May 1, 20179 yr Here is the latest Axe I have finished. I started it last year whilst working along side of a student who made a dane axe from riggers shackles. A damascus Dane axe, low layern Body folded and punched and then a high layer edge . Materials 15n20 and en42J... The material follows the shape of th eye and although the axe is folded I completly forge welded it and re punched through the material. The higher layer edge is wrapped over the lower layer core material. I wanted tight subtle pattern in the edge and a bold body.
May 8, 20179 yr Author On 01/05/2017 at 3:03 PM, Latticino said: Absolutely stunning. Care to share the edge length and weight? the weight is 1 lb 15 Oz, 9.5 inches along the edge. Thanks for all the kind words
