Beardedblacksmith Posted July 28, 2019 Share Posted July 28, 2019 Does anyone have tips on un-seizing a bullet wilton vice? Quote Link to comment Share on other sites More sharing options...
pnut Posted July 28, 2019 Share Posted July 28, 2019 Maybe soak it in ATF or WD-40 for a while. Beyond that maybe some judicious heating but that could damage it if you're not careful. Pnut Quote Link to comment Share on other sites More sharing options...
Stash Posted July 28, 2019 Share Posted July 28, 2019 An ATF and acetone mix is a very effective home made penetrant. As pnut said, soak it for a while, work at it a bit, lather rinse and repeat until it works free. Patience is the operative word here. Don't try to force things, and use the torch with caution. Steve Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted July 28, 2019 Share Posted July 28, 2019 I soaked one of mine in PB Blaster for a week. Then drove a wedge in the jaws and they came right apart. I guess it depends on the level of seize. Quote Link to comment Share on other sites More sharing options...
JHCC Posted July 28, 2019 Share Posted July 28, 2019 PB Blaster and some judicious sledgehammering got my Columbian apart. Quote Link to comment Share on other sites More sharing options...
Beardedblacksmith Posted July 31, 2019 Author Share Posted July 31, 2019 Thanks for the info fellas! Quote Link to comment Share on other sites More sharing options...
Nobody Special Posted August 1, 2019 Share Posted August 1, 2019 If you feel bold enough, you can also put it in a tote with the acetone/ATF and drive around with it in the bed of your truck. The vibration often helps with stuck parts. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 1, 2019 Share Posted August 1, 2019 Don't be in a hurry! I'd try soaking it in Penetrating oil and gentle tapping for at least a month before escalating. Quote Link to comment Share on other sites More sharing options...
G-son Posted August 4, 2019 Share Posted August 4, 2019 A bit of heat often helps. And I'm guessing a lot of people in this group has access to heat. Just don't over do it, hardened steel parts still needs to be hardened. Quote Link to comment Share on other sites More sharing options...
BIGGUNDOCTOR Posted August 4, 2019 Share Posted August 4, 2019 Depends on how it was seized. Today I could put it outside and it would get to an even 160F plus degrees that would loosen old grease. If it was rust; electrolysis, penetrating oil, kerosene, diesel Does it have a rear cap that can be removed and access the back of the screw? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 9, 2019 Share Posted August 9, 2019 PATIENCE! Soak with penetrating oil every day for several months and tap on it before going to more risky methods! Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted August 9, 2019 Share Posted August 9, 2019 PB Blaster needs to come out with an IV drip for rusty things. Set it and forget it. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 12, 2019 Share Posted August 12, 2019 I have a lot of rusted adjustable wrenches now. I was thinking of buying a gallon of WD 40 and a dump it and them in an ammo can and set it where it will be in the sun part of the day and let it cycle. Memo to self only open can when it is cold to the touch! Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted August 12, 2019 Share Posted August 12, 2019 I would need a lot of WD40 or PB blaster to cover my Wilton C2 vise. Right now I just spray it down every 2 days. I got it pushed in enough that the key on th shaft was resessed in the body so it left me a tiny resivior to fill up. Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 12, 2019 Share Posted August 12, 2019 Scrolling through the Unread Content page, this thread's "Vice seized" title caught my eye, and I thought, "The cops are seizing vises now?" I guess that's why they have a Vise Squad. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 13, 2019 Share Posted August 13, 2019 Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 13, 2019 Share Posted August 13, 2019 Is Vice/Vise seizure covered by the USA's Constitution's 4th amendment? Unreasonable search and seizure... Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 13, 2019 Share Posted August 13, 2019 Only if there is no rust involved. Quote Link to comment Share on other sites More sharing options...
pnut Posted August 13, 2019 Share Posted August 13, 2019 9 hours ago, ThomasPowers said: Is Vice/Vise seizure covered by the USA's Constitution's 4th amendment? Unreasonable search and seizure... "Vise seized" ,I thought it was a medical emergency. Pnut Quote Link to comment Share on other sites More sharing options...
JHCC Posted August 13, 2019 Share Posted August 13, 2019 11 hours ago, ThomasPowers said: Is Vice/Vise seizure covered by the USA's Constitution's 4th amendment? Unreasonable search and seizure... Maybe that's why so many old vises are marked "warranted". Quote Link to comment Share on other sites More sharing options...
anvil Posted August 14, 2019 Share Posted August 14, 2019 On 7/28/2019 at 1:56 PM, Stash said: ATF and acetone mix what Stash said. ATF and acetone are the least expensive and beats all the rest hands down. Somewhere I have the test results on this. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 14, 2019 Share Posted August 14, 2019 Alcohol, Tobacco and Firearms mixed with Acetone sounds positively federal! Quote Link to comment Share on other sites More sharing options...
anvil Posted August 14, 2019 Share Posted August 14, 2019 Lol! Quote Link to comment Share on other sites More sharing options...
