There were some amazing overtones and undertones that my wife pointed out. Picked out at least a dozen tones. Some of us can't hear the higher pitched tones, even with my hearing aids.
Where might that be? Have you read this yet? READ THIS FIRST
I don't believe I could spend $400 U.S. for half an anvil. Now if they had the broken base that could be welded back on, that might be a different story. Not sure if Trenton used wrought iron for the base though.
Have him take a look at this thread, the only way to "fix it right" IMO.
Robb Gunther and Karl Schuler's Anvil Repair Process - Anvils, Swage Blocks, and Mandrels - I Forge Iron
You're welcome Kacy. It was pure luck that I remembered the star as a Swedish makers mark, Forgot it was used by Kohlswa. You have a premier anvil to say the least. They ring so loudly because they are cast steel and a lot of us have found out to quiet the ring, is to set the anvil with cheap latex calking compound between the base and anvil stand. Doing that will tone it down but not effect the rebound at all.
Yes, 1 part wax, 1 part turps, 1/2 part BLO also seen the amount of Japan Drier described as a generous pour so I'm not sure it's critical as to the amount of JD. If I remember right the first three parts were in cups.
You can highlight a small section and a quote this button pops up, click it. Useful if your reply drops to another page or is a few posts away from your reply.
Look up Medi-Lyte, they are replacement for salt tablets. We use them for hydration and electrolyte replacement. Much better than Gator Aid. If you have medical problems check with your doctor (ours recommended them for us).
Just keep in mind that charcoal takes a lot less air than coal. A constant air supply, like with an electric blower, will result in using too much charcoal and actually a cooler fire. So you will need a way to control the air supply.
Knowing where in the world you are located may help. Hence the suggestion to edit your profile to show it. READ THIS FIRST
I think it's a Swedish North Star anvil 130 pounds.
https://www.iforgeiron.com/topic/48016-swedish-star/
You have probably seen this already. Christopher J. Downs Blacksmith from 1902.
https://delawarecountyhistory.com/radnortownship/RADNORDIRECTORY1902E.htm
I believe Centaur Forge added that disclaimer after several of our members had problems with their Kanca anvils. I don't remember seeing it prior to then.
https://www.iforgeiron.com/topic/61932-kanca-new-165-anvil-with-a-soft-face/
How much an anvil is worth depends greatly on where in the world it's located. Hence the suggestion to edit your profile to show location. READ THIS FIRST
Welcome to IFI. We won't remember that once leaving this post, hence the suggestion to edit your profile to show location. This thread will help you get the best out of the forum. READ THIS FIRST
Exactly what I need, all I have to do is look at something sharp & I wind up bruised or bleeding. A side effect of chemo and getting older. I've been using archers sleeves which help but Kevlar is so much better.
