Safety glasses for forging...
4 minutes ago, turbo7 said:
There is no such thing as "too much protection" but I havnt got an astronaughts helmet and a lead lined leather suit either.
I respectfully disagree.  If the protection restricts your movement or vision to the point where it crosses the liability/benefit threshold then it is too much protection.
  • Replies 389
  • Views 140k
Most Popular Posts
  • Blacksmith Johnny
    Blacksmith Johnny
    check out my new torch goggles, my boy said there steam punk whatever that is- lol
Ok thanks. the radiation is infrared radiation I believe. So I assume that as long as I am not getting sun burn, I should be alright. Maybe I should wear long sleeves though.
I recently went in for an eye exam and while there I asked the dr. if prolonged exposure to IR could contribute to cataracts.  He said that it certainly can, so reduce the amount of exposure if possible, like not staring into the fire for extended periods of time.  Occasional glances or periodic "looks" to check on your iron probably would not have a detrimental effect.  He said that if one needs to look into the fire for extended periods of time to get IR filtered glasses.  Where and what kind is another topic.
John,
Beware the "Expert" that just joins the crew. Guy I know that was an apprentice on a stone mason crew that built rock walls in SW Virginia told me about this guys first and last day on the job. As I understand it a good quality chisel will mushroom and this guy was bragging about the quality of his old chisels. The first blow he landed on that first day shot a chip on to his hand that came way too close to looking like a suicide attempt. I don't think he needed glove because his tools loved him? They were up in the foothills of the Blue Ridge and after they got the bleeding stopped they got him to the ER. About 1/2 days work wasted not counting getting blood off the Boss' rock. Even a well trained tool can turn on you and taste your flesh and blood.
I investigated this issue at some length when I first started Smithin, as both cataracts and MD run in my family.  I asked my own ophthalmologist and he had no clue, had to research online to find out about the IR danger and take precautions by buying some IR glasses.  I never forge without them, keep a spare set for any hangers-on, too.
You might consider sending your ophthalmologist a copy(ies) of your findings........;)
If you're concerned about nuclear radiation from coal, wear a dust mask and goggles. Shower immediately when done,  shampoo repeatedly. There's no really good way to get hair completely clean though it's just too porous. Maybe just keep shaved down. Wear coveralls and wash your clothes separately.
Of course if you were to walk around with a Geiger counter sometime you'd discover we're surrounded by radioactive stuff. And the RADON Oh my run RUN!
Minimize exposure but don't get silly about it.
The only EM radiation from forges is IR. Don't stare into the fire, keep an eye on your steels but don't stare.
I live at an elevation, have igneous rocks around where I live and drink groundwater that sometimes  fails the radionuclides levels; skin cancer and driving to work is so much  more a danger that radiation due to coal exposure isn't even in the same order of magnitude, Black Lung is a greater possible issue!
You also suffer high doses of radiation from that big unshielded fusion reactor in the sky!! Igneous rock too? :o  Oh my. At least you don't have big trees too close do you?
About coal and radiation and radioactive particle releases. Just because virtually every coal power plant releases more radiation a month (I don't recall the actual number and ain't going to look it up) than 3 Mile Island during the "Melt Down" doesn't mean we're going to change to clean power. Too much lobby power in DC from the coal industry for that to happen.
No, I'm not suggesting an atomic reactor as a forge. On the other hand if you put one together and get it working I want PICTURES. B)
Now I worked out the plans for a thermonuclear powered forge; but then I realized that the common high winds out here would make it impossible to use and maintain without a dedicated shop building and a method of moving it in and out.
That would require some EXTRA LONNNNNNNNNNNNNNNNNNNNNNNNNNNNNNG tongs!!! :wacko:
There's always something isn't there? Think of the clinker.
As long as we are worrying about things.
BP0051 Good Coal
Trace elements are defined as elements present in coal in amounts of less than 1 percent by weight. Generally, trace elements are present in coal in amounts much lower 1 percent, and are reported in parts-per-million (ppm) by weight in the coal. A trace element concentration of 1 ppm = 0.0001% by weight, or expressed in another way, a 1 ppm concentration of a trace element equals one pound in one million pounds (500 tons) of coal. Most trace elements in West Virginia coals are present at levels of 10 to 100 ppm, or less.
Highly toxic elements (e.g. arsenic, mercury, lead, and selenium) are present in West Virginia coals, though generally in very low concentrations. How hazardous elements present in very low amounts adversely impact the environment is a matter of scale. For example, a coal fired power plant with no pollution controls in place theoretically would produce 10 tons of lead for each million tons of coal burned containing 10 ppm lead. However, modern pollution control measures provide controls against the release of large amounts of hazardous trace elements to the environment.
A table of statistical correlations of trace elements with ash yield, in decreasing order of significance, includes Chromium (Cr), Thorium (Th), Scandium (Sc), Cesium (Cs), Rubidium (Rb), Lithium (Li), Vanadium (V), Hafnium (Hf), Cerium (Ce), Lanthanum (La), Zirconium (Zr), Tantalum (Ta), Niobium (Nb), Dysprosium (Dy), Holmium (Ho), Lead (Pb), Samarium (Sm), Europium (Eu), Gallium (Ga) and Tellurium (Te). These elements likely occur within mineral matter in coal. Most of these elements probably occur in silicate minerals, especially clay minerals, which make up 60-70% of the mineral matter in coals.
Trace Elements in West Virginia Coals
Antimony (Sb) Erbium (Er) Manganese (Mn) Tantalum (Ta) Arsenic (As) Europium (Eu) Mercury (Hg) Tellurium (Te) Barium (Ba) Fluorine (F) Molybdenum (Mo) Terbium (Tb) Beryllium (Be) Gadolinium (Gd) Neodymium (Nd) Thallium (Tl) Bismuth (Bi) Gallium (Ga) Nickel (Ni) Thorium (Th) Boron (B) Germanium (Ge) Niobium (Nb) Thulium ™ Bromine (Br) Gold (Au) Praseodymium (Pr) Tin (Sn) Cadmium (Cd) Hafnium (Hf) Rhenium (Re) Tungsten (W) Cerium (Ce) Holmium (Ho) Rubidium (Rb) Uranium (U) Cesium (Cs) Indium (In) Samarium (Sm) Vanadium (V) Chlorine (Cl) Iridium (Ir) Scandium (Sc) Ytterbium (Yb) Chromium (Cr) Lanthanum (La) Selenium (Se) Yttrium (Y) Cobalt (Co) Lead (Pb) Silver (Ag) Zinc (Zn) Copper (Cu) Lithium (Li) Strontium (Sr) Zirconium (Zr)
Time to go light the forge and make something while we consider all this new information. Oh yes, wash your hands before dinner as you would not want to ingest any trace elements. (grin)
I wonder if anyone is looking into "mining" the ash for rare earth metals...
This has me thinking. I always have water with me by the forge. I have to be careful not to get any dust where my mouth goes.
Ya never know what might be in the water, either!!! (think Flint, Michigan....... :rolleyes:)
Spanky, do you recall where you purchased your IR glasses, or did you just do a web search?
I wear prescription glasses, so I guess goggles would be in order.  I have already had to buy two sets of prescription glasses recently, so getting some of those in IR resistant is out of the budget.
I bought mine on Amazon.  I looked at some local welding shops and quite surprisingly they didn't know what I was talking about when I said I needed some IR glasses!  I think UVEX brand was the one I finally settled on.
O-A welding shades work; a number 2 is suggested if I recall correctly.
Bad eyes so I bought prescription #3 welders green safety glasses.  I've complained for years about the radiation from coal fired power plants in comparison to well run nuclear power plants.  (got one just across the river from me).  Lived in Tennessee for a while, all of the rivers I wanted to fish had so much mercury that you couldn't eat your catch.
The UVEX I bought were #3 shade also.  Charlotte, that's still true down here, fishing is for sport, definitely not for eating!
I got two pairs of the UVEX goggles; one for me, one for my son. Shade #3.
