My First Project - Tongs
Caleb Hale
Preface: Sorry to those who object to the idea of tongs being someone's first project. I didn't start reading here until I had already planned and started this adventure :D
So I've been at this whole blacksmithing thing for about 3 weeks now, I'm definitely hooked. I just had to steal the propane tank from my barbecue pit to finish heating the pin for these tongs, so yeah. I started off pretty slow because well, my arm was just a limp noodle after a few hits...I'm much better now.
This is actually my second attempt at tongs, the first ones I abandoned very early on, after my first day of forging, when I realized I didn't have enough metal in the boss.
These are made out of whatever the low grade steel bars are they sell at the big name hardware stores - 1" x 1/4" x 3' flat bar (I read that it's A36 steel from an unofficial source). The pivot pin is the same steel - 1/4" round bar.
I used 2 whole cans of propane while forging them / learning to forge...that was a bit of a shocker how fast it goes, but I know I'm wasting quite a bit right now. All good.
Anyway I'm pretty proud of how they turned out, and they seem like they will do the job intended. The real test will be when I actually hammer on hot metal while gripping it with them I suppose. They've got good motion to them and are comfortable when I'm gripping the intended steel. Most importantly it was a completely awesome experience and I can't wait to make more stuff.
Picture time...
Everything is pretty much in-line and on-center.
17349810_10202927647907536_6094971794583
Overall 25" length. I rounded the handles as much as I could by hand.
17239744_10202927647787533_5082667983300
Front profile view...sorry so dark. LED lighting for my workspace is on the to-do list.
17310324_10202927647227519_4505961895907
Rear profile
17359202_10202927647307521_6778081660519
This is the first side of the pin I hammered on. It started to fall off to one side as I was hammering...I recovered a little bit. The pivot hole is actually centered in the boss.
17349748_10202927647707531_8937733941405
I punched as big a hole as I could in a piece of 3/16" flat bar and set it under the boss with the pin in it for my first few strikes (not sure what the technical name for something like that is, swage block?). It kinda worked, not as well as planned (needed to double the thickness of my swage block or whatever it's called) but I do have 1-2mm of pretty thick overlap all around the pivot hole on the other side. Notice the hole actually is centered from this side...
17349621_10202927647747532_5830455168749
This is the knife stock they will be holding for me. They have a nice, firm grip on the material. They feel springy in my hand when I grip tight.
17349744_10202927647267520_4275235024204
Banged it around on the anvil a few times...didn't budge.
17240697_10202927647347522_3198965381758
All comments and criticism welcome! And thanks for reading this far! :D
Pretty good first try. Pay attention to the interior corners next to the bosses: it looks like you've got some cold shuts and cracking starting there. Make sure that there's a bit of a radius on the edge of the anvil where you do the set-downs. I strongly recommend that you go back and round out the reins more; the sharp corners are going to be hard to grab and will tire your hands very quickly.
Keep up the good work!
10 hours ago, Daswulf said:
The term you are searching for I believe is "Bolster plate".  Nice work on your first completed tongs.
Bolster plate, thanks! I need to make some modifications to my bolster plate for the next time I pin some tongs.
3 hours ago, ausfire said:
Nice job. Folks say tongs are easy to make but they're not.
Agreed! It would have been a lot easier if I didn't have to make a matching pair.
I struggled with making any radius at all because my anvil is new. Should I think about dressing the edges myself or just let it wear down on it's own?
I wanted to round the entire reins but I was worried about drawing the material out too thin, so I just did the handles.
Thanks for the kind words everyone!
Pictures, please. Hard to answer without seeing what you're actually dealing with.
If you're hammering your stock on the edge of the anvil and hammering half-on/half-off, the force of the hammer blow will indeed penetrate farther into the stock and draw it out more. However, if you hold the stock flat on the anvil and hammer on the corners of the square, you can round off the edges without substantially reducing the thickness.
Can't take any new ones right now, but in the last photo you can see the edge of my anvil pretty well. It's got a pretty sharp right angle to it all the way around like that. I've seen some posts about "dressing" an anvil, but grinding down the edge to a radius makes me nervous.
Okay, generally speaking, sharp edges on an anvil are a Very Bad Thing, largely because of how they can cause cold shuts and stress risers. However, they can be useful when notching steel to mark it.
At the same time, some different radii can be helpful for creating quarter-round set-downs or for heavy drawing out.
There was a very good thread about this on IFI a few years back; see HERE. Also, take a look at Mark Aspery's "Old School project #3 - The Miner's Candlestick" video, to see a variably radiused edge in use.
just to say, were it my anvil I would radius the edges a bit in certain spots. It's a bit scary to do to a new anvil but just don't go extreme. I would say to research it a bit before doing anything. It's easy to take material off but not so easy to put it back.
That's a really good first pair of tongs. Just do that and make them overall beefier. The reins are a good size. Keep at it!
if you are ever neer me, feel free to shoot me a message and drop by! Or if you just are wondering about where to find stuff, don't hesitate asking, I'll try and help out as much as I can.
                                                   Littleblacksmith
                                                   Littleblacksmith
Awesome thanks for the offer! I was actually out near Bryan a couple of weeks ago at a demo at Steephollow Forgeworks where I picked up my forge and anvil.
It's only about an hour drive for me.
I was there too! were you there Friday? also, did you get the chance to meet a fellow by the name of Matt Marti? he makes some beautiful hammers, and also did a demonstration. Did you get your anvil and forge from the front where there was Tons of tools, or in the back? I had to keep myself from buying everything do to the high prices..... Steep hollow is only like 30 minutes from my house.
        Littleblacksmith
        Littleblacksmith
I came out Saturday afternoon. The only person I met was a guy named James who owns Texas Farrier Supply out of Fort Worth...he was setup right in the front where most of the anvils were. It was just pure luck that when I bought my anvil/forge online he emailed me back that he would be at that show and if I wanted to meet and pick it up in person to not have to worry about shipping costs.
I did see some really nice hammers there. I actually went with the intention of buying one, but my jaw dropped a bit when I saw the prices. Then James recommended I start out with a cheap hammer anyway to see how heavy I like it before I spent a lot of money...that was probably good advice.
The hammer I use the most is one I paid $5 for at a flea market.
The one I use the second most was in the garage of the house we bought seven years ago, so it was free. Of course, you could say that I paid six figures for it, but it came with a free house and garage.
You can take a block of steel and radius the edges and then weld on a stem. It does not nee dto be on the bottom just so you can stablize it in your hardy hole. This will give you some rounded edges, and you can make a variety to see what works best for you with out worrying about the new anvil.
Awesome tongs dude! Way better than my first set. 2 bottles of prop though, ouch!
Just curious, how fast do you burn through a tank? I can usually get about 7hrs out of one but I only have a single burner.
I'm so frickin jealous of y'all. I was looking forward to going to that dang demo for a month until my boss told me a had to work. Maybe next year :(
Great tongs man.  I've tried and failed like 4-5 times so far, bought 1 pair of Wolf's Jaw tongs and they've been great,  I plan on attempting some more tongs here in the near future, hell I'll be happy if they looks or operate anything remotely close to how yours look.  Major Kudos for the first pair....Job Well Done.
Thanks man! Yeah I think I was scared to hit it real hard the first few times...wasn't moving much metal. That first tong took like 4 hours or so, second one probably only about 2 hours.
I'd say a tank last me 5-6 hours using a dual burner setup.
Thank a lot man I appreciate it!
