CKillgore Posted March 17, 2015 Share Posted March 17, 2015 Hey guys,I've got a new style 100lb. LG hammer. I am trying to build a guard for the spring and wanted to attach the guard to the 3 long bolts going through the ram guide. Unfortunately, there is not enough bolt there to get the guard piece on it. Is there any reason not to replace them with threaded rod? I have a metal lathe and the capability to turn my own bolts but it seems like all thread would be an easier solution. Thanks,Cody Quote Link to comment Share on other sites More sharing options...
jeremy k Posted March 17, 2015 Share Posted March 17, 2015 Use the threaded rod as needed - works just fine on my new style hammer. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted March 17, 2015 Share Posted March 17, 2015 What grade are the guid bolts? Be aware that "studs" will exhibit higher clamping forces than bolts for the same torc. Being that a nut produces less friction than a bolt, and you experience less stretch. Secondly be aware that not all " all tread" is the same, grade 0, 3, 5 and 8 being common bolt specks, wile comely one only finds grade 0&3 rod, one might look at graded studs, they typically have corse threads on one end and fine on the other, but are available in grade 5&8. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted March 18, 2015 Share Posted March 18, 2015 Greetings CK,A simple answer seeing that you have a metal lathe .. Drill and tap the bolts on the head end for say a 3/8 stud.. That should work just fine...Forge on and make beautiful thingsJim Quote Link to comment Share on other sites More sharing options...
jeremy k Posted March 18, 2015 Share Posted March 18, 2015 Charles - no need to over think - the guide bolts do not get torked to a spec, they just get tightened enough to hold the guides in place with some clearance for the ram to move. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted March 18, 2015 Share Posted March 18, 2015 Sorry, automotive mechanic, lol. "Third rock from the sun" mind set "when everything is spinning round, things tend to come undone" ;-) Quote Link to comment Share on other sites More sharing options...
CKillgore Posted March 19, 2015 Author Share Posted March 19, 2015 Thanks for the advice guys. I think I am going to go ahead and order some all-thread. If it doesn't work out for whatever reason, I may try Jim's idea!Cody Quote Link to comment Share on other sites More sharing options...
Crazy Ivan Posted March 19, 2015 Share Posted March 19, 2015 I'm no expert on LGs, but yesterday I was working on a friends 50LB LG and we replaced the guide bolts with 5/8X3 1/2" grade 8 bolts to accept her guard and hold the guide in place with nylon nuts just holding the guide, then the gaurd frame, then another nylon nut to hold that in place. I ran the hammer all day today and it didn't seem to be a problem. I wasn't the one who [paid for the nuts and bolts, but probably around $10 at a local big box store.(using the term "nylon nut" meaning whatever those nuts are called with the nylon thing on the inside of the thread to prevent it from backing out inadvertantly) Quote Link to comment Share on other sites More sharing options...
Judson Yaggy Posted March 19, 2015 Share Posted March 19, 2015 One brand name for them is "Nylock" Quote Link to comment Share on other sites More sharing options...
SoCal Dave Posted March 20, 2015 Share Posted March 20, 2015 Hey Crazy Ivan: I have a 50 lb LG also and would like to see the guard setup. Some pictures would be great, if possible. Thanks, Quote Link to comment Share on other sites More sharing options...
jason0012 Posted March 31, 2015 Share Posted March 31, 2015 Buy some B-7 allthread. McMaster, MSC and such carry it. B-7 is the ISO equivalent to grd-8 . Quote Link to comment Share on other sites More sharing options...
Suboc Posted April 11, 2015 Share Posted April 11, 2015 (edited) This is how I did mine on my 100# ...I took cold rolled and cut just enough thread for the nuts and left the center section unthreaded so the adjuster bolts make contact with the unthreaded section.Dan Lehman Edited April 12, 2015 by Suboc add photo Quote Link to comment Share on other sites More sharing options...
winterbear Posted April 12, 2015 Share Posted April 12, 2015 Subok that is a pretty hammer! Chris Quote Link to comment Share on other sites More sharing options...
Suboc Posted April 12, 2015 Share Posted April 12, 2015 (edited) Subok that is a pretty hammer! ChrisThanks Chris. Those photos were taken several years ago just after I had rebuilt it. Believe me, it's not that clean anymore but has proven to be a great hammer. Edited April 12, 2015 by Suboc Quote Link to comment Share on other sites More sharing options...
Black Frog Posted April 13, 2015 Share Posted April 13, 2015 Very nicely done! I'm saving these pics foe future ideas. ... Quote Link to comment Share on other sites More sharing options...
Crazy Ivan Posted April 13, 2015 Share Posted April 13, 2015 Hey Crazy Ivan: I have a 50 lb LG also and would like to see the guard setup. Some pictures would be great, if possible. Thanks, Hey Dave, My apologies for not posting those pics. I just saw this now. I'll keep you in mind next time at the shop and try to get some pics up for you asap. Quote Link to comment Share on other sites More sharing options...
