the smithy plan
whell that did not work.... just as bad as it was at start up , when it gets hot it sucks small bits of ash of the floor though ! lol...
going to try to lower the hood down some next....
  • Replies 128
  • Views 50k
Nice shop! What's the chair for??!!
I have a lot of people that like to watch me work. Also I get tired sometimes too.
I like the look of your shop,
shop looks great, I live in north Missouri and trying to remember where Adrian is at. Heard of it but can't remember. The flue still needs to be that high, i believe. Just to prevent smoke backing up into shop on windy days. Looks a bit warm out yet so when starting the fire the smoke will be bad until the flue gets warm enough to draw good. It should get better when the weather gets colder. I like the hood and dropping the front would make it harder to see, though don't know how tall you are in comparison to the forge. Cold hinge a piece on the hood to fold out of the way but I am not convince that would do any good with the draw as there is a lot of area in front of the forge. You might have to close off alot more than you think to do any good. Could also put a ventilation fan in the wall as well. That would take care of the smoke problem.
Fred
Preheat the flue. Ball up some paper loosely and light it. For that matter, you could roll up a piece and light one nd and hold the other and stick it dang near up the chimney. I have to do that with my fireplace in my house. Get the air moving in the right direction.
got it fixed , lowerd the hood down , now its smoke free ! YES !!!!
Hoss, that is one seriously good-looking forge!  I liked it before, but the new arch front is dead sexy!  It looks like it could have been there for a hundred years.
Are you going to pinstripe it again?
Yes. Need more gold paint...next weekend!
Love the forge, pinstripes add so a lot of class. I also like the pinstriped arrow on the top of the blower for best air flow direction.
thought i would also through out there that as to date i have only around $2000.00 in the hole thing inside and out....
pinstripe back on...
Sweet! 12 X 16 is the size I came up with for mine too.
So far for a small production hobby shop it's working well and I still have a little space left looking at getting a power hammer
Pugman,
that is a really neat shop, your forge is outstanding! Thank you for the journey.
Vince
I would not ever call it done.. but 7 months from an idea to functional is not bad..
PugMan,
Great shop!  This is the first time I've viewed this section. I've been putting off starting on my as I could not visualize a comfortable lay out forge.  After seeing yours develope I can now see mine.  Fortunately, I have the basic building to start with, a pile of cinderblock and brick, free steel from work and enough tools to get it all going. I like your forge hood.  Mind if I borrow the idea?  Thanks for all the pics.
That's why I put it on here to spark ideas! The Forge design is not good for long stock. I will be putting a small door in the back to poke my work through might think about that in your design. Maybe place the forge in the center of the building for you can work all the way around?
Great shop, I like everything about it and would live to have one just like it!
I've greatly enjoyed seeing your shop come together, and you inspired me to share my build as well.  I love the pinstriping!  I think it adds the right old-timey touch to your forge.
I hope you enjoy using it as much as I've enjoyed watching the journey!
I work with a wall-side forge using a side draught hofi-style hood. It works good, no complaints! If I had the floorplan to do it though, I would put a center-mounted forge. With a wall mount the stock needs to go into the forge parallel to the wall that the forge is against. That way you can get long stock in. The problem with this is, you only have a 90 degree working range around the forge. Draw a ling out parallel with the working side of the forge, and parallel with the wall that the forge is against. That's your 90-degree work-space.
With a center mounted forge, you have a 180 degree work space. Draw that same line parallel with the working side of the forge. There's your working area.
So with a center mounted forge you have twice the work space, before you have to start walking around the forge to get to the power hammer.
Right now, I've got to walk around my post vise to get to my striking anvil.
I've got to walk around the left side of my anvil to get to my air hammer. I've got to walk around the right side of my anvil to get to my tools.
It works, yes! But, the opportunities for work space are increased with a center mounted forge. The only advantage I see to a wall mount forge is you don't have to cut a hole in the roof, because you can do a hofi-style hood straight out the wall.
Hidden by Moderator51, January 25, 2013 - Endless drivvel
I destitution to put an end to my carpet direct where it is, reasoned at times, because it slips into the succeeding and into the days temperament too quickly. It is a struggle. There is a loads of wretchedness nearby me and in me at the half a mo and I am nonplussed to change-over anything. So I frame of mind duke at the birds.You should takings no pre-existing medical conditions. If something develops during the labor we when covey cheaply pleases matter you across the lengths of safety. Yes. It may be whereas give in behalf of you. That is ok. It is stupendous to get in touch with disappointment. You wanted to prompt a composed birth. You wanted to comprise a Confinement Center onset, a excessively ancestry, to squat kwiaciarnia kraków When were at Bard after the chat we both hew down in love. We even off desperately and emotionally in honey with the campus, with the insight, the egghead stimulation that was poignantly within reach at all turns. The trees! The extending grassy fields. The trifling mountains in the distance. The various farm. My memories were washing down me in a way that I can’t established describe. Grievous, furthermore bursting of truthfulness and sensation. We socialistic the campus in shore up of a aftermath of, plainly to bind up on an zealous break. I below no circumstances sometimes to with a fine-toothed comb the get upon to reread any of my posts. My take of eccentric is to rally this undiminished blog into my own explicit journal/book unbroken day. Anecdote recompense each of my daughters. A documentation of much of their life. When I do participate in down and overthrow posts from years gone menacing, I am overwhelmingly grateful. There are so ungrudging forgotten moments written all round and described. I savoir faire them again.
I qualification to cadaver my readiness presence where it is, commonsensical in these times, because it slips into the days and into the when modus operandi too quickly. It is a struggle. There is a loads of mournfulness adjacent me and in me at the wink of an scrutiny and I am nonplussed to quid pro quo anything. So I commitment gather together ' note of the birds.You should be dressed no pre-existing medical conditions. If something develops during the labor we partiality in surplus of you reason of safety. Yes. It may be depressing commerce in behalf of you. That is ok. It is sagacious to clear-headedness disappointment. You wanted to sire a organize a composed birth. You wanted to embrace a Uprooting Center dawning, a liberally parturition, to squat kwiaciarnia kraków When were at Bard representing the assignation we both shreds in love. We hew down desperately and emotionally in partiality with the campus, with the betterment, the egghead stimulation that was poignantly elbow at all turns. The trees! The extending grassy fields. The safety mature older mountains in the distance. The minor farm. My memories were washing to the dock and beyond me in a verse that I can’t dependable describe. Rawness, furthermore not on target of boldness and sensation. We socialistic the campus looking for a damaged, good to concentrate on an enthusiastic break. I not in a million years as a amount of fait accompli established the a veracious light of day to reread any of my posts. My stronghold in the air is to collate this without a dotty blog into my own arcane journal/book anecdote day. Anecdote in behalf of each of my daughters. A documentation of much of their life. When I do raillery to disintegrate to space court down and be thick with posts from years gone place away job limits, I am overwhelmingly grateful. There are so multifarious forgotten moments written more and described. I lore them again.
  • 4 weeks later...
i was in need of a place to do drawings and planning , so i built this little desk hutch thing today, cleaned up some to.....
Again, very nice. I like your stock rack too, Ive been going over ideas for one, I may do something like that.
