jlpservicesinc Posted May 8, 2017 Share Posted May 8, 2017 5 hours ago, JHCC said: Excellent! And remember: just because it's spring steel doesn't mean you have to turn all of it into tools. I've been using a lot of mine for nailmaking, lately. What kind of nails are you making out of 3/8" spring steel??? Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 8, 2017 Share Posted May 8, 2017 Practice ones. Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted May 8, 2017 Share Posted May 8, 2017 Ouch.. Quote Link to comment Share on other sites More sharing options...
Melw45 Posted May 9, 2017 Author Share Posted May 9, 2017 3 hours ago, Ranchmanben said: I'm a big fan of coil springs for punches too! I was talking about uncoiling an entire spring, doesn't look like much fun. The small one I did was kind of fun. Once I got it moving it was quite smooth. Mel Quote Link to comment Share on other sites More sharing options...
ede Posted May 9, 2017 Share Posted May 9, 2017 Many years ago, I straightened a roll of garage coil springs and went through the whole process of making chasing tools with them. After hardening, tempering and attempting to do some chasing with them, they bent. Case in point, before undertaking making chasing tools from scrap yard steel, make sure that they are hardenable steel. After all, not all springs are alloyed the same nor have the same purpose. For instance overhead springs are designed to stretch and torsion springs are preloaded with torque to raise and lower a door. Over the weekend, I straightened a 3/4" coil spring with a friend and got 11 1/2'. Using a coke forge to take heats, using the vise initially to get a flat, then reheating and inserting the stock in the hardy hole and straightening with tongs. These will be used for punches. To prep the springs for straightening, I coated the springs with paint remover as the sand blaster was ineffective. It worked OK on one of the several springs I coated. I am thinking a better way of removing the paint so I don't have to breathe those nasty fumes is with a trash fire. I can see two reason for the toil of uncoiling, 1) if you have more time than money 2) you just like doing stuff the hard way--aka a blacksmith. Quote Link to comment Share on other sites More sharing options...
Ranchmanben Posted May 9, 2017 Share Posted May 9, 2017 I generally just cut a coil off with the band saw and burn the paint off in the forge. Quote Link to comment Share on other sites More sharing options...
WNC Goater Posted May 9, 2017 Share Posted May 9, 2017 That's a cool video JHCC posted & fun to watch. But looks like they have too many chiefs, not enough indians. Need ONE guy in charge guiding the operation otherwise, you get that, which appears to be an accident waiting to happen. Surprised no one got burned. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 9, 2017 Share Posted May 9, 2017 10 hours ago, ede said: To prep the springs for straightening, I coated the springs with paint remover as the sand blaster was ineffective. It worked OK on one of the several springs I coated. I am thinking a better way of removing the paint so I don't have to breathe those nasty fumes is with a trash fire. Trash fires create their own nasty fumes, alas. The last time I stripped a spring, I cut it into the lengths I needed first. That way, the coils could rest flat in the container of stripper, rather than my having to do the stripping in installments. (There's a joke to be made about the appeal of slow stripping, but I'm not going to make it.) Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted May 9, 2017 Share Posted May 9, 2017 On the "How to make a skinner knife" Video I used a coil spring and included how i straighten them.... I prefer to straighten all the springs as they just take up to much room in the coil.. straightening springs doesn't really take that long once you figure out how to get what you want hot.. It is easier if you have a forge with a good smoke catcher as then you don't have to smell the paint but I always stand the spring up in the forge one side and then the other till orange and then straighten using the hardie hole primarily and then when needed I use a scroll fork in the hardie hole.. Any of the carbon steels used in springs will show you as they reach transition temperature on the cooling off while bending.. You will notice it starts to glow a little different than surrounding parts.. This is the time to take another heat.. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 9, 2017 Share Posted May 9, 2017 On 5/8/2017 at 1:37 PM, Will W. said: Giant chainmail (just for fun) Fun indeed! Quote Link to comment Share on other sites More sharing options...
jlpservicesinc Posted May 9, 2017 Share Posted May 9, 2017 1 hour ago, JHCC said: Fun indeed! thumbs UP.. Quote Link to comment Share on other sites More sharing options...
Will W. Posted May 9, 2017 Share Posted May 9, 2017 1 hour ago, JHCC said: Fun indeed! Nice! That looks awesome! You beat me to the punch haha. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 9, 2017 Share Posted May 9, 2017 So, uh. How far you going to go with that? Quote Link to comment Share on other sites More sharing options...
Will W. Posted May 10, 2017 Share Posted May 10, 2017 My vote goes for an entire hauberk! Or a coif, at least! Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 10, 2017 Share Posted May 10, 2017 Well, I had enough spring to make a medieval baby blanket. Quote Link to comment Share on other sites More sharing options...
Will W. Posted May 10, 2017 Share Posted May 10, 2017 Well done, JHCC. That is very nice. How about some dragonscale weave next? Full Persian, perhaps? Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 10, 2017 Share Posted May 10, 2017 1 hour ago, Will W. said: How about some dragonscale weave next? Full Persian, perhaps? Who knows? This was only my second piece of maille; here is my first: (Note the additional use of garage door spring!) Quote Link to comment Share on other sites More sharing options...
Will W. Posted May 10, 2017 Share Posted May 10, 2017 6 minutes ago, JHCC said: (Note the additional use of garage door spring!) Garage door spring is truly wondrous material apparently! The possibilities are endless. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted May 10, 2017 Share Posted May 10, 2017 I don't know how comfortable it would be, but it would be fun to see a blacksmith's hammock made out of the giant chainmail. Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 10, 2017 Share Posted May 10, 2017 Attached to some very stout trees. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted May 10, 2017 Share Posted May 10, 2017 Indeed! Or a forged up framework. Quote Link to comment Share on other sites More sharing options...
Will W. Posted May 10, 2017 Share Posted May 10, 2017 1 hour ago, John in Oly, WA said: I don't know how comfortable it would be, but it would be fun to see a blacksmith's hammock made out of the giant chainmail. Yeah!!! I hope you don't mind if I... Ugh... "Borrow" that idea haha. Quote Link to comment Share on other sites More sharing options...
John in Oly, WA Posted May 10, 2017 Share Posted May 10, 2017 By all means, borrow away! Just post the pics. Would be nice to see. Quote Link to comment Share on other sites More sharing options...
the iron dwarf Posted May 10, 2017 Share Posted May 10, 2017 maybe someone should do a farriers hammock out of horse shoes closed up and made into riveted maille Quote Link to comment Share on other sites More sharing options...
Will W. Posted May 10, 2017 Share Posted May 10, 2017 25 minutes ago, John in Oly, WA said: By all means, borrow away! Just post the pics. Would be nice to see. Will do. When I get around to it... 8 minutes ago, the iron dwarf said: maybe someone should do a farriers hammock out of horse shoes closed up and made into riveted maille Seriously! The creativity here is amazing! Awesome idea! Quote Link to comment Share on other sites More sharing options...
