Welcome Nyckname, If you edit your profile to show your location we won't dun you for it when the answer depends upon it. This thread will help you get the best out of the forum. READ THIS FIRST
That is a good looking Fusil no doubt.
I have resurrected several old barrels using this same method. My last was an original German 56 caliber Jaeger that I restored. I did a final polish by fire lapping the bore, after about 20 rounds most of the pitting was gone.
https://www.muzzleloadingforum.com/threads/jaeger-project-rifle.93808/
Welcome to IFI... I suggest reading this thread to get the best out of the forum. READ THIS FIRST some answers depend upon your location, hence the suggestion to edit your profile to show location.
Your plans look good to me, although I wouldn't waste the money on ITC 100. Instead I would use Plistix or Metrikote which work better and a whole lot less expensive. Wayne Coe (member here) can supply small amounts of both.
Yep, that's the screw box. Cleaning it and the screw is normal maintenance. I only consider taking it apart when the mount, spring and movable jaw/ leg are removed. I see no need to do that with your vise. It looks to be in very good condition BTW.
Gotta love it, learn something new just about every day.
https://www.google.com/search?q=backing+out+punches&client=firefox-b-1-d&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi6o52WmdXgAhWG4FQKHaGGB9sQ_AUIDygC&biw=1138&bih=511
Welcome to IFI I always suggest reading this to get the best out of the forum. READ THIS FIRST
Your A&H looks to be in very good shape, to see the serial number you can chip away the concrete covering it at the front foot under the horn.
I also see 1916 on the front foot. A wire wheel on an angle grinder should clean the rust pretty well, just no grinding, milling or welding on the hardened face. Hammering hot steel will shine it up just fine.
Ya done good and what a great tribute to your grandfather, I bet he is looking down and smiling. The only thing left to do is have a dram in his honor.
Sorry to hear about your grandfather.
Yep Iron City. I wouldn't do anything to it except a light brushing with BLO to preserve the patina and oil the screw then put it to work again.
