I was about to cannibalize one for a set of tongs. Sounds like it would have been a waste of good tool steel.
Posted
It wouldn't be a waste of tool steel for a pair of tongs. Tongs are tools you'll use all the time. Stronger springier steel allows you to make them thinner and lighter without sacrificing strength.  Light strong tools are easier to handle and less tiring. Using good steel for tongs is a good investment.
However, I suggest you hold off on making tongs from lug wrenches for a while. The steel isn't easy to move, demands good heat management and it's more prone to catastrophic failure. It's kind of finicky.
Right now you need tongs, yes? Buy some bar stock, there are a number of good tong how to videos on Iforge that'll tell you how much and what size to use. Once you get the hang of making tongs, moving on to more difficult and demanding steel means a much higher probability of success.
I like coil spring with about 1/2" wire diameter for tongs. They make light springy tongs and aren't so demanding. Sure it's tougher stock to forge than mild steel but not a whole LOT. Another popular tong steel is 4140 and it's popular for a good reason. 4140 is on a par with coil spring for work to move but is less susceptible to poor heat management.
Posted
I’d rather save the tool steel for the countless hardened tools I need to make. My blacksmithing tool inventory right now consists of a hammer, JABOD, 66lb Chinese cast steel anvil, and a cheap chisel/punch set I bought to get me through until I can make my own. I have some leaf springs off an F250, a couple sway bars, and the tire iron to work with for that. I’m still trying to find a good source for soft steel. Living in rural Texas makes finding good known steel for a reasonable price a challenge sometimes.
Posted
For small round mild I have often found scrapped electric fence rods to be very soft under the hammer---the ones predating A-36.  I once made a nice small dragon from one using the triangular sheet metal stabilizer for the wings.  (Bent ones get tossed where we blacksmiths can straighten them!)
Strap stock is usually not that difficult to find "junked".   Got any friends who will let you prowl their farm/ranch scrap piles?  Just watch out for galvanized stuff!
Now for "Good Known Steel" other than A-36 I'd have to drive the 80+ miles to the city. (For A-36 if the windmill repair and supply place doesn't carry it; it's only 50 miles to a dealer.
Have you checked any local machine shop for drops?
One "trick" I have used to good effect is to always buy one stick of steel more than I need when I make a trip for steel.  If I make a mistake I don't have to make another trip wasting time and $$ and it gives me a supply to use on other projects without a massive outlay of money to "stock up".  Same thing with nuts and bolts.
Posted
Ahh the only mention of 1030 on this page is yours; can you tie it into what it refers to?  4130 is mentioned earlier and is different than 1030.  I picked up the ASM Metals Handbook to check out steels.   30 points C is the cutoff between low carbon and medium carbon steels.
Posted
Also note the source/origin of the tire iron.  i have had some you could use for years and other seemed to be onetime use deals. The ones that come with the car(newer smaller cars dont come with em any more) tend to be on the lesser quality side compared to the after market ones.
so to blanket state that tire irons are **** could lead you to a failed project in some cases.
Recommendation:  get one...cut a piece off of it...spark test it....harden(quench) it with  water.  if its hardens your good to make what you were going to make .  if it doesnt, cool too...make something else.
you are correct ...i miss read earlier.....disregard that post....
  • 1 month later...
Posted
4130 and such is nice if you need some springiness in a part (e.g. some flexture). you quench it and thats it.
Posted (edited)
I like the results I've gotten from the lug wrench I used for a punch. I'm thinking about making some eye punches from the other ones I have after my shoulder issue is resolved. I'm having Blacksmithing withdrawal syndrome (BWS) and it's horrible.  I've been playing with clay a lot but it's the equivalent of chewing on a straw when you want a cigarette:(
Pnut
Edited by pnut
Posted
When I had a bad case of blacksmith's elbow I forged CP 1 or 2 Titanium as it is so soft at forging temp I could use a tiny hammer and my elbow didn't notice I was sneaking in forge time!
Posted
I can still swing a hammer without pain it's just all the other movements that hurt. I know I shouldn't be putting it off but I'm trying to make it through the busy season at work so I can get through the winter financially after we hit the dead season between November and April. I'm not forging because I don't want to exacerbate the injury any further. Hammering isn't the issue. Setting up and breaking down the smithy is when I hurt my shoulder. I don't know if I'll make it to the slow season or not but I'm sure as soon as I see a doctor I'll not be able to work for at least 4-6 weeks.
Pnut
