Kev walker Posted September 10, 2017 Share Posted September 10, 2017 Hydraulic press hi all i'm thinking about building an hydraulic press I was thinking about using a 5 inch hydraulic cylinder but I seem to be having problems finding one in the UK does anyone know where to get one in the UK like they fit on most of the Usa 5x8x2 cheers Link to comment Share on other sites More sharing options...
the iron dwarf Posted September 10, 2017 Share Posted September 10, 2017 do you have a suitable power pack? that is often harder to get and then get a cylinder to suit. for forging you want speed more than pressure because as soon as the tool touches the work it get hot fast and the work gets cold fast so you need to work out the best size from the flow / pressure of your power pack. if working with metal cold rather than hot then you need pressure more than speed Link to comment Share on other sites More sharing options...
Kev walker Posted September 10, 2017 Author Share Posted September 10, 2017 No I've got nothing yet just trying to put a parts list together at the moment ? I was thinking get the cylinder first and build the framework then sort the hydrolics to match I was thinking something like this Link to comment Share on other sites More sharing options...
the iron dwarf Posted September 10, 2017 Share Posted September 10, 2017 thats ok if buying new but a lot of people dont have a grand for a powerpack and it depends a lot on what you want to do with your press. how much experience do you have in design and construction, do you have 3 phase and if not you are limited to motor size Link to comment Share on other sites More sharing options...
Kev walker Posted September 10, 2017 Author Share Posted September 10, 2017 I need one to drift hammers I would try to buy new for the Power pack if I can ? I have been building things all my life i have just built this tyre hammer it turned out well it works a lot better than I thought it would very controllable very happy with it No 3 phase Link to comment Share on other sites More sharing options...
the iron dwarf Posted September 10, 2017 Share Posted September 10, 2017 have just had a quick look and seen several new 120mm bore and 140mm bore cylinders on sale but for a reasonable speed and to use them near the working pressure you will need a large powerpack. will pm you a link to one if you want then same seller has lots of other sizes too Link to comment Share on other sites More sharing options...
Kev walker Posted September 18, 2017 Author Share Posted September 18, 2017 Just got this cylinder off eBay 5 x8x2 should do the job ? £140 Link to comment Share on other sites More sharing options...
Frosty Posted September 18, 2017 Share Posted September 18, 2017 Are you a certified welder or at least experienced making welds that have to undergo SEVERE strains? A weld breaking on a hydraulic press is like having a bomb go off in your face. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Kev walker Posted September 18, 2017 Author Share Posted September 18, 2017 Not a certified welder but I can weld I build norton bike frames for a living, I know it has to be stronger than a bike frame I'll manage ok cheers. Link to comment Share on other sites More sharing options...
BeaverNZ Posted September 19, 2017 Share Posted September 19, 2017 Mmmm Motor bike frames Though they would be better if they were dirt bike frames LOL just kidding I am going to be building a yamaha HL 500 frame soon Im making a replica those frames look good Cheers Beaver Link to comment Share on other sites More sharing options...
Kev walker Posted September 19, 2017 Author Share Posted September 19, 2017 Nice one Let’s have a look when you’ve done it cheers Link to comment Share on other sites More sharing options...
John in Oly, WA Posted September 19, 2017 Share Posted September 19, 2017 That cylinder should do the job - coupled with the right motor, pump and valve. Very similar to the cylinder on my press. Link to comment Share on other sites More sharing options...
HIGHSIDER Posted September 21, 2017 Share Posted September 21, 2017 Wow! Those bike frames are stunning! Big in to my bikes. Looking forward to your press build. If its anything like that hammer you built, it will be stunning. That cylinder is a good start. Link to comment Share on other sites More sharing options...
Kev walker Posted September 21, 2017 Author Share Posted September 21, 2017 Wow! Those bike frames are stunning! Big in to my bikes. Looking forward to your press build. If its anything like that hammer you built, it will be stunning. That cylinder is a good start. Thanks I just got the steel and all the Templates have gone off to the laser should get them back in five days so should be starting the build next week with any look cheers Link to comment Share on other sites More sharing options...
Frosty Posted September 22, 2017 Share Posted September 22, 2017 I can breath a little easier now Kev. If you don't do heavy welding I'd recommend reading up on it, you obviously run good beads so it's just adapting technique. I look forward to your work in progress pics and seeing it in action. Frosty The Lucky. Link to comment Share on other sites More sharing options...
Kev walker Posted September 22, 2017 Author Share Posted September 22, 2017 I can breath a little easier now Kev. If you don't do heavy welding I'd recommend reading up on it, you obviously run good beads so it's just adapting technique. I look forward to your work in progress pics and seeing it in action. Frosty The Lucky. I can weld thicker steel, take a look 2 -1/2" to 1” Link to comment Share on other sites More sharing options...
JHCC Posted September 22, 2017 Share Posted September 22, 2017 Very striking! Link to comment Share on other sites More sharing options...
Kev walker Posted September 29, 2017 Author Share Posted September 29, 2017 Well ive started my build 8”x5” h girders still waiting for the laser cutting should have all the main welding done today i think I’ll do three welds on all the 20mm parts that should hold it together It Will add a 20 mm top plate and underneath the top H girder there will be a 60mm striking anvil block should be very strong Link to comment Share on other sites More sharing options...
Kev walker Posted September 29, 2017 Author Share Posted September 29, 2017 Link to comment Share on other sites More sharing options...
Kev walker Posted October 30, 2017 Author Share Posted October 30, 2017 Well got a bit more done on my press almost done the frame and ram parts tig weld first to get a good bite then 2 passes with the mig welder Should be enough to hold it I can’t see it going anywhere should only have about 24 ton should have it painted before the end of the week Link to comment Share on other sites More sharing options...
Kev walker Posted November 3, 2017 Author Share Posted November 3, 2017 Link to comment Share on other sites More sharing options...
jeremy k Posted November 3, 2017 Share Posted November 3, 2017 Kev, looks like your well on your way with your press Link to comment Share on other sites More sharing options...
BeaverNZ Posted November 3, 2017 Share Posted November 3, 2017 Nice not too many people have a partly tig welded press frame Link to comment Share on other sites More sharing options...
bubba682 Posted November 4, 2017 Share Posted November 4, 2017 23 hours ago, BeaverNZ said: Nice not too many people have a partly tig welded press frame Its the only way to go Beaver when i weld mine ill be goin over it with stick 7018 a1 with a little preheat just enough to sweat out the moisture. Link to comment Share on other sites More sharing options...
BeaverNZ Posted November 4, 2017 Share Posted November 4, 2017 47 minutes ago, bubba682 said: Its the only way to go Beaver when i weld mine ill be goin over it with stick 7018 a1 with a little preheat just enough to sweat out the moisture. The Low hydrogen rod run correctly would be just as effective and alot faster as the tig weld but thats up to you, The mosture that you see when preheating is just water condensing from the flame fuel gas hydrocarbons burning and turned into water and Co2 Link to comment Share on other sites More sharing options...
Please sign in to comment
